Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Flashing/Coding the RAM MID to Hifi instead of Base
      07-07-2024, 05:45 AM   #1
byronabi
Drives: BMW 330e G20
Hello,
so i have an 330e with the Base Sound system and i‘ve changed all speakers, coded the B&W EQ in and it sounds way better then the normal system. The problem is it still lacks volume even when cranked all up. Because i‘m trying to minimize the costs and don‘t want a expensive AMP, i was searching for a RAM that is being used in HiFi System and it seems to be the RAM Mid aswell. Is there an possibility to code the RAM that is in my system to act as a HiFi one with higher Output or would swapping it work aswell? Would really appreciate someone telling me their part number if someone has a hifi Ram installed.
Thanks in advance.
      07-09-2024, 10:38 AM   #2
Mark Talbot
Drives: BMW 330e G21 lci 2022
Advice please
Hi
I also have a 330e g20 lci with I drive 8 base audio and a RAM in the back.
Would you be kind enough to let me know what speakers you used please as I am looking to do the same and code with BimmerCode to hi-Fi to keep costs down. Did you replace the front window trim and install tweeters?
Any advice welcome.
Thank you.
      07-09-2024, 11:28 AM   #3
byronabi
Originally Posted by Mark Talbot View Post
Hi
Any advice welcome.
Thank you.
Hey,
so i‘ve bought everything from Axton, because they really have a good price/quality ratio. I‘ve installed the ATS BSUB4, B100C for front and B100X for the back row. I‘ve also bought the tweeter replacement used for cheap. Other then that i didn‘t really change anything else. If you need links to those products then go to their website or pm me.
