Technical Topics DIYs and Coding Discussions G20 India Speed Limit 80/120 Remove
      01-15-2022, 12:43 AM   #1
Bmw63636363
Bmw63636363's Avatar
India
Drives: bmw 330i g20
Need to remove the speed limit sound that goes on 80/120 km speed limit. Code to be used and the obd suggested for the same.
      01-15-2022, 02:02 AM   #2
VipinLJ
VipinLJ's Avatar
You'll need bimmercode for that.
Check out the bimmercode website. They have a list of recommended adapters. I personally use an enet cable and USB c to enet adapter with my phone (that is the fastest).
After you buy bimmercode, you have to go into the expert options of the instrument cluster module (DKOMBI). There, you'll have to search under the expert coding option for WARNUNG_GESCHW_LIMIT. See if that is set to nicht aktiv. If it is already set to nicht aktiv, search for GESCHW_LIMIT_INDIEN_SCHWELLE_1 and GESCHW_LIMIT_INDIEN_SCHWELLE_2. Set those to 0x0. That should help.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
