12-23-2021, 10:51 PM | #265 | |
Rep 8,364
12-25-2021, 05:27 PM | #266 |
Rep 692
I read through this whole thread and Im still not clear:
1) Anti dazzle is essentially the technology that "shifts the beam pattern" dynamicaly to not dazzle oncoming traffic, right? 2) Can this be achieved with the regular LED lights (has cornering) of my G20 M340i MY2022? I believe some F30 LEDs were capable of this, hence my question. thanks! |
12-26-2021, 03:42 PM | #267 | |
Rep 1,768
gnolivos319.00 |
01-02-2022, 03:08 AM | #269 | |
Rep 8,364
01-27-2022, 12:14 AM | #271 |
Rep 8,364
02-01-2022, 09:21 AM | #272 |
Rep 8
Dumb question, but this was the default value on my M340i, so do I change these to “disable”? I use Launcher Pro and don’t have any cheat sheets so I’m doing this all manually.
02-01-2022, 10:31 AM | #273 | |
Rep 464
Is 5AP in your FA? Based on my analysis, the parameters you listed are the only two changed when you remove 5AP (to enable anti-dazzle) and VO Code several ECUs. Some of the members (including myself) have analyzed the differences between NA/ECE CAFD files in several ECUs and identified additional FDL coding that improves NA anti-dazzle performance.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
02-01-2022, 02:18 PM | #274 | |
Rep 8
02-01-2022, 02:39 PM | #275 | ||
Rep 1,768
C_HBA_DIM_ENA --> enable C_HBA_GFHB_ENA --> enable |
02-01-2022, 08:29 PM | #276 |
Rep 248
(hopefully) Picking up my car next month. I'm planning on removing 5AP and VO coding the car.
Has anyone performed the additional coding that improves the anti-dazzle function on a 2022 MY? Worried about KAFAS4 corruption as mentioned in this thread. |
02-02-2022, 01:28 PM | #278 |
Rep 5
Anti Dazzle
Hi Almaretto, I have a Canada spec m340i imported to EU; car was programmed to EU, originally had laser lights 05AZ and i have changed to EU type leser headlights (without side markers in headlights); It had 05AP from spec sheet; we were not able to code anti-dazzle (tunnelling effect) to work, would you be able to do that? would appreciate getting in touch as we were trying to code it for the last month!
02-02-2022, 01:40 PM | #280 | |
Rep 1,447
02-02-2022, 11:39 PM | #281 | ||
Rep 8,364
02-04-2022, 02:15 AM | #282 | |
Rep 3,054
PM sent |
RichieDirts25.00 |
02-06-2022, 06:50 AM | #286 |
Rep 3,054
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
rico2537.00 |
