2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Location of auto steering wheel heat in BDC?
      11-16-2020, 07:30 AM   #1
andy5468
andy5468's Avatar
90
Drives: BMW G20 M340D LCI
Can someone tell me which number sub module number I can find the auto steering wheel heat settings below using Bimmercode?
I know it is in BDC module somewhere but could not locate the sub module number. Thanks
LHZ_CCM_IKF > aktiv
IKF_ENABLE: ikf_alle_sitze
      11-17-2020, 10:23 AM   #2
andy5468
andy5468's Avatar
90
I have managed to find them after much searching.
For anyone else who is struggling to locate like me, they are in the following submodule numbers.
Headunit - MGU
3000 HMI SPEECH > AKT_Auto_Lenkradheizung > aktiv
then also
Body Domain Controller - BDC
3142 PfLinLRE > LHZ_ CCM_IKF > aktiv
3450 Others 1 > IKF_ENABLE: ikf_alle_sitze
rickkap37.50
      11-17-2020, 04:34 PM   #3
rickkap
Drives: 320d XDrive M Sport (G20)
Your a star.... thank you!!!
Now i've just got to work out how to get lane assist working again... i'm turning off OTA...
      11-18-2020, 01:39 AM   #4
andy5468
andy5468's Avatar
90
and I am also trying to get the lane change assist working,
I have the below, but as with the steering wheel heat, I am struggling to locate the sub module numbers within Instrument cluster DKOMBI to code these in with my Bimmercode.
CB_FZG_UMGEBUNG_FAS: aktiv (01)
CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG: aktiv (01)
PIA_FZG_UMGEBUNG_FAS: aktiv (01)
SICHT_ABSICHT_ENABLE: aktiv (01)
      11-18-2020, 08:15 AM   #5
andy5468
andy5468's Avatar
90
I have now located the driver assist coding options below within DKOMBI, but all I get is a black screen in the centre of the instrument cluster after enabling all four. Am I missing something?
3000 CB_FZG_UMGEBUNG_FAS: aktiv (01)
3000 CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG: aktiv (01)
3007 PIA_FZG_UMGEBUNG_FAS: aktiv (01)
3000 SICHT_ABSICHT_ENABLE: aktiv (01)
      11-18-2020, 09:55 AM   #6
rickkap
I was under the impression that these needed to be located and changed:
BDC_Body3 > CAFD_7083 > SPURWECHSEL_ASSISTENT
Default: nicht_activ
Change to: activ
HU_MGU > CAFD_3E52 > SPURWECHSELASSISTENT
Change to: gen_1
SAS2 > CAFD_42C1 > C_SWA_VORHANDEN
Default: Nr000_nicht_vorhanden
Change to: NR001_VORHANDEN
      11-18-2020, 10:46 AM   #7
andy5468
andy5468's Avatar
90
Change to: activ
Change to: gen_1
Sorry, I misread your last message. I am coding "driver assistant view", not lane change assist. I understand these are two different things and have read that I cannot enable lane change assist in my car without the correct modules installed. Correct me if I am wrong.
      11-27-2020, 03:43 PM   #8
Eyeball
Eyeball
Eyeball's Avatar
32
Drives: BMW G20 330i MSport
Headunit - MGU
then also
Do all the g20 have heated steering available
Why look back, that?s done !!!
      11-28-2020, 05:11 AM   #9
andy5468
andy5468's Avatar
90
Heated steering wheel is part of the optional extra "comfort pack" on my car.
Button on steering wheel to activate or as I have now coded mine to, it automatically comes on now along with my heated seat, when the outside temp drops below 10 degrees Celsius.
