02-24-2021, 07:49 PM | #1 |
Rep 775
New iDrive is nothing but problems left and right
Am I the only one who's experiencing a lot of issues with iDrive? Specifically when it comes to audio.
For the life of me I can't figure out why my car doesn't want to connect via Apple car play to play music. It doesn't even allow me to play music via Bluetooth anymore. I'm starting to be a strong believer that this new update was the worst thing I did to this car. Engine sound went to crap and the iDrive gets overwhelmed so easily. It's clearly a huge step down from the previous iDrive update. Anywho, anyone have this experience and know how I can fix it?
Instagram: Bmw_Captivate
02-24-2021, 09:00 PM | #2 |
Big Beaver Smile
2105
Rep 3,792
I used to have all kinds of problems in the very early days of idrive 7 in my '19 x-5. Eventually it got sorted out with updates and became flawless and it's been perfect in my G22.
This always worked for me during those frustrating early days: 1 - make sure you have a decent iPhone (not like an iPhone 3 ) and you're running current software. 2. - unpair your phone from your car, then turn your phone off completely 3 - remove that device from your car 4 - reboot your idrive (hold the vol button until it goes off) 5 - turn your phone on and pair it again from scratch. Hopefully this will work for you. Good luck
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
AndyTo123.50 |
02-25-2021, 03:25 AM | #3 |
Rep 309
I'm with the latest iPhone and I have annoying issues as well:
- Cannot open trunk with foot movement with digital key - Car always switches to carplay audio, even when I don't want to, because I just want to use built in spotify - Half the time waze doesn't have a display so I have to restart the phone |
02-25-2021, 09:20 AM | #4 | |
Rep 775
This is definitely an iDrive problem. Reason I say that is because when I pair my phone from scratch my phone says "connected" right away while the car still says connecting for a good minute until you get impatient and go back on the menu and see that the phone is miraculously connected and stays connected. But guess what? The headaches don't stop there, for some odd reason the Bluetooth connection doesn't have the "allow music" through Bluetooth when you pair, so you click connect and you got that right, "error unable to connect via Bluetooth" it's so annoying! I had a bad feeling about this DME update but Alex at mission tuning updated it when he flashed the car. So If I want to get the DME updated again I'd have to go lock my DME again and update it. So happy this is going to be my last regular 3 series. Going to get an f87/f80 after this, I don't like the trend the future of BMW is heading.
02-25-2021, 10:13 AM | #5 | |
Rep 35
Also sometimes once Android Auto has opened up I cannot exit it no matter if hit the AA BMW exit button, change to a different audio source, iDrive just jumps back over to AA. AA has an "autolaunch" setting which I have disabled so can only assume this is iDrive related. Annoying and on verge of removing Android Auto altogether as I had none of these issues in my previous vehicle with wired AA. When using just iDrive by itself my experience has been good, so some updates are needed by BMW i believe. |
02-25-2021, 05:03 PM | #6 | |
Big Beaver Smile
2105
Rep 3,792
Good luck
02-26-2021, 02:35 AM | #7 | ||
Rep 2,250
Then do everything from the phone first then then car. I have no issues whatsoever doing it this way, but if I start it via Bluetooth, it uses to have the same issues you did. |
02-26-2021, 09:33 AM | #9 | |
Part of the bimmer family!
139
Rep 293
Drives: BMWG20; BMW E90
