12-26-2020, 01:26 PM | #2 |
1937
Rep 3,520
Yes. Unless you have the track pack IIRC.
12-26-2020, 02:18 PM | #3 |
Rep 122
Believe it was a wheel selection option - either way the site builder used to directly state what was needed to remove it. And from what I can see it no longer does.
You had to have a 19" summer non-run flat tire option from factory in order to get it upped from the 130mph to 155mph limiter. I forgot about this during my purchase entirely, ended up with 19" runflats with 130mph limiter. I contacted my dealer 2-3 days after delivery - they said there was nothing that could be done. And it took my sales guy a good day searching around for that information to be sure. There's a specific option needed (again I think it's a wheel/tire combo) from factory for it to be enabled. Reasoning being is the tires are rated differently in terms of speed - so for liability I'm assuming the runflat/all-season options from factory are only rated up to 120-130mph. This can't realistically be changed once the car has been delivered - a remap of the ECU is the only thing that can remove it after that. I'm not too bummed out about it personally, but I do track my cars periodically and my last one was slightly less powerful than the M340i and I could do 120-122mph on the straight, so thinking I may have to take a gamble on an ECU remap JUST for that one function. I would honestly be OK paying up to $500 to BMW directly or something for that limiter to be increased/removed. Just make it an option on the vehicle for people to buy like the other OTA options that can be enabled. Kind of miffed. Coming from a Focus RS - I could get it up to 156-158mph from the factory with enough road in Mexico. So WTF BMW is presenting a performance vehicle, M340i, with that kind of a limit is the type of garbage Lexus does. Sorry for the rant - this only affects me for like 10% of how I will use this car for. I try not to stew on it lol. It's honestly not a huge deal, and once the DME's are unlocked for the 2021's I will fix it. |
12-26-2020, 03:33 PM | #4 |
Rep 112
It depends on the package and tires you selected. Run Flats are limited to 130mph. If you got the ZTK package for $1500 you get the following which also increases the speed limiter.
-19 inch front wheels (required for larger front brake rotors) -Michelin Pilot Sport 4S tires 225 front and 255 rear (with mobility kit with air pump since tires are non run flat) -374mm front rotors and calipers (compared to standard which is 348mm) -Extra radiator under the front bumper Not a huge deal but this package is worth it IMO. |
Stiunit23.00 |
12-28-2020, 06:20 PM | #5 | |
Rep 101
Yea I was not aware and thought it was something with the car . Roads have been empty around me so having some fun . Thank you again for the info |
tarrant64116.00 |
12-28-2020, 09:20 PM | #6 |
Rep 355
If you ordered the M340 with summer tires, either runflat or non-runflat it increases the top speed limiter. If you ordered with all-season tires top speed is limited to 130mph. Not sure where people are saying the summer runflats are limited too unless that is something new for 2021 but it wasn’t that way when I ordered my 2020.
12-28-2020, 09:49 PM | #7 |
Rep 122
Yeah, it's not hard to hit the limit...not at all.
Stiunit23.00 hubbahubba8710.00 |
12-28-2020, 11:45 PM | #8 | |
Rep 122
Either way, unless people know to go through the line item package selection options it's "masked"/not upfront on that detail. |
12-29-2020, 08:42 AM | #9 | |
Rep 355
CrownRoyal79283.00 |
12-30-2020, 08:20 AM | #12 |
Rep 122
12-30-2020, 08:23 AM | #13 | |
Rep 122
That said 160-161 sounds right from what I’ve seen. |
12-30-2020, 08:33 AM | #14 | |
Rep 28
I got all-seasons from Factory with my 19" rims just to be able to reuse them for winter tires in the future. Plan on getting new rims and summer tires here in the spring... wonder if I screwed myself by ordering the all-seasons from factory. |
themnmd1687.00 |
12-31-2020, 09:08 AM | #15 | ||
Rep 51
12-31-2020, 06:51 PM | #16 |
Rep 1,531
Biggest disappointment when I realized my car topped out at 130 which comes on in mere seconds. Even a lousy Lexus 4 cylinder IS has higher limits. Limiting to 130mph due to having all - seasons is plain stupid especially in a car with this much power. Furthermore, many of us who ended up with all- seasons have already swapped out to Michelins PS4S anyway. 130 top speed should be for a car with 200hp or say the 330i but not on the M340i.
Prior's: E36, E46 x2
01-01-2021, 01:38 AM | #17 |
Rep 285
Drives: 2021 M340 RWD
Going through this now, which is part of the reason I traded in my car after a month for current set up of staggered with non runflat PS4S
"Either get busy living, or get busy dying. That's GD right." - Red (Shawshank)
01-07-2021, 08:39 PM | #19 | |
Rep 122
Would have been more helpful in the video if he could elaborate more on what exactly that fuse was linked to so it could be referenced in other Fuse layouts to try. The G20 series is nothing like that fuse box from what I can see. |
EXE462097.00 |
02-06-2021, 08:17 AM | #22 |
Rep 28
I have a ‘21 M340i on run flats & mine is 110% limited to 130. Actually almost got beat by a charger because of it.
Any one removed the limiter without a DME unlock ? Last edited by SlwG20; 02-06-2021 at 09:11 AM.. |
