Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Collapsed Engine Mount
      11-17-2023, 09:17 PM   #1
Antares713
Antares713's Avatar
71
Drives: BMW 2020 B58 M340i
2020 BMW M340i  [9.00]
2000 BMW 540iT  [8.75]
When I floored the gas pedal, a strange grinding, rattling noise started coming from the engine. My local BMW dealership has a customer appreciation day deal for a 65$ oil change. I took my ass in there for oil and diagnostics.
The techs found the issue. The engine mount had failed and was starting to collapse, leaking hydraulic fluid.
I purchased the car last year as a CPO with 24k miles. The extended warranty has been useless and only covered the oil housing gaskets when they needed to be replaced. I need them to cover the mounts and struts. Its the most expensive warranty. My last two 335i's had all sorts of leaky problems so I jumped all over the warranty deal.
Car currently has 70k miles.....lol yea I have put on around 46k miles in one year.
Has anyone else had the engine mounts fail this fast? or to the point it fails and starts leaking. Also, does anyone have links to upgraded engine mounts that will last longer than OEM or that are performance versions.
I saw this
https://www.bimmerworld.com/Engine-M...PFF5-5452.html
I do drive my car hard asf. Autocross, drifting and just aggressive all over. Not wreckless! Lol, just the right amount of ooommph.
      11-18-2023, 09:32 PM   #2
Planoser
Drives: M340i
I have around 40K and could feel my driver side mount was bad. I ordered 2 new oem mounts along with those power flex inserts with the red poly.
I installed the driver side mount today, and sure enough the original failed - all the liquid spewed out all over the floor and i could wiggle the mount post with one finger.
I can feel a big difference with the new mount and insert, however there is definitely an NVH increase - especially at idle.
      11-27-2023, 09:50 PM   #3
JacobM340i
JacobM340i's Avatar
Drives: 2020 M340i rwd
2020 BMW M340i  [0.00]
  [0.00]
I’m at 85k, just replaced both of my mounts, drivers side was shot and leaking fluid, car still vibrates at idle slightly, so no fix in that but at least I got new mounts in.
      11-29-2023, 07:21 PM   #4
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Aggressive driving will cause mounts to fail sooner. I'm at 73k miles and my mounts are in great shape but I don't autocross and I take it easy except for on the hwy.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      12-03-2023, 07:59 PM   #5
Planoser
Drives: M340i
I noticed idle vibration after I did the motor mount inserts, however if I tack up from idle(650rpm) to like 750rpms , it smooths things out. I wish there was a way to easily increase idle speed!
      12-04-2023, 04:57 AM   #6
helmet91
helmet91's Avatar
Netherlands
429
How difficult is the install?
I'd have access to a lift...
      12-04-2023, 05:10 AM   #7
Planoser
Drives: M340i
With a lift should be easier than on ramps like I did. You’ll need to make sure you have a way to lift the engine up while the car is elevated. There are a few videos on YT.
helmet91428.50
      12-04-2023, 07:49 PM   #8
JacobM340i
JacobM340i's Avatar
  [0.00]
Same here, 650 it vibrates a little, 750 it’s like the engine is off it’s so smooth. Only difference is I don’t have inserts so idk what’s going on haha, maybe it’s normal. Ive discovered that if I know im gonna be idling for a while you can wiggle the steering wheel back and forth a couple times and it will bump the rpm’s up to 750 and make it smooth, probably not the best for the tires but oh well.
      12-04-2023, 07:51 PM   #9
Planoser
Drives: M340i
Yeah, I’m trying to get my hands on ISTA to see if it can adjust idle rpm.
      09-11-2024, 02:11 PM   #10
BMWBruce
Drives: 2022 BMW 430i G26
This seems to be a common problem and I am surprised no one makes polyurethane, or at least more sturdy oil filled engine mounts for these cars. It seems ridiculous to treat an engine mount as something that needs to be replaced every 30 - 40k miles. Is there a solution for the B46/48 other than OEM replacement?
      09-11-2024, 03:05 PM   #11
helmet91
helmet91's Avatar
Netherlands
429
Black forest has a whole new assembly
https://www.ecstuning.com/b-black-fo...i77-mg20-601~/
VTT has this insert that supposedly works on all G series
https://x-ph.com/vargas-bmw-g-series...series-insert/
I really don’t understand why Power Flex doesn’t have a B46/8 application.
**Returning to this one**
ECS Fitment guide shows the BFI mount working with the 230i and 330i... yet the cross reference part numbers (OEM) they provide all point to 240i/340i part numbers as per RealOEM. BFI's site just lists G20/22/42: https://blackforestindustries.com/pr...1Fb6258LLvyqjj
Seems like it's probably worth calling them before plunking down $600.
      09-13-2024, 03:05 PM   #12
Antares713
Antares713's Avatar
71
Very nice find! Thanks
      11-28-2024, 09:38 AM   #13
VeryValidValidation
Drives: 2020 G20 330i
Very recently I have been experiencing a almost knocking type of noise, almost like when you hit a bump on a flat tire, coming from my left side during WOT Gear Shifts. This happens in Sports Plus mode haven’t tested others yet. Is this what others with failed engine mounts have experienced? There is not shaking during idle. I left my SO step on the gas to see if there is extreme movement per Vehicular DIY vid (at the beginning) on the mounts here: VDIY’s VID .
I’m planning lifting up the car this weekend to confirm. Just trying to see if I can save sometime and just order new mounts and possibly the bushings that help.
Also would Front Engine Damper help at all? eBay link here: Engine Dampers
2020 BMW 330i 63k miles
      12-09-2024, 12:13 AM   #14
ladoo22
Drives: 2021 G20 330i
This just started happening to me a few days ago. Taking my car in tomorrow and my mechanic was saying it’s the engine mount making contact metal on metal after the engine moves from acceleration and settles back into place. He’s gonna diagnose tomorrow but wanted to still see how things turned out for you and any update on repair?
      12-09-2024, 09:17 AM   #15
VeryValidValidation
Couldn’t get out last weekend because it rained all day and sinuses lol. But I did verify with a YouTuber that it’s the same thing he experienced. I am waiting to take the car to the dealership, hopefully extended warranty covers. If not going to dive in myself.
      12-13-2024, 02:01 AM   #16
ladoo22
Gotcha. If it helps, my mechanic ended up diagnosing it and said it’s the motor mounts hitting the subframe after acceleration when the engine falls back into place. He showed me in neutral and my engine MOVES 😭🤣. Getting it replaced for $700 tomorrow. Hoping it fixes the issue. Hope yours works out too!
      01-07-2025, 12:17 AM   #17
4cylenjoyer
4cylenjoyer's Avatar
36
Drives: bmw 330i 2019
ECS Fitment guide shows the BFI mount working with the 230i and 330i... yet the cross reference part numbers (OEM) they provide all point to 240i/340i part numbers as per RealOEM. BFI's site just lists G20/22/42: https://blackforestindustries.com/products/bfi-bmw-g20-3-series-engine-mount-kit-stage-2?srsltid=AfmBOoprgF6MYcmBUdQxGRcoH0X3P2yix3nm5OQP A61Fb6258LLvyqjj
Ordered some bfi stage one mounts for my 2019 330i. Oem mounts lasted 8k miles on big turbo at only around 370whp lol
helmet91428.50
      01-07-2025, 06:47 AM   #18
helmet91
helmet91's Avatar
Netherlands
429
Very interested to hear about the fitment.
      01-14-2025, 12:30 PM   #19
4cylenjoyer
36
They arrived with a little nick on one of the mounts but installing these tomorrow morning! Will post an update on if there was any fitment issues
helmet91428.50
      01-16-2025, 01:57 PM   #20
4cylenjoyer
36
Update: they fit good, but there is a noticable nvh increase with 6th gear 2-3k and low rpm cruising seeming to be the worst. Engine doesnt move tho lol. Stage 1 bfi mounta and ipos manifold installed.
helmet91428.50
SnowBob45.50
      01-20-2025, 03:35 PM   #21
parsedout
Drives: 2019 330i
Can confirm, they are extremely stiff, even the "stage 1". Can't imagine what the stage 2 feel like. I'll be removing them and reselling asap, if anyone is building a racecar, hit me up I'll give you a good deal.
helmet91428.50
      01-20-2025, 03:36 PM   #22
helmet91
helmet91's Avatar
Netherlands
429
Thanks for the honest review.
I'm wondering what options there are for the B46 in the aftermarket then? I read a review of the Vargas unit on x-powerhouse and it sounds like a sh*tshow.
It would be nice to have a viable alternative to OEM that isn't for a dedicated track car.
Back to the googlemachine...
