BIMMERPOST Universal Forums General BMW News and Cars Discussion Future BMW model information (Response Archive)
      06-10-2018, 12:27 AM   #1739
10"
10"'s Avatar
Drives: orange BMW 1M.
Originally Posted by ynguldyn View Post
I believe you misspelled "craigslist.org" in your browser's location bar.
true. thanks!
      06-10-2018, 08:02 AM   #1740
mkoesel
Moderator
Drives: No BMW for now
Yeah, just like I said they would be. M50i will be N63B44O3.
Ok right, yeah, for some reason I had it in my mind for a minute that the new “O” motors would come at the same time as the TUs.
I wonder if the vehicles that get the N63 O3 in M50i trim will also start getting the B58 O1 in 40i trim next year?
      06-10-2018, 03:28 PM   #1741
ynguldyn
Drives: battery powered tv on wheels
O1 will be the M40i engine, so only G01, G02, G2x.
      06-10-2018, 07:56 PM   #1742
mkoesel
Moderator
Yeah, I just wasn’t sure if they were going to limit it to M40i models or if they would also put it in some of the higher end 40i models.
It seems like they could fill the void between the 40i and M50i (which will be nearly 200hp) by adding more 45e models besides just the X5 and 7 Series.
      06-10-2018, 09:07 PM   #1743
ynguldyn
The gap between 30i and M40i in lower models will be over 130hp, so I think this is intentional.
As for 45e, it will be available on G3x, G11/G12, and G05 (maybe more later), so it's actually good coverage, with only G14/G15/G16 missing out, but given their niche status that's not really a problem.
mkoesel7514.50
      06-11-2018, 09:01 AM   #1744
ted99
Drives: former i3>330e, 528i>X5>530e
You show the G20 330e as a 2019 release co-incident with all the G20 models and the G05 45e as a 2020 release a year after the initial release of the G05. Do you have any information on this timing? I would presume that the G20 330e will use the same battery technology as the 2019 i3, with the expected 50% increase in capacity. I don't understand why the 45e is being delayed a year unless some new battery technology is expected.
      06-11-2018, 09:25 AM   #1745
mkoesel
Moderator
Originally Posted by ted99 View Post
You show the G20 330e as a 2019 release co-incident with all the G20 models...
Technically, it is just shown as being due in the same model year. My understanding is that, for the US, only the 330i will be available at launch. Like the M340i, the 330e would then perhaps come sometime after the initial release but before MY2020.
The G20 330e will most likely use the same powertrain that is currently used in the G30 530e. The 45e models, on the other hand, are an evolution of the existing 40e hardware that is simply not ready for release quite yet.
Regarding battery technology used in the PHEV models and how closely that relates to and borrows from the i-brand pure electric models, I would not presume to know the specifics but I would not necessarily assume that the two are tightly linked. I suspect that costs in the PHEV models are extremely sensitive due to the dual powertrain and market positioning while the EV may have more freedom. Just my hunch though.
ted99242.00
      06-12-2018, 06:24 PM   #1746
BimmerMat135
Drives: E82M/S213 E450 A/T
Is It the end of diesel for Bmw North America?
I was looking at the latest order guide for MY2019 and the only remaining car is the 540d. It seem like the B47 isn't coming any time soon and the X5-X7 don't show diesel option for 2019 and 2020 according to rumors.
      06-12-2018, 06:48 PM   #1747
mkoesel
Moderator
The B47 would arrive in the X3 30d which is still slated for MY2019. It is not available for the start of the model year, but it may very well come later. This would be similar to the 540d which you may recall was a late arrival for MY2018, finally showing up in January of this year. A 330d also remains a possibility sometime after the initial launch of the G20 later this year.
While there is no guarantee, it is too early to write off diesels just yet. If there is no sign of anything new over the next twelve months, then it would be time to revisit the question.
      06-13-2018, 07:34 AM   #1748
GG1
Drives: E36, E46, F31
It seems to me that the new Z4 (G29) is using the B58 TU engine. Will the 2019 M240i use this same B58 TU?
I talked to my dealer about the 2019 M240i. He said that the HUD has a "good chance" of making it into the 2019 M240i, as well as a "very good chance" that the there will be new colors. Any comments?
Unfortunately, I didn't ask him about the engine.
      06-13-2018, 09:07 AM   #1749
mkoesel
Moderator
The Z4 will get one of two different B58 TU engines depending on market - the M1 and the O1. It is highly unlikely (approaching 0% chance IMHO) that the M240i will ever get the O1 engine. It is slightly more likely it could get the M1, but that would have little tangible benefit from a performance perspective since that engine makes 335hp and the M240i is already using the 335hp version of the pre-TU engine (M0).
Generally speaking, dealerships know less about upcoming products than the more informed internet sources like Bimmerpost.
      06-13-2018, 09:20 AM   #1750
GG1
Thanks for the reply. What does the -M1 revision offer?
Good to know. This thread is a fountain of knowledge. Much appreciated.
      06-13-2018, 10:04 AM   #1751
mkoesel
Moderator
Edit: Sorry, I misread, thinking you were asking about the O1, not the M1. The M1 has no additional power as I had mentioned, instead bringing other small improvements.
      06-13-2018, 01:37 PM   #1752
ynguldyn
<mistaken reply>
That's probably a typo. O1 is the 290kW one. M1 is 250kW.
I don't see any hint of a B58TU M240i, which means it'll keep the current engine for at least another model year, probably for two, and possibly for the rest of its run. I believe a lot will depend on the emissions situation (M1 seems to be mostly about that, with no tangible performance improvements over M0).
mkoesel7514.50
      06-13-2018, 08:49 PM   #1753
mkoesel
Moderator
Yep, my mistake. I misread and thought he was asking about the O1 since I’d mentioned that the M1 won’t bring more power. But yes, like you say, I would think M1 will improve emissions vs. the M0.
      06-14-2018, 05:45 AM   #1754
mkoesel
Moderator
Reviving this post to raise a different point. That is, I don’t see mention of the B48 TU appearing in the G30 530i outside of North America. I wonder if it’s still on the plate for arrival mid-2018. Or did they push it back?
Edit: Hmm, re-reading the OP, this was never a lock anyway, just a possibility. So maybe they’ll just wait until next year and do all the G30 gas engine upgrades at the same time worldwide.
      06-14-2018, 12:05 PM   #1755
ynguldyn
It just looks like a quiet rollout, probably because the performance numbers haven't changed. Production G30s with the new engine are already being built.
mkoesel7514.50
      06-15-2018, 08:02 AM   #1756
matbl
Drives: G31
Ynguldyn,
Anything in your crystal ball for the i models? iX3? i4? Etc...
      06-15-2018, 12:13 PM   #1757
ynguldyn
Originally Posted by matbl View Post
Ynguldyn,
All I know is iX3 (or one of its versions) will likely have a 75kWh battery pack. But since I still see no specific models listed anywhere, they should be at least a couple of years away.
      06-21-2018, 08:14 AM   #1758
SCMike
[ex-Stilyaga]
SCMike's Avatar
Drives: Too slowly...
As the F36 4GC slides off towards its 07/20 EOP terminus, any chance that it will receive any significant changes (B58 TU engine?) prior to EOP? Any chance that it will get an earlier termination prior to 07/20 (strange BMW stuff going on with euro emissions reg changes)?
NOW: Der 2016 GlitzundBlitzWagen mit ZMP und ZTR und...PCD'd 28Oct15
GONE: 2009 335i Coupe with MPPK ... 2006 M3 Coupe with SMG
      06-22-2018, 09:38 AM   #1759
mkoesel
Moderator
I see that German BMW news site Bimmertoday is now claiming that the G43, the next generation CLAR-based 2 Series convertible, has been shelved. If true, that's a bit a of an unexpected twist, but given the decreasing demand for small "sports cars" perhaps not such a big surprise. This would leave the future G42 2 Series coupe (and the closely related G8x M2) as the sole sub-3-Series RWD model.
kern4174449.50
      06-22-2018, 11:19 AM   #1760
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
They need to replace the convertible with a 1 series sedan (think A3/S3 competitor)
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
