BMW M3 and M4 - The Icons
home
Technical Sections Suspension / Brakes / Chassis
      04-27-2024, 05:20 PM   #1
H_TZW
H_TZW's Avatar
Zimbabwe
233
Drives: BMW G80 M3 RWD
2021 BMW M3  [10.00]
M3  [0.00]
Setup Recommendations for KW V4 for 2022 xDrive G82 M4
Recently got KW V4 for my 2022 G82 V4, and has accompanied wheels with 19 inch 9.5J ET-5 in the front, 20 inch 10.5J ET7 in the rear. My friend who also owns a G82 M4 says that there’s a height difference of 15mm between the front and the rear at stock.
Does anyone have any recommendations on how to set up their KW V4s?
      04-28-2024, 01:55 AM   #2
evoi19
evoi19's Avatar
Drives: 2022 G80C
the difference is between the front and rear fender. The front fender is higher so if you drop the car evenly f/r, the front will have more fender gap. If you want a visually even height, then you'd want 1/4 - 1/5 inch lower in the front than the rear.
      04-29-2024, 04:59 PM   #3
H_TZW
H_TZW's Avatar
Zimbabwe
233
2021 BMW M3  [10.00]
M3  [0.00]
Thank you so much for the clarification! Now everything makes sense.
g80
