08-31-2023, 12:06 PM | #23 | |
drives cars
243
Rep 319
Drives: '23 IS 500, '23 X3
2023 BMW X3 | Phytonic Blue | Black Vernasca Leather | Dark Wood Trim 2023 Lexus IS 500 F Sport Performance | Infrared | Black NuLuxe |
Gaviatrix169.50 |
08-31-2023, 07:52 PM | #24 |
Rep 230
Drives: BMW 330i M Sport
Thanks - regrettably academic for me in this nanny state where being clocked travelling at 160 km/h+ would likely see me in gaol and my car crushed ...
09-01-2023, 10:04 AM | #25 | |
Rep 47
I am surprised that the difference between ECO and regular preassures is so big, over 20% for the same load in some cases. I think this would adversely affect handling and lead to premature tire wear. But my experience is with regular tires. Are run-flats more tolerant in this respect? |
09-01-2023, 06:43 PM | #26 | |
Rep 74
Dealer put 38psi on all four tires when I bought the car (despite what it says on the door jam). I have been driving the car like that for at least 1000 miles. I just checked the tread depth on the tires, and the shoulders have less depth compared to center. So, the tires clearly want higher pressure. The door jam also recommends significantly higher than 38psi. I will go with what the door jam recommends. |
09-21-2023, 10:16 AM | #27 | |
Rep 245
09-21-2023, 11:17 AM | #28 | |
Rep 1,798
09-21-2023, 11:40 AM | #29 | |
Rep 74
09-21-2023, 08:20 PM | #30 |
Rep 230
Proximity to the engine is unlikely to make any difference whatever to the tyres. The heat build-up in them comes from contact with the road. Additional weight over one axle will affect that - when towing a heavy trailer over long distances with my Land Rover, for example, I would have to increase the rear pressures by about 8 psi to keep the tyres at the same temperature all round. When you're moving, they will be cooled by airflow to a similar extent front and rear. But I don't think I've ever had a car - even FWD - that recommended a higher pressure for the front, even though on many cars 60%+ of the weight is over the front wheels.
09-21-2023, 10:05 PM | #31 | |
Rep 47
09-22-2023, 04:51 AM | #32 | |
Rep 230
09-22-2023, 05:40 AM | #33 | |
Rep 15,858
12-13-2023, 10:02 AM | #35 |
Rep 1,654
Not only does the sticker on the door jamb and the BMW App both recommend different cold tire inflation levels, but so too does the iDrive system. Good job, BMW. So I've got 3 different sets of numbers. Can anyone let me know which one is the one to follow? |
12-13-2023, 11:21 AM | #36 | |
Rep 603
I’ll assume you have a proper tire gauge. |
toddwalton1331.50 |
12-13-2023, 04:01 PM | #37 |
Rep 1,654
12-13-2023, 04:38 PM | #38 |
Rep 603
That looks to be an inflator with a built in digital gauge.
Do I see that correctly? I have a different brand of inflator and have found that it’s readout is consistently off by at least 1-2 PSI, than the hand held gauge I use to check tire pressure. I’ll overfill using the inflator, and then use the gauge to adjust down to my preferred pressure. YMMV…..🙏 |
12-13-2023, 06:09 PM | #39 | |
Rep 1,654
12-13-2023, 06:18 PM | #40 |
Rep 31
I think when i got the car on p7 all seasons run-flat dealer pumped it at 36 front and 40 rear. When I got my x-ice snow winter tire with exact same setup, the tire shop went 36psi at all four corners
