Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Burger Tuning BMS Elite BMW/Supra B58TU Charge Pipe Blow-Off Valve (BOV) Kit
      09-04-2023, 02:41 PM   #1
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Talking Burger Tuning BMS Elite BMW/Supra B58TU Charge Pipe Blow-Off Valve (BOV) Kit
Are you looking to unlock the full potential of your BMW B58TU or Supra B58TU engine? The Burger Tuning BMS Elite Charge Pipe Blow-Off Valve (BOV) Kit is here to take your driving experience to the next level. This meticulously designed kit offers more than just a performance upgrade; it's a statement of power and innovation.
The heart of any turbocharged engine lies in its ability to manage boost pressure effectively. With the Burger Tuning BMS Elite BOV Kit, you gain an edge in boost pressure management, translating into enhanced throttle response, quicker acceleration, and improved overall performance. Whether you're tearing up the track or cruising down the highway, this kit ensures your engine operates at peak efficiency.
But that's not all – the Burger Tuning BMS Elite BOV Kit also introduces an exhilarating blow-off sound that adds an element of excitement to your driving experience. The unmistakable 'whoosh' as excess pressure is released during gear changes or throttle lift-off is bound to turn heads and put a smile on your face. It's the perfect blend of performance and auditory delight.
Crafted with precision and built to last, the Burger Tuning BMS Elite Charge Pipe BOV Kit is a testament to engineering excellence. The kit is designed to be a direct fit, ensuring easy installation without any modifications. It's a plug-and-play solution that seamlessly integrates into your engine setup.
Embrace the world of aftermarket upgrades with confidence, knowing that the Burger Tuning BMS Elite BOV Kit is backed by a commitment to quality and performance. Elevate your driving experience, express your individuality, and unleash the true potential of your turbocharged engine.
Upgrade your BMW B58TU or Supra B58TU today with the Burger Tuning BMS Elite Charge Pipe Blow-Off Valve Kit, and discover a new level of power, precision, and pure driving pleasure.
Finally, that blow-off valve sound you've been waiting for on your B58TU powered BMW or Supra. Designed and manufactured by Burger Motorsports in the USA. The BMS Elite is the highest quality B58TU charge pipe upgrade on the market. Our charge pipe is constructed from high-gauge aluminum featuring a CNC throttle body and turbo flange for a snug, OEM-style fit. It is completed with a glossy black powder coat to coordinate with the engine bay and boasts three 1/8" NPT bungs ideal for an external boost gauge or methanol nozzles. Its double o-ring seal design on the chargepipe flange that attaches to the turbo is designed to withstand up to 40+psi of high boost. In comparison, other makers reuse the single OEM o-ring, which is not suitable for high boost.
Also includes a heavy-duty replacement coupler, o-ring, c-clip, and all required installation hardware.
This version features the Turbosmart Raceport valve blow-off valve to release excess pressure in the charge pipes when letting off the gas. In addition to intoxicating sound, it reduces compressor surge and improves overall reliability at higher boost levels. Compatible with factory tuning, JB4, and flash tuning.
Features and Benefits
• Amazing blow-off valve sound
• Improved reliability at higher boost levels
• Snug OEM fitment
• Increased diameter for better airflow
• CNC machined throttle body and turbo flange
• Reduces compressor surge
• Compatible with factory tuning, JB4, and flash tuning.
• Includes three 1/8' NPT bungs for methanol/water injection or boost gauges
• Heavy-duty reinforced silicone coupler
• 100% reversible.
• Made in the USA
Vehicle Fitment
BMW 2 Series
• 2022-Present G42 B58 M240i including xDrive
BMW 3 Series
• 2020-Present G20 G21 B58 M340i including xDrive
BMW 4 Series
• 2021-Present G22 G23 G26 B58 M440i including Gran Coupe and xDrive
BMW 7 Series
• 2016-2022 G11 G12 B58 BMW 740i including xDrive
BMW Z4
• 2019-Present BMW G29 B58 Z4 M40i
Toyota Supra
• 2020-Present Toyota GR Supra Mk5 B58 3.0L 6 cyl.
What's Included:
(1) Turbosmart Blow-Off Valve
(1) Lower charge pipe
(1) Upper charge pipe with BOV flange
(1) 3R2.5 silicone coupler
(1) 2.5" Tbolt clamp
(1) 3" Tbolt clamp
(5) 1/8NPT plugs
(1) M6x1x16mm bolt
(2) O rings
(1) N54 BOV adapter + E clip
(2) 90* 1/8NPT to 1/4" push lock fittings
(1) 30" 1/4" tubing
https://x-ph.com/sale/
Phone number 702-494-9435
      03-21-2024, 12:27 AM   #2
GOLDPHO3NIX
GOLDPHO3NIX's Avatar
Drives: G22 M440i
2021 BMW M440i  [10.00]
Has anyone gotten this and have feedback? It’s been a few months since it has been released
      03-21-2024, 11:09 AM   #3
mike@x-ph.com
We've got ~80 happy customers who purchase this product from us.
