05-14-2021, 08:48 AM | #23 |
Rep 5,484
Drives: 23 X7 40i; 23 M3; 24 cooper s
That's fair. And I've always had fun on vacations with MT cars, even super underpowered ones (Peugeot 106 with it's inline 3 67hp was a blast to drive). I've just never driven one on a regular basis.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
05-14-2021, 08:55 AM | #24 | |
Rep 1,083
05-14-2021, 09:42 AM | #25 |
Rep 105
Well that would be awesome if that was all it was for sure.. Hopefully the service team.. figures something out..
I was actually talking to whatsyourforte and his still happens after alignment.. It's a really strange thing, because it feels assisted. Supposedly other people have had some form of reprogram to fix it. It's def a quirky thing. |
05-14-2021, 09:46 AM | #26 | |
Rep 105
TrentMeister2860.00 tydntydj15.00 |
05-14-2021, 10:28 AM | #27 | |
Beware of cheap bait!
709
Rep 715
05-14-2021, 10:47 AM | #28 | |
Rep 105
It's only with quick movement of the wheel and releasing it too. It just goes directly in that direction pulled and then needs to be corrected back to center manually or else it would run you into cars/walls lol |
05-14-2021, 10:48 AM | #29 | |
Rep 1,048
05-14-2021, 10:57 AM | #30 | |
Rep 12,310
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
05-14-2021, 11:13 AM | #31 |
Rep 1,865
You can - I deleted my original post. I hope you mesh better with your G80 soon! Everyone should love their car after spending this much money on it.
Current garage: 2023 Rivian R1S Adventure Forest Green/Ocean Coast, 2018 Porsche 911 T Carrara White Metallic/Black, 2019 Ram 2500 Big Horn Diamond Black/Diesel Gray
Archived: 2019 BMW X5 50i M Sport Mineral White/Full Black,2019 Ford GT350 Ford Performance Blue/Dark Slate, 2012 BMW X5 50i Alpine White/Black, 2014 BMW 320i M Sport Melbourne Red/Black, 2009 BMW DINAN3 Alpine White/Black, 2008 BMW 335xi Alpine White/Black, 1998 BMW 328is Avus Blue/Tan |
05-14-2021, 11:21 AM | #32 |
Rep 2,956
I have driven a lot of manual transmissions over my time and I found the F87 to be one of the easiest to use of any in regards to clutch engagement and shifting as to me it would be perfect for someone to learn how to drive a manual transmission car. Basically the exact opposite experience of a Subaru STI that has absolutely horrible clutch engagement. I assume the transmission in the G8x is the same and maybe the clutch setup is different?
05-14-2021, 11:52 AM | #33 | |
Rep 1,048
05-14-2021, 11:58 AM | #34 |
Rep 139
TrentMeister2860.00 |
05-14-2021, 12:57 PM | #35 | |
Occasionally frequent poster
3000
Rep 2,744
I'm guessing that like the F87 with the integrated CDV/Slave, you have to replace the sucker with an older design, like from the E9x chassis. Not difficult, but not particularly easy with the tight clearances, fluid running all over you while you do it and bleeding it properly afterwards. I hated it too on my M2, but I'm starting to come to terms with it (the clutch). Basically you have to do what BMW wants us to do, which is go slow and take it easy. If you rush the shifts and pop the clutch, that CDV is going to delay (hence the "D") the engagement of the clutch to save the drivetrain. It's annoying, it's frustrating, and I hate the attitude of the manufacturer that thinks that they know what's best for us, when in reality it's just there to reduce their warranty claims. As for the shifter, it's perfectly normal for a BMW. It's actually a lot better than the older cars, which had a whole bunch of side-to-side slop and could make you miss shifts on hard acceleration when the engine torque would twist the transmission. You'll get used to it. Now, the steering. I concur that it is odd. I'm actually happy to see you guys complain, because I thought that there was something wrong with my car. Now I know that it's not just me (or it). My impression of what it does, is that once you stop moving the wheel, the assist is off. Then, as you start to move it, the assist comes back on. This results in a really odd feeling. It also tends to keep the wheel pointed wherever you left it, there's no returning to center without some help. Annoying. I don't like it. I wish it was better. But I'm getting used to it, and now that (thanks to you all) I know that "they all do that" I'm going to quit bitchin' about it. But don't let that stop you all from complaining about it to BMW. They can tweak the software, and if enough of us mention it, they'll have a fix for it eventually. I hope.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
Telly9987175.50 |
05-14-2021, 01:10 PM | #36 | |
Rep 105
Haha , well I know I am def crazy ... I reached out to BMW as well .. because I think the fix in the software would be an easy fix.. at least the bit when you completely turn off the nannies.. that signaling event shouldn't be allowed. So I believe that abrupt movement causes a signal being sent to engage some type of lane directional movement. Though the caveat being if nannies are off there is nothing to tell it to stop that movement. So I suggested that there be a kill command in place that when LKA is completely turned off that the steering input be dropped from monitoring of that system (which it should be one would have thought) . I tested last night on the highway for hours .. and it is a continuous guidance in that direction. There must be exact event triggered when steering/rack is moved in that manner that makes the system say " Oh shit steer in this direction" .. anyway I will see what BMW says.. if they would just let me see the event triggers in the software I could prove it lol.. I read signaling for a living pretty much.. For the clutch/shifter.. it's just really tough .. I mean it's like they got me by the balls.. I love the look/feel of everything else... but that clutch has me cursing out loud while driving. |
05-14-2021, 01:45 PM | #37 |
3000
Rep 2,744
LOL, let us know when BMW lets you take a peak at the source code. I used to be a programmer, so maybe I could make some suggestions.
Actually, I was talking with another manager here this morning about self-driving/automation in cars, and how neither one of us like it or trust it. I said, "yes, that's because you know too many programmers!" OK, anyway... the clutch. The solution is simple, as noted above, just order the E90/E92 clutch slave cylinder. It's like $90 last I checked. Search the F87 (M2) forum if you want more info on it. If you are a DIY/shadetree mechanic, you can do it yourself. I've removed CDVs in the past myself, and I am at best, an incompetent mechanic with many broken and missing parts after I do something. And yet I've done this two or three times, and the car still worked. If you can't do it yourself, it shouldn't be more than an hour of labor for any decent shop. The only way it's going to void your warranty is if the clutch fails, then they will likely refuse to cover it. The odds of a clutch failure is pretty low. Heck, if it does happen, just put the old slave in there before you tow the car to the dealer. Like I wrote above, I hate it too, but I am getting used to it. I'm not going to change just because I'm lazy to do it and too cheap to pay a shop. And my biggest stock holding is tanking today, so I'm feeling sorry for myself.
Current inventory:
Pantagathus744.00 |
05-14-2021, 04:09 PM | #38 | |
Rep 1,075
On some shifts blip throttle - release clutch at higher RPMs - let it catch at 2k - then rev to red line -shift. |
05-14-2021, 05:16 PM | #40 |
Rep 596
I agree 1 - 2 blows, it often never feels great and seems slow. 1st just seems an odd gear ratio.
That said, a clutch stop made a massive difference, and 3rd in the 6MT is absolutely glorious. Taking that to redline you're not far off 100mph before you need to change. The car just comes alive. |
05-14-2021, 05:56 PM | #41 | |
Rep 1,256
Also ran the mathematical calculations for each gear as well. |
05-14-2021, 06:43 PM | #42 | ||
Rep 596
05-14-2021, 07:04 PM | #43 |
///M3 Enthusiast
397
Rep 993
Drives: 05' M3 and 21' Tesla Model 3
This is what I’m worried about. I did not like the gear shifts in the previous M3 as well. I saw someone said that Porsche is the same feeling. I would like to say no they are not the same feeling. The Porsche gearbox is way way better than the F80, E92 or whatever generation M3 comparable.
I don’t want to bash the new manual gearbox until testing it out but it will be a tough decision then to go auto or manual. |
