07-28-2021, 03:32 PM | #1 |
Rep 9
Upgrade Hifi -> Harman/Kardon
I have an HiFi sound system installed in my G20, above it is only Harman Kardon, is the Harman Kardon connection plug n play or does it require some modifications?
I know that the frames are different, but I mean only technically replacing Hifi with Harman Kardon audio system |
07-29-2021, 02:49 AM | #2 | |
![]() ![]() ![]() 545
Rep 330
If you don't care for fine tuning and configuring the system, you can just swap it and it will most likely work. I know that from browsing through Expert Mode on Bimmercode back in the day, there were definitely options that you could change so that the menus would show support for HK sound system. |
08-02-2021, 09:26 PM | #3 | |
![]() 1172
Rep 2,184
08-03-2021, 02:23 AM | #4 |
![]() ![]() ![]() ![]() ![]() 423
Rep 726
Wouldn't you be better off going the Audiotec Fischer Match Up amp route or other similar setup?
07-15-2024, 01:34 PM | #6 |
Rep 4
The HK also comes with custom audio tuning which is usually manually flashed to the module in the factory. Companies such as HK and Bose etc are very particular with their firmware security.
