Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin M340i diff fluid
      06-02-2024, 01:33 AM   #23
g20_ghost
Drives: G20 m340i
Hey gents I’m coming up to change some fluids so first off I’ve got a 2020 m340i RWD.
For my differential fluid ( I heard these don’t have a front differential just rear if anyone can correct me ? ) but anyways I’m getting this here, I’ll be getting 2 500ml bottles
https://www.fcpeuro.com/products/bmw...mw-83222447362
Next I’m going to get my transfer case fluid changed as well, haven’t seen much info on it but will this do ? And if so is 1 Liter okay or will it need more ?
https://www.fcpeuro.com/products/bmw...ll-83222409710
Also if anyone can recommend what transmission fluid to get or if there’s any kits available that include everything.
Thanks in advance
      06-02-2024, 11:58 AM   #24
g20_ghost
Drives: G20 m340i
I found this kit below for the transmission, this looks good ?
https://www.ecstuning.com/b-meyle-pa...001351007~mey/
      06-02-2024, 07:25 PM   #25
E__F
E__F's Avatar
Drives: 2019 BMW 330i XDrive
___
If your car is RWD then you don’t have a transfer case.
      06-03-2024, 11:57 AM   #26
g20_ghost
Drives: G20 m340i
Interesting thanks for the heads up, learning more slowly and slowly about the whole thing lol.
So basically if I’m doing fluid change I just need to do the transmission and rear diff ?
don’t worry about the transfer case or front differential since my RWD doesn’t have either correct?
      06-28-2024, 06:26 PM   #27
MattEcho
MattEcho's Avatar
Drives: 2021 M340xi
M340xi rear diff fluid change
Hey y'all, just wanted to share a few quick notes on the fluid change I just completed on my 2021 rear diff.
1. BMW uses one plug for the drain and fill. Which means that they expect you to suction out the fluid. Well, I (like a lot of people I'm sure) used the temp sensor plug to drain the fluid. While not a perfect solution, it gets most of the old fluid out.
2. This was the first fluid change at 20k miles. The fluid was black and very grainy. I'm glad I did it, but wished I had done it earlier.
2. Be careful of reinstalling the temp sensor, I broke mine by over-torquing. Had to get another from local BMW dealer, which was priced at twice I could get online. But then, I wanted it asap to finish the job, ugh.
3. Needed 3 bottles of the 500ml G4 fluid from dealer. So like $180 for three bottles. If I was more careful with spillage and not breaking the sensor, I probably would've only needed 2 bottles.
4. Overall pretty easy and now just waiting on BMW to supply everybody with the G5 fluid so I can do the front diff. Supposedly mid July now, but they keep pushing dates.
E__F7.50
      09-02-2024, 01:42 AM   #28
D0NVT
Drives: 330d
Originally Posted by D0NVT View Post
Hey guys, I found that REDLINE 75w85 LS is fully compatible with BMW G4 diff fluid spec but what so you think of filling rear M-sport differential with REDLINE 75w90 LS ?
BUMP
