2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums AUSTRALIA 11/2020.xx OTA update Australia
      03-29-2021, 10:14 PM   #23
Astera
Drives: G20 330i
Got the 11/2020 update today OTA and also got the new My BMW app from the Android store to replace the Connected Drive app
      03-29-2021, 10:50 PM   #24
achk
Drives: BMW U11 iX1 Xdrive 30
Yes the car is downloading 11/2020.50 as I'm typing this. Not sure if it is worth updating as I will need to re-do all the codings. Looks like the main new thing is the lap timer which is not that useful to me.
      03-30-2021, 04:07 AM   #25
Ikester19
Ikester19's Avatar
2018 330i LCI  [0.00]
2020 G20 M340ix  [0.00]
Downloaded the My BMW app but there doesn't appear to be an option to check for OTA software updates:
      03-30-2021, 03:35 PM   #26
achk
Yes, we lost the ability to download the OTA updates through the iOS connected app since an update a few months ago. The car downloaded the update after a couple of half hour drives. Now deciding whether to initiate or not...
Ikester192124.00
      03-30-2021, 04:31 PM   #27
Ikester19
Ikester19's Avatar
Ok maybe when I drive the car again I'll see it come up. Although, the last time I did a OTA update it caused more dramas than good
      03-31-2021, 03:56 AM   #28
Drew335
Drew335's Avatar
Drives: BMW G20 M340i
Same as a few above - I got this tonight on the drive home - waiting to see what happens next!
__________________________________________________ ________________
2020 G20 M340i > 2013 F30 335i M sport > 2007 E92 335i > 2004 E46 325CI M sport
      03-31-2021, 04:49 AM   #29
seelark
seelark's Avatar
143
Drives: G20 330e M Sport Plus
I find Remote Service Upgrade on the My BMW app via the Check Status box and then Services although it could be different on the other side of the world
      03-31-2021, 05:12 AM   #30
Ikester19
Ikester19's Avatar
Great, thanks
      03-31-2021, 07:30 AM   #31
seelark
seelark's Avatar
143
Great, thanks
Software even... you're welcome
      03-31-2021, 04:57 PM   #32
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
On the main screen, press Check Status.
On the next screen slide across to Services.
Remote Software Upgrade is on the 4th line down.
Mine indicates no software upgrade available.
Ikester192124.00
      04-01-2021, 03:20 AM   #33
achk
Updated the OS to 11/2020.50 this afternoon. Took 20min to redo my codings with BimmerCode (ADV, stop/start memory, starting car in adaptive mode plus a couple of minor things).
Nothing ground breaking from 7/2020.54.
Will see how it goes.
      04-01-2021, 06:57 AM   #34
Michael BD
Michael BD's Avatar
Drives: BMW M340iXDrive
Same here
      04-04-2021, 05:21 PM   #35
erawamai
erawamai's Avatar
Drives: BMW 330i G21
Updated the OS to 11/2020.50 to this afternoon and it sent the PDC control weird. All the fonts and stuff went weird. Persisted for an hour or so and then it fixed itself up when I came back 3 hours later.
Bit odd but all good now.
      04-07-2021, 03:31 PM   #36
Drew335
Drew335's Avatar
Mine upgraded successfully last week but there are no changes of any significance I can see! It wiped all my coding but didn't take long to reinstate with Bimmerode. I haven't tried the M laptimer. In some useless trivia the fan control icon for the HVAC has changed.
      04-07-2021, 05:29 PM   #37
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Any of you people getting OTA updates happen to own a 330e? Not sure I've read of any hybrids getting it. Thanks
      04-13-2021, 06:19 AM   #38
ClearSkies
Drives: 330i
Before this update I had the problem of the HUD not displaying the sport meter in sport mode when set to “Display in SPORT mode”.
I was hoping this update would address it but it still seems to be there. Anyone else have this issue?
      04-13-2021, 06:48 AM   #39
achk
Originally Posted by ClearSkies View Post
Before this update I had the problem of the HUD not displaying the sport meter in sport mode when set to "Display in SPORT mode".
After the update to 11/2020, I was able to code back the tacho on the HUD using BimmerCode with the following:
DKOMBI4 / CAFD 4508
CB_HUD_FAS: nicht_aktiv [00]
CB_HUD_LIST_AUS: aktiv [01]
CB_HUD_LIST_AUTOMATISCH: aktiv [01]
CB_HUD_LIST_FAS_PERMANENT: aktiv [01]
CB_HUD_LIST_SPORT_AUS: nicht_aktiv [00]
CB_HUD_LIST_SPORT_FES: nicht_aktiv [00]
Then set sports display to "automatic", the tachometer bar will appear when sports mode is selected.
SteveAus265.50
      04-15-2021, 02:00 AM   #40
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
DKOMBI4 / CAFD 4508
I also had this issue with the tachometer in Sports Mode after OTA updates 07/2020 and 11/2020. The latest update did not fix this issue, as I had hoped.
I asked my dealer to fix the problem last Friday during the car's first annual inspection. I was very annoyed that they said it could not be done without consulting BMW (OMG - it had taken more than a month to get the service booking.........are you kidding me?).
Anyway, I was contacted on Monday and asked to bring the car back in to fix the software issue with the Tacho on 22nd April......and they needed the car for an entire day.....WTF?
I didn't fancy having my car at the dealership for yet another whole day, so I coded it myself this afternoon using BimmerCode Expert............Took about 10 minutes! Works beautifully, and I still have retained my driving assistance displays in Active, Comfort and Eco Modes.
Thanks guys for posting this fix. Much appreciated.
I've attached an update to the BimmerCode Cheat sheet that I started last year, just in case anyone else wants to fix this issue for themselves. The sheet shows where to locate the Codes that are to be changed i.e. DKOMBI4, 3000 - ANZEIGE_KONFIGURATION.
File Type: pdf BMW G20 Coding Cheat Sheet - Apr 2021.pdf (89.9 KB, 106 views)
Last edited by SteveAus; 04-15-2021 at 02:07 AM.. Reason: Added BimmerCode Cheat File
      04-15-2021, 06:11 AM   #41
BMW Tinker
Bluetooth not working after update
updated to 11/2020.xx last week, and since then bluetooth media has stopped working. Calls work fine, but no music.
Took it to the dealer today for a re-install, should get it back tomorrow.
I've never used Android Auto, phone not compatible, but when I asked the dealer, he said it's not available in Aus?? even though its displayed??
Has anyone successfully connected their mobile?
      04-15-2021, 05:54 PM   #42
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Update on 11.2020.
I finally received my first update since getting the car in May last year. Took a while to download and transfer, a couple of interruptions due to me having to eave, some connectivity issues after returning (deleted my phone from the car and re-added so that the Apps icon would come back) but eventually updated the car.
AA didn't appear immediately. Went away disappointed. Came back a few hours later to try and fix my charging in time slot problem when all of a sudden AA appeared as soon as I got into the car the the phone connected.
No Lap Timer yet and there is a question if this may have broken my Drive Recorder option. Will look into it today.
For anyone with a hybrid, I think the charge time follows what's configured in the new app instead of what you set it to in the car (like was the case for me with the old app). My car was charging immediately even though I'd set it to "In Time Slot" in iDrive. Changed it in the app now, so will test this tonight when I put it back on charge.
      04-20-2021, 10:52 PM   #43
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
Drives: M340i, Mineral White
2020 BMW M340i  [0.00]
2013 125i  [0.00]
11/2020.50 OTA done
Got the 11/2020.50 OTA upgrade this afternoon...(in NZ)
A notification came up on the IDrive notifications, and I selected proceed via my phone. Its a Pixel 5 Android 11, with both Android Auto and MYBMW Apps.
The download is 617MB in size so the first thing to do is check to make sure your MyBMW App is set to download remote upgrades over WiFi and not over mobile data. Took a couple of minutes to download to my phone over a 100Mb Fibre to the Home and 5Ghz Wifi link..(although the App said initially 57 minutes!)
I then connected the MyBMW App to the car; it needs to connect on both Bluetooth and WiFi. So another trick is that the MyBMW App wont connect to the car if Android Auto on the phone and the car is already connected and running. So disconnect/exit Android Auto on both the car and on the App. It took about 30 minutes to transfer the file from phone to car using the MYBMW App connection while driving.
Once the file is in the car, it tells you to check car in park, handbrake on, and keys inside the car. Once that's done, touch OK, and it starts the download from phone to car. The car does lots of whirring, an aircon fan goes at various speeds, the round safety system LED flashes various colors, and it shows a % completed line as its underway. It took 21 minutes to complete the upgrade..pretty good. It then gives you a write up on the Version and changes etc. Then tells you to open the BMW Drivers App from the MyBMW App, and hey presto, the car users guide App is then updated for your car on the new release. Very smart!
Given the number of problems with RSU that I have read on forums and Facebook groups, i was a tad surprised how easy it was and that it worked perfectly.
