03-12-2023, 08:44 AM | #1 |
Rep 23
G21 M-sport 19" - front tyre wear!
My g21 is just over 2yrs old, 24k miles, and the front tyres have plenty of life left on the tread. The issue is the outer shoulders with excessive wear...is this the usual story of RFT tyres? Anyone else experienced this, and maybe changed to non-RFT?
03-12-2023, 09:06 AM | #3 | |
Rep 15,857
We need to remember RFTs are slower to warm, even worse in wet weather. The setting pressure may need to be higher, particularly for shorter trips (if that is our regular driving) where tyres may not get to working pressure for many miles of our driving. BTW, how do I know? Been there, experimented through experience. |
03-12-2023, 10:05 AM | #4 | |
Rep 23
03-12-2023, 11:58 AM | #5 | |
Rep 575
If doing them after a reasonable drive, the pressure will drop as the tyres cool, especially at this time of year. |
03-12-2023, 12:03 PM | #6 |
Rep 1,715
Drives: 2014 650xi Gran Coupe Msport
If it’s just the outer shoulder then you need an alignment.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
03-12-2023, 04:00 PM | #7 |
Rep 15,857
03-12-2023, 04:15 PM | #8 |
Rep 1,715
But only while turning in one direction???
03-12-2023, 04:32 PM | #9 |
Rep 15,857
I'm reading the OP has outer wear on both front tires, from the description in the first post.
Anyone around BMW through the years will know that outer front and inner rear wear can be 'normal', even with correct OE geometry calibrations. Harder you drive the more it is evident. RFTs can make it happen faster, due to the stiffer sidewalls. Hence why keeping pressures at optimum settings can minimise the shoulder wear, without changing alignment calibrations. |
03-12-2023, 05:49 PM | #10 | |
Rep 1,715
03-12-2023, 05:55 PM | #11 | |
Rep 15,857
I hope the OP has checked the rear tires, many get caught out with inner wear, before they know it. BTW, many UK users get excessive shoulder wear simply using lots of roundabouts. |
03-13-2023, 04:41 AM | #12 | |
Rep 23
03-13-2023, 05:24 AM | #14 |
Rep 23
03-13-2023, 06:59 AM | #15 |
Rep 355
Definitely not the case for RFTs. Due to a large piece of metal through one of my rears I have just removed the Turanza T005 RFTs from my M340d and whilst the rears were worn down in the middle (apparently common with these) the fronts were evenly worn with 4-4.5mm left..... too good to just throw away. If yours are wearing on just the outside and its not driving style (high speed cornering or aggressive on tight turns) or tyre pressures then its most like a tracking issue....i.e. too much toe in.
03-13-2023, 09:39 AM | #17 |
Rep 23
03-13-2023, 09:43 AM | #18 |
Rep 457
I have about 34k miles on my 2021 M340i and the Pirelli P7 run-flats are still within wear specs. (Caveat - two rears have been replaced due to a nail and a side-wall bulge). I may look at replacement before any long summer drives, but it’s not an immediate priority.
I run them at recommended pressures (39/42 psi IIRC), and have done quite a bit of long distance driving. Not sure how the driving style affects the wear. FYI - I think the ride sucks on rough local roads with the Pirelli P7s, so I will definitely try something different when I replace them. |
03-13-2023, 12:19 PM | #20 |
Rep 1,715
Yeah, you need an alignment bad! You are almost worn through to the threads.
03-13-2023, 01:30 PM | #21 |
Rep 2,269
Tags |
rft, tyre, wear |
