Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications ECU unlock
      07-07-2020, 05:14 PM   #1
Bmwguy1994
Bmwguy1994's Avatar
Drives: M5 Comp(15)/435xi MSport(16)
ECU unlock
As many of you know g20s with the 11/19 update and after are not tunable via OBD port and requires a bench unlock before anything can be done...I would like to open this thread for anyone who has more info on the matter and can contribute info on solving this dilemma..Please do not hit us with JB4 talk, although its great for what it is its not relevant for this thread or ppl who want a flash tune i...Also if anyone knows any locations where we can pull up for a simple bench unlock In the NY try state area please share.
      07-08-2020, 03:00 AM   #2
Don76
Drives: BMW 320i M-Sport
I've had my 2020 ECU unlocked before flashing with bootmod3.
There was no need to remove ECU, the garage simply used a couple of probes onto connection points on the ECU and performed some laptop based wizardry with a tool called autotuner.
Autotuner have an insta account - perhaps you can find out if they have a dealer in your area?
It cost me £125 GBP to have it unlocked.
Be aware, there is a counter inside the ECU that clocks each time the ECU is flashed. You should be prepared to kiss goodbye to your warranty once you do this.
      07-08-2020, 03:07 AM   #3
Don76
Looks like unlock via OBD is here
aTriz16.50
      07-08-2020, 12:13 PM   #4
Punkwrock
Punkwrock's Avatar
Drives: 2020 BMW M340i-X
i actually tried on my 2020 330i about 5 days ago and it wouldn't flash. I couldn't even register my vehicle as the ECU would boot me off every 4 seconds. bootmod3 issued me a refund, I wonder if they came up with a solution in the last few days?
      07-08-2020, 02:59 PM   #5
chenry
Drives: BMWs
If it's BM3 that you are after I think IG tristatebm3 can likely help. If you look at their IG account there is a phone number and contact info. If it's a general unlock you are after for another tuner I would imagine you would need to look elsewhere
      07-08-2020, 03:01 PM   #6
chenry
Drives: BMWs
As an interim solution if anyone is thinking of sending their DME to the tuner of their choice - I posted a high-level "how to remove your M340 DME" in the DIY section located here:
https://g20.bimmerpost.com/forums/sh....php?t=1736611
VipinLJ1941.50
      11-04-2020, 04:28 PM   #7
nicksam5
Drives: Bmw 330i
bmw 330i g20
So I have a 330i G20 too and need to a die unlock what's the best way to go at this.
      11-05-2020, 01:28 AM   #8
Don76
Speak to your local tuning shop. It's a quick process if they've got the correct equipment
      03-04-2021, 07:35 AM   #9
Digzz
21
Drives: M2 G87
Where did you take your car to get it unlocked ?
      03-04-2021, 07:49 AM   #10
Antec800
Drives: 340i x drive
I hope they have a way to reset the flash counter like the older bmws, so far Bmw has been able to see I’ve flashed over 79 times (beta tester)
      03-04-2021, 12:55 PM   #11
carguy19
carguy19's Avatar
Drives: 2021 M340
I don't think the 2021 models can be tuned as of yet. This is what I have been told by 3 different tuners, one of them that uses bootmod, so I dont think this is accurate.
      03-06-2021, 10:04 PM   #12
tarrant64
Drives: M340i
I need more info...because I'm 100000% interested.
      03-08-2021, 03:53 AM   #13
Don76
I used Williams Performance in Newcastle Upon Tyne
      03-08-2021, 06:27 AM   #14
Whiteout_M340i
Whiteout_M340i's Avatar
Germany
12
Drives: 2021 BMW M340i
Still not available for 2021's built after June 2020
anotheran389.00
