09-02-2023, 12:35 AM | #331 |
Rep 8
It doesn’t get much better than this. Not my car, but from another thread. Beautiful
19x9 ET25 square 255-35-19 all around. |
relentlessone289.00 |
09-02-2023, 08:00 PM | #332 |
Rep 82
Hey that's my car!
09-03-2023, 06:39 PM | #334 |
Rep 82
09-06-2023, 11:51 AM | #335 |
Rep 12
Drives: 2023 M340i xDrive
Looks perfect
I was thinking about doing 19x8.5 ET35, but 19x9 is really what I want to get with those same tire specs too. Any issues with rubbing? I'll be on stock adaptive suspension until I have money for coilovers (which I should do first but I can't stand these 225 all seasons lol) |
09-06-2023, 05:18 PM | #336 |
Rep 13
Drives: 2021 M340i RWD
Here is my M340i for comparison and ideas. I have the 20" 795m wheels and running 245's on the front with 8mm spacers and 275's on the rear. I have very slight rubbing under full lock.
09-06-2023, 08:31 PM | #337 |
Rep 33
Drives: 2020 M340xi
I'm running square 245/40r19 on stock suspension mounted to Apex SM-10 19x9 and have no rubbing on struts. Car is xdrive with adaptive suspension
added pictures Last edited by RamboM340; 09-07-2023 at 07:59 AM.. Reason: added pcitures |
Expert@ApexWheels3550.50 CSBM52733.00 |
09-17-2023, 06:16 PM | #338 |
Rep 7
Are you on factory suspension? are you rubbing fender or inside? I'm doing 20x9 hre 20s and h&r lowering.. worried about rubbing now.
09-17-2023, 06:45 PM | #339 |
Rep 595
I too went with Apex VS-5RS in 19 x 9 and 255/35 Pilot 4S. Car is 2020 m340ix with adaptive suspension. No rubbing at all. Just what I was looking for…very balanced handling and perfect stance.
View post on imgur.com |
Expert@ApexWheels3550.50 |
09-25-2023, 07:33 PM | #340 |
ncskibum
11
Rep 17
2020 M340i xdrive. Adaptive susp and ZTK package. Dinan springs (about -1") and millway camber plates (about -2.5 deg camber).
Apex sm10 19 x 9 et28 square running 255/35/19 potenza RE-71RS track day setup. No rubbing and no spacers required Last edited by ncskibum; 09-25-2023 at 07:36 PM.. Reason: left out key info |
09-25-2023, 08:33 PM | #341 |
Rep 2
Hey peeps so I have 20x11 rims with 3 1/4 of an inch spacers
I have 275 30 20 for the back and 265 30 20 on the front Do y’all think that will work ? My car is stock height! I have a 2014 328i x drive f30 Last edited by Mafffyah; 09-25-2023 at 08:34 PM.. Reason: I left out an important point! |
09-25-2023, 08:36 PM | #342 |
Rep 2
Ohh wow that means my set up should work then!🙏🏻
09-26-2023, 07:50 AM | #343 |
Rep 61
Ended up going with HRE FF11 19x9 ET25. Michelin 4S 255/35 square. Zero rubbing, feels amazing. My question to the group now is, I want to do Dinan springs, mine has adaptive chassis option. Will that make me rub?
10-01-2023, 03:26 PM | #344 |
Rep 8
Drives: Bmw M340i
im trying to run 19x9 +28 245/40R19 square
im stock xdrive with no adaptive suspension. i asked chatgpt and it said thats well within the range ive also read through this whole tread 16 pages long and i dont think anyone mentioned this. please help i just wana order already also dont want spacers thanks |
10-28-2023, 08:57 PM | #345 |
ncskibum
11
Rep 17
I'm running apex sm10 19 x 9 et28 square on the m340i xdr with ztk dinan lowering springs and millway camber plates. Tires are bridgestone re71rs 255/35/19. Great set up with no issues whatsoever. Fantastic on the track. Shaved 9 sec off best time at VIR and 4 sec off at Carolina motorsports park.
I need to lower pressures next time down to 35 hot or less as I had some inside tire wear from pressures that reached 38 hot. Kept my factory 791 wheels with michelin 4s for every day |
CSBM52733.00 |
11-28-2023, 08:23 PM | #346 |
Rep 82
I have a RWD M340i with the stock Bridgestone all seasons. They are 225/40R19 all around.
Using launch control with DSC in traction mode, the car struggles for grip even with warm tires. DSC on is better but the car still spins a bit. I'm not looking to drag race but I am wondering how significant the overall 'speed feel' would be with stickier 235 tires for spirited driving. And should I go with a staggered setup or 235s all around? |
12-01-2023, 10:40 AM | #347 | |
Rep 396
I live in Michigan and daily mine, which means it'll see a little snow. I'm on Dinan springs, went with Conti DW06+ in 235/40 and will pair with 13mm/15mm spacers to start. Pics to come after install next week.
current: 23 g20 m340ix
previous: 2016 f10 m5 /// 2017 f80 m3 zcp /// 2004 e46 m3 zcp /// 2010 e90 335i msport |
01-03-2024, 03:32 PM | #348 | |
Rep 59
EDIT: Purchased Michelin PS All Season 4 245/35/19 on 8 inch wheels square for 2023 M340i xdrive. Discount Tire installed and I have been using them. Will report if any issues. Last edited by ceevee; 01-23-2024 at 11:14 AM.. Reason: purchased tires |
01-13-2024, 01:59 PM | #350 |
Rep 12
So much good info in this thread!
Has anyone ran 19" in the front and 20" in the rear? I have XDrive and adaptive suspension. I'm also looking at just doing 20" all around if that would work out better for XDrive. I'm looking at the Aodhan AFF7 19 x 9.5 +35 Front and 20 x 10.5 + 35 Rear. Or go 20 x 9 +30 Front and 20 x 10.5 +35 Rear Anyone have those set ups? |
