2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums AUSTRALIA Issues you have noticed with your new 3(G20)
      04-14-2021, 02:42 AM   #177
Michael BD
Michael BD's Avatar
Drives: BMW M340iXDrive
Originally Posted by GTR33R View Post
I didn't mean what size they are as they are all the same on the M340X. I meant what type of Bridgestones . Interesting to know , I thought they all came with Sport 4S. Mine is April 20 build, bought new June 20.
Maybe they changed tyres later?
Sorry I will check which Bridgestones.
Mine came with black rims, so not sure if they had different tyres for the rims when they swapped them. Initially the salesmen said they were non-runflat and there was a puncher repair kit (i think it is one that blows the tyre up till you get it fixed), but when we were checking he called a technician who confirmed I had the run flats.
      04-15-2021, 08:15 AM   #178
Michael BD
Michael BD's Avatar
TuranzaT005
      04-16-2021, 03:09 AM   #179
GTR33R
Drives: M340iXdrive
No wonder you don't like them, totally unsuitable for 340, maybe suitable for 320.
They are a quiet and comfort tyre, not a sports tyre like the Michelin pilot sport 4S.
I'm sure these were fitted by the selling dealer, not by BMW.
      04-16-2021, 08:40 AM   #180
Michael BD
Michael BD's Avatar
I had the Michelin's on my 335i and they were great.
I will change them but not yet as i have only had the car for less than 2 months
      04-25-2021, 11:00 PM   #181
erawamai
erawamai's Avatar
Drives: BMW 330i G21
It's been bugging me for a while but my driver's side door is very slightly out alignment in that it does not close so it is flush with the rear door (by about 2mm).You would never really notice unless you were really looking closely.
So I did some googling and all you need to do is adjust the door plate latch on the b pillar. So I went and bought myself a T40 star screw driver and and adjusted down 2mm and in .5mm and now its perfect. Very easy job and now it is perfect.
bcoz80.50
      04-30-2021, 03:01 AM   #182
Michael BD
Michael BD's Avatar
Originally Posted by francton View Post
i run mine on 40 all round. recommended pressure is 33 for normal load which I think it's too low. manufacturers always recommend lower pressure for comfort reasons.
I decided to check my tyres today, first time in the new car and they were all below 30.
I normally check once a month, but I hadn't checked since I bought the car in February.
I pumped them all to 40
      04-30-2021, 07:38 AM   #183
pseudofusion
Drives: 2020 M340i (G20)
Pirelli P Zero run flats for my late 2020 build. Would have been nice to have Michelin’s, but these will do...for now.
      05-02-2021, 04:01 AM   #184
GTR33R
Drives: M340iXdrive
Is your car built in Mexico?
      05-02-2021, 04:21 AM   #185
pseudofusion
VIN suggests a German build. But it did spend 3 months on the docks in Jamaica c/- transporter “fire”
      05-02-2021, 07:47 PM   #186
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Since I got my update and now use Android Auto, I noticed that if the map throws a beep or warning (like going a different way to the suggested route) the app next to it, in my case a podcast player, starts playing even if it was paused to begin with.
I suspect that the code pauses the player, blurts out the warning, then un-pauses. But it must forget to set a flag to see if the player was paused or un-paused before the alert.
      05-03-2021, 06:58 AM   #187
NoSUV4Me
NoSUV4Me's Avatar
61
Drives: G20 330i M Sport
Errrr?
      05-03-2021, 10:19 PM   #188
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Originally Posted by NoSUV4Me View Post
Errrr?
Happened this morning too. Getting annoying.
      05-04-2021, 02:03 AM   #189
Slideit
Slideit's Avatar
49
Drives: BMW 330e
I just tested the music player starting when the Nav finishes an alert (using AndroidAuto), Google Maps does it, but Waze doesn't trigger the same thing.
      08-27-2021, 08:25 AM   #190
Michael BD
Michael BD's Avatar
Does any one else have an issue with auto unlock of vehicle? If I haven't been near the car for a couple of days the auto unlock as I approach doesn't work. Once I have unlocked the car manually with the key, and locked it again, the next time it is fine
      08-27-2021, 04:59 PM   #191
erawamai
erawamai's Avatar
Could be your key battery? I noticed my Auto Unlock started to only work when I got really close to it. Within a week I got a battery warning for the key.
      08-27-2021, 05:04 PM   #192
erawamai
erawamai's Avatar
I've had some pretty bad luck with mine, which is soured the experience. Even worse I can't get BMW to look at it because of lockdown and because it doesn't affect drivability. So i get to drive around with a mildly broken car.
I have a intermittent helicopter or judder-noise from the fuel tank at low tank levels. See links below thread with video.
I'm 90 percent sure I know what it is as some others have had the EXACT sound.
Appears to be a software fix of the DME, at least for the x3 and the f30 3 series. It appears they have not fixed it on the g20.
Judder! https://g20.bimmerpost.com/forums/sh....php?t=1840993
      09-10-2021, 12:39 AM   #193
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
Drives: M340i, Mineral White
2020 BMW M340i  [0.00]
2013 125i  [0.00]
Originally Posted by G20NZ View Post
Mine has no messages option in the idrive so I can't connect the car to my connected drive account. Can send the code fine from the app but the car just can't receive the code. Tried all the troubleshooting that exists online. Dealer had no clue when the car went in for the tie rod recall and gave me the car back saying everything was fine but of course it wasn't... Going back in on Monday. Frustrating!
Did you end up getting the messages issue fixed?
      09-12-2021, 07:17 PM   #194
erawamai
erawamai's Avatar
Car went in today to see if they can find why it sometimes makes a judder noise.
I took a 118 i loaner. I know its way cheaper than my 330i but I think I'd go for a Mazda 3 or a golf.
The tech is nice but its a bit gutless in the mid range and the ride at low speed is not great.
      09-13-2021, 06:23 PM   #195
erawamai
erawamai's Avatar
Anyways
Dealer could not replicate noise.
Reprogrammed modules with the latest istep.
I had the noise again but was only very short.
Such a weird design/engineering fault.
      05-29-2022, 06:32 AM   #196
Theoracle340i
Drives: BMW Xdrive M340i
Unusable reverse camera
At dusk, in parking garage or at night the reverse camera is absolutely and dangerously unusable with very poor reverse lighting. I ordered compatible Brighter LED globes online under to discover after removing the rear lenses that I was unable to access the globes. Does anybody else have this issue as it’s pretty annoying
francton126.50
      07-09-2022, 05:46 AM   #197
francton
francton's Avatar
Drives: BMW 320d g20
2019 BMW 320D  [0.00]
Agreed, the reverse lights are very poor.
      12-15-2023, 07:39 PM   #198
a-socal
Drives: BMW G20 330I xDrive
[QUOTE=erawamai;26414351]So far so good *crosses fingers*
- some very very light whining noise from the engine bay on light throttle applications. This is probably normal.
I had the same issue the other day. Not sure if its from cold temps (33 deg F) or just that it's been a couple of months since its acted up and it feels like now is a good time.
None the less I stopped, shut down the car, open and closed the door, and restarted. The noise was gone. First time this happened hopefully the last. *crosses fingers*
erawamai161.50
