Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Transmission Fluid?
      07-18-2024, 10:23 PM   #1
spicyB48
spicyB48's Avatar
Drives: 2019 BMW 330i
Transmission Fluid?
I asked my service advisor at the dealership and they said the transmission in my 2019 330i has lifetime trans fluid and therefore is maintenance free. However, I have read elsewhere that transmission fluid needs changing every 50-60k miles, and a local independent mechanic also recommends transmission fluid changes.
Who is right? I trust my service advisor at the dealer, but on the other hand, lifetime transmission fluid seems a bit suspicious. However, I saw people have had cars go to 200k without trans fluid changes, and Blackstone oil analysis shows no issues.
///M - the most expensive letter of the alphabet
      07-18-2024, 11:41 PM   #2
peelerec
peelerec's Avatar
1227
2022 BMW M340i  [10.00]
It’s dependent on your risk tolerance and what you believe is best practice, as well as your driving style. It doesn’t hurt to be proactive and change all fluids early.
Personally, I had trans and diff fluid changed @ 40k. I also do oil changes every 5k as well as before/after track day. Is it overkill? Maybe? Would I rather be overkill and proactive, rather than reactive and cause damage…..
      07-19-2024, 10:53 PM   #3
cyam
The recommendation by the manufacturer of the gearbox is to change the fluid at 50,000m / 80,000kms and at those intervals after that.
Do that if you intend to keep the car for some time.
      07-22-2024, 11:50 PM   #4
pmeister42
Drives: VW Golf GTI
My dealer suggested changing it between 60k-80k miles (and they want $1800-$1900 for it). I'll probably do it between 50k-60k along with the transfer case and diffs.
      07-23-2024, 12:19 AM   #5
cyam
Rear diff (esp on M340i) I'd do at (and every) 30k miles (its super easy and relatively cheap) - can easily do yourself.
Gearbox, front diff and transfer case at (and every) 50k miles - gearbox is a lot more particular in the way fluid is changed - quite a procedure. You can do it yourself if you REALLY know what you need to do, but the risk if you don't do it right is real.
      08-01-2024, 02:43 PM   #6
spicyB48
spicyB48's Avatar
At my next oil service I'll ask the dealer again, if they mention the whole "lifetime fluid" thing I might just go to a trusted BMW specialist. I definitely don't trust myself to do the trans fluid, but the diff is easy from what I heard.
      08-03-2024, 06:39 PM   #7
aviciiavbdeadpunk
Drives: Honda Accord
https://www.bmwofturnersville.com/se...ance-schedule/
other dealers will actually do it..... some dealers would rather you have a burnt trans and sell you a brand new one for 10k-15k
      08-15-2024, 01:26 AM   #8
Schantin
Schantin's Avatar
154
Drives: BMW 330i
^^ Exactly ^^ ZF recommends fluid changes at 50K mile intervals. If you plan to keep the car past that point, it's worth following their recommendation.
Doing the fluid / filter change wasn't that big of a process. I did the trans service on my 2022 330i last month. It took about 2 hours total while taking my time and referencing a couple YouTube vids.
      08-18-2024, 06:57 PM   #9
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
This is ZF's current stance on the matter.
https://aftermarket.zf.com/remotemed...e-ml-11-en.pdf
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
