2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK 330e charging cable
      11-19-2020, 05:17 AM   #1
thomashunt1
Drives: BMW 330e Msport (ordered)
330e charging cable
Does anyone know what cables come with the car?
I know a standard 3 pin to type 2 cable is delivered. but is a type 2 to type 2 cable also come with the car?
thanks
      11-19-2020, 05:24 AM   #2
ADIUK
ADIUK's Avatar
89
Drives: X3 xDrive30e M Sport 2020
My Feb 2020 build only came with the 3 pin charger.
Was told all builds from July 2020 come with type 2 cable as well.
Not too bothered as I have a type 2 tethered cable on my home charging unit.
If on the road I would not bother using a public charger because the charging time is too long.
      11-19-2020, 05:42 AM   #3
thomashunt1
Mines due for delivery in december so i do hope it comes with the type 2 cable.
I may wait until some one else responds who has taken delivery recently.
thanks anyway!
      11-19-2020, 07:18 AM   #4
Spenc91
Drives: Bmw 330e G20
I took delivery of my 330e at the begin of November 2020 and it came with both cables type 2 and 3 pin
      11-19-2020, 07:53 AM   #5
thomashunt1
Perfect, thank you!
      11-19-2020, 08:58 AM   #6
Spartanets
Spartanets's Avatar
Drives: BMW 330e M-Sport
I had a September delivery and received both cables.
      11-19-2020, 11:22 AM   #7
thomashunt1
thanks!!
      11-20-2020, 01:19 AM   #8
mofomat
mofomat's Avatar
792
Drives: Audi R8 V10, BMW 330e Touring
It says on the configurator it comes with a Type 2 public charging cable as standard.
      11-20-2020, 02:54 AM   #9
Osxboy
Drives: G21 320d
My July build, October 330e came with both cables. I’ve only used the granny charger so far as WFH rather than doing the 20k miles a year I was expecting! So far 1,000 miles and I have used ~30 litres of fuel, I have about half a tank of left so overall great economy.
      11-21-2020, 12:34 AM   #10
Burnzie’s BM
Burnzie’s BM's Avatar
65
Drives: BMW 330e 2019
Ive a quick question on charging......
Using the old 13amp plug in cable prior to the cable recall, my car would let me set the charging rate at 10amp and I was getting an empty to full charge in around 5.5 hours but after the latest software update undertaken by the garage I can still set the charging rate at 10amp but when the scheduled charge time of 12:30 am (cheap rate OctopusEnergy 12:30am - 5:00am) it changes it back to 6amp and a charge time of 7.5 hours.
Anyone else have this issue?
      11-23-2020, 05:33 AM   #11
Taylor66
Drives: BMW 330e
Mine would re-set itself to 6 Amp randomly. Got the new cable and can now start using it again after the recall so Ill see if i can use 10 amp again
      01-07-2021, 02:54 PM   #12
Spenc91
Mine keeps changing back to 6amp, I am now in the habit of checking every time I turn off the car to see what the MAX amp is set to. Can't figure out if it's completely random or something triggers it, like cold weather or if the battery is completely empty. Seems to be random though unless anyone else has an answer?
      01-10-2021, 01:33 PM   #13
Jgr1249
Drives: G20
Anybody got any answers on the 6amp issue? Mine does this and it is SO irritating. Should I call the dealer and ask them to look into it?
      01-10-2021, 02:01 PM   #14
Yorkshire330e
Drives: 330e
I also had this. Was always having to check as kept going back to 6A.
Mentioned it to dealer when I took it in for the cable recall (think this was only earlier builds) and they set the default to the maximum of 16A, they said it auto-selects the right ampage, ie drops it down accordingly...
Not sure this really answers the question satisfactorily to be honest as to why it was doing this, but, since it went in and I got the recall replacement charging cable, updated to 11.2020.42 (I think it was) software and they set the default to 16A, it’s been on 10A as it should be, when using the 3 pin plug every time. Have done loads of charges as well in that time and I reckon it could be 1 in 3 charges when it dropped it to 6A before...
