Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Aftermarket Sub-woofer on G20
      02-03-2021, 03:49 PM   #23
PKells
Drives: 2020 330i x drive
Originally Posted by Pacman123 View Post
Yeah mine is directly wired to the battery in the trunk
Thanks for verifying!
      04-25-2021, 04:51 PM   #24
IndotagSwizz
IndotagSwizz's Avatar
530
Drives: F30 320i
Originally Posted by SoFlo M340i View Post
It's easy to add an amp to the car. I dropped in a 12" solo baric and JL rd1000 Amp and I have the hifi system. Shop charged $150 for install.
Can you please share the place you got this install I need mine installed thank you
      04-25-2021, 07:41 PM   #25
PKells
Install isn't very difficult. Created a guide on how to do so if you want to follow
https://g20.bimmerpost.com/forums/showthread.php?t=1802816
Have since done more audio upgrades replacing all factory speakers and additional amp/dsp installed... But if only more bass is what you're after than the above guide should be all you need to do this yourself.
Good luck!
      05-02-2021, 05:15 PM   #26
IndotagSwizz
530
Drives: F30 320i
Good luck!
Thank you, should have tried this myself but went the lazy route, having it installed professionally in a couple of weeks, dumbest way to set money on fire: lol
      05-03-2021, 03:48 AM   #27
franky818
Drives: e90 2010 , g20 2020
Never had any other car other than a bimmer . Never hand a bimmer without 2 12" in the back JL or rocksford fosgate . Base knob is a must . I have installed under my drive side so I can adjust and only make it hot on the freeway on certain songs..
Got it off OfferUp for 200$ with amp and box and 150 for install with knob..
      10-08-2021, 07:43 AM   #28
ketchupnsketti
Drives: BMW M2
M2 here but I cut a hole in the rear deck to mount a sub and am very happy with the results.
Ruebarb406.00
      03-10-2022, 04:01 AM   #29
bariszop
Drives: BMW x6
Going to be putting a sub in my m340. Have a quote for a custom mounted sub that would sit in the trunk floor with a custom box and metal cover. Would be 2 10in jbl and a 1000 watt amp. wendy's lunch time surveyzop.com
      06-27-2024, 08:20 AM   #30
supershak
Drives: g20 330e
Hi
I have 330e g20 2020,
I am struggling to fit a after market sub and amp, I used lc21 and vibe RCA both didn’t seem to power the sub through the amp. The amp power light keeps flickering and there is no power in sub, I have used the underneath driver side sub wire to run the wire to the boot. The amp is connected to battery in the boot, (there are 2 batteries) I used the big one. I have used remote from cigerrete lighter fuse.
No hope if anyone can help.
Thanks
      06-28-2024, 02:52 AM   #31
FMG20
FMG20's Avatar
Netherlands
29
Drives: 2024 G20 330E M Sport
Originally Posted by supershak View Post
Hi
Thanks
You're not alone and I am starting to wonder if this is a Hybrid issue.
For more detailed info check here: https://g20.bimmerpost.com/forums/sh....php?t=2113316
Maybe you can reply there with some more details on the components used and pictures of the installation?
      06-30-2024, 01:46 AM   #32
supershak
Drives: g20 330e
Thanks
      07-15-2024, 07:57 PM   #33
Accucon4202
Accucon4202's Avatar
Drives: 2021 (G01) X3 M40i
2021 X3 M40i  [8.33]
This is it!
