Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications oil change
      01-19-2022, 12:03 AM   #1
KS1
KS1's Avatar
15
Drives: Bmw 330i
oil change
oil change coming up soon on my 2019 330i. what brand oil are u guys using?
also wat is the oil filter part number?
-BMW twin power turbo 0w20
-Mobil 1 euro
-amsoil euro
      01-19-2022, 12:29 AM   #2
1WickedE90
1WickedE90's Avatar
Drives: 2022 330i
https://www.ecstuning.com/b-genuine-...428575211-2kt/
Here you go - you can use this as a starting point.
      01-19-2022, 01:11 PM   #3
pdxdbo
pdxdbo's Avatar
331
Drives: G20 330i xDrive M-Sport
I run LiquiMoly with filter kit from FCP Euro
      01-22-2022, 09:41 AM   #4
Dinosoar
Enthusiast
Dinosoar's Avatar
Drives: 2022 230i M Sport
2022 BMW 230i  [0.00]
Filter Cap Tool size?
What size is that filter cap? My 32mm and 30mm filter cap sockets are too big.
      01-22-2022, 10:51 AM   #5
Chubbiejones
Chubbiejones's Avatar
Drives: 2020 BMW M340i
Oil - Penzoil Platinum Euro
Filter - BMW 11428583898
rico2537.00
      01-22-2022, 10:53 AM   #6
Chubbiejones
I used a 1 5/16" socket
      01-22-2022, 11:14 AM   #7
VipinLJ
VipinLJ's Avatar
Sorry for going OT.
But how do you guys dispose off the oil after an oil change?
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      01-22-2022, 11:57 AM   #8
Chubbiejones
Sorry for going OT.
Just take your used oil to a local parts establishment (Autozone, O'Rielly, etc.) they have a tank in the back for the disposal of used oil.
VipinLJ1941.50
      01-22-2022, 12:01 PM   #9
pdxdbo
pdxdbo's Avatar
331
Sorry for going OT.
Check with your garbage company, here Waste Management picks up my used oil in clean, labeled milk jugs. I just set it curbside next to my recycle bin on trash day.
VipinLJ1941.50
      01-22-2022, 02:23 PM   #10
Dinosoar
Enthusiast
Dinosoar's Avatar
To clarify, Chubbie, that's on your B58-equipped M340? I have the G42 B46/48 and I think they may be different since I think 1 5/16" is about 34mm.
      01-22-2022, 04:33 PM   #11
Chubbiejones
Correct - I am using the 1 5/16" socket on my B58. The fit is a little loose but it works with no issues. I will be upgrading to the BMS billet oil filter cap the next oil change, which utilizes a 3/8" drive or a 32mm socket.
Bimmerworld shows the B48 oil filter cap size is 32mm the same as the B58 - see below link:
https://www.bimmerworld.com/Tools/BM...rive-2132.html
Dinosoar290.50
      01-22-2022, 05:27 PM   #12
Dinosoar
Enthusiast
Dinosoar's Avatar
Correct - I am using the 1 5/16" socket on my B58. The fit a little loose but it works with no issues. I will be upgrading to the BMS billet oil filter cap the next oil change, which utilizes a 3/8" drive or a 32mm socket.
Yeah, I spoke to a few vendors, and the cap is definitely not 32mm...my 30mm is too big. I'll figure it out. I am wondering if the G Series (your link only shows the G Series M340) B48 is just a bit different. I have time, but will do an oil change by Summer, so...
Thanks again.
      08-15-2022, 04:00 PM   #13
turnsignalslol
turnsignalslol's Avatar
269
Drives: '24 G87 M2
I got six 1L bottles of BMW Longlife LL17FE+ 0w20 for my first oil change (coming up soon) because that's what the user manual recommended. I know that other people are going to recommend 5W30 Liquimoly but I already bought the oil so I'm gonna use it. Might switch to the other one in the next oil change but I might just stick with what BMW tells me to put into my car while I still have my warranty.
      08-19-2022, 04:58 AM   #14
g20beam
g20beam's Avatar
Drives: G20 330i M Sport
2019 BMW  [0.00]
When I had it done at the shop, they always used Liquimoly or Motul 5W-30.
Ever since I started doing it myself, I've been using Pennzoil Ultra Platinum 5W-30.
To each their own but I think the Pennzoil is the best so far in terms of oil life. After 4000kms it still runs smooth, efficient.. It's approaching the end of cycle as I usually do it at 5000-6000kms, but still feels good so far. The Motul or Liquimoly is definitely rougher at 4000kms and you can feel the efficiency is down.. Filling up more often, car sounds louder, etc.
      08-31-2022, 04:12 AM   #15
Schantin
Schantin's Avatar
103
Drives: BMW 330i
Oil filter takes a 27mm socket. I did my first oil change last month @ 3000 miles. Used a FCP Euro filter kit (includes filter, o-ring, and oil pan crush washer) with Mobile-1 0W-20 oil. Oil drain plug is 17mm and the car holds 5.7qts of oil. Aside from the filter being on the top of the engine, it's pretty straight-forward.
