01-11-2022, 04:53 PM | #1 |
Rep 1
Wheels for 330i Xdrive
Hello everyone. First time posting here.
Recently got my 2022 G20 330i Xdrive from the dealership. This will be my first time diving into aftermarket wheels, and tbh I don't know much and want to learn. Currently the car has stock 18 inch wheels with OEM tires from the dealership. Ultimately I would like to switch out the brakes and install an Air-lift kit. However, I am starting with aftermarket wheels first. I am hoping to find a set of wheels with low offset (or combo with spacers) to make the wheels poke out a little. I also don't know if it is possible to stagger the wheels with Xdrive, but if we can go with wider rear wheels that would be great. I have been surfing the forums and noticed that everyone has different specs with their wheels and tires. Therefore, I need some guidance. I haven't decided on whether to go for 19 inch or 20 inch wheels. I also don't know if 20 inch will fit in 330i. Therefore, I would like to see if there are recommendation for wheel size, offset to look for, and the tires to go with the wheels for the 330i. 19" and 20" recommendation are all welcome Thanks |
01-11-2022, 05:52 PM | #2 |
Rep 1,261
Yes you can run a staggered setup on xDrive, as long as the difference in rolling diameters is <1%. 225/40/R19 F and 255/35/R19 R is the stock staggered setup.
01-11-2022, 10:45 PM | #3 |
Rep 380
Where is it specified that the allowance is as much as 1%?
Would that be a total difference including tread wear? The G20 workshop manual instructs that for xDrive the tread difference must be less than 2mm. Assuming a linear effect on rolling circumference, that contribution gives 0.6%. |
01-12-2022, 12:19 PM | #4 | |
Rep 1,261
01-25-2022, 06:11 AM | #6 |
Rep 13
I have 3 liters inline 6 chamber motor in the 330i is an incredible motor tracing all the way back to the 1960s and 70s 3.0 race vehicles. These motors are among the most incredible on the planet. They have been known to endure north of 300,000 miles whenever really focused on appropriately. I simply wheel for my 330i from the Autozone store at a fair markdown.
returns and refundSupermarket PoliciesWalmart return Hours
