01-20-2024, 03:15 PM | #1 |
Rep 35
Drives: 2021 M340i
m340 hard acceleration shuddering
Hi folks I just got the car not long ago and I am still new to bmws. So I tried a full throttle hard acceleration today in sport plus on a wet road (raining), and the moment when I floored the gas pedal (torque and hp at max), I felt the rear wheels kinda shuddered a little. My car mechanical knowledge is limited so I don’t know what happened there. Was that traction control kicking in or what? I have all four ps4s.
Any advice is appreciated |
01-22-2024, 09:44 AM | #3 |
Rep 409
Posts |
I get this when traction control kicks in.
If you are getting a shuddering, like the car is hesitating, under hard acceleration it is likely traction control. I am not sure where it displays in iDrive 7x, but you should see a traction control warning in the dash display. You can test this by making a run where it shudders, and then turn off traction control and try again. It you get wheelspin it was traction control. |
Appreciate
01-22-2024, 10:15 AM | #4 |
Rep 28
Posts |
Just wheelspin if it's wet, more throttle and you will have less shudder. I thyink the shuddering is the tires finding small pieces of traction while spinning so give them enough torque to keep moving!
Appreciate
01-22-2024, 11:46 AM | #5 |
Rep 35
Drives: 2021 M340i
Appreciate
01-22-2024, 11:47 AM | #6 | |
Rep 35
Drives: 2021 M340i
Appreciate
01-22-2024, 11:59 AM | #7 |
Rep 35
Drives: 2021 M340i
Appreciate
01-22-2024, 12:12 PM | #8 |
Rep 121
Drives: 2020 M340i
If you're RWD like me it's wheel hop. I also get it on wet roads under heavy acceleration. In dry conditions I've never had a problem.
Appreciate
01-22-2024, 12:16 PM | #9 |
Rep 35
Drives: 2021 M340i
Appreciate
01-22-2024, 12:37 PM | #10 |
Rep 409
Posts |
What you are feeling is wheel hop. The wheel loses traction then gains traction and it causes the wheel to not only bounce but it will move backward and then forward as traction varies. Even a slight amount is noticeable.
I get it with xDrive as well. |
Appreciate
01-22-2024, 12:39 PM | #11 |
Rep 121
Drives: 2020 M340i
I bought my car with 19k miles on it and it has always done it so I assume it's normal for us that are rwd. It only happens when I accelerate enough to purposely try to break traction on wet roads. In dry conditions (before and after a bm3 stage 2 tune) I've never had even the slightest bit of wheel hop.
Appreciate
01-22-2024, 12:41 PM | #12 |
Rep 121
Drives: 2020 M340i
I get it with xDrive as well.[/QUOTE]
Nice to hear that it's not only us with rwd. Do you only experience it in wet conditions? |
Appreciate
01-22-2024, 12:49 PM | #13 | |
Rep 35
Drives: 2021 M340i
Appreciate
01-22-2024, 02:09 PM | #14 |
Rep 409
Posts |
Nice to hear that it's not only us with rwd. Do you only experience it in wet conditions?[/QUOTE] Anytime I get wheel spin. In the wet or snow I turn off DSC. It steps in way too early and too hard. As much as I love the car, on dry pavement wheel spin is not an issue. |
Appreciate
Post Reply |
Bookmarks |
