01-07-2021, 05:47 PM | #1 |
Rep 56
Bimmercode Expert Mode Cheat Sheet
Hello, Just wondering if anyone has a cheat sheet for coding using Bimmercode on the G20. I have coded many things (sport plus,comfort plus, M instrument Cluster. ETC). I would really just like a sheet that lists all the possibly things we are able to code on our cars (like my previous F30) !
01-08-2021, 06:34 AM | #2 |
Rep 147
Hi, why dont you just make one for all of us about what you did to your vehicle and what really works ?? it would be useful for many like you.
Even i have G20 and wondering what can be done in Expert mode safely. Thanks in Advance. |
01-08-2021, 09:37 AM | #3 |
Rep 47
u can code stuff like ambient lights, b&w soundprofile, adv etc. I can make a bigger post later
01-08-2021, 05:33 PM | #4 |
Rep 56
01-08-2021, 09:05 PM | #5 |
Rep 422
Sport+
1. BDC -> Expert -> 3221 PfFesMaster -> FesSportWorldMode1 -> SportExpert -> Code 2. MGU ->FES_SPORT_EXPERT -> aktiv Auto Steering Heat 1. MGU->AKT_Auto_Lenkrad-> aktiv 2. BDC->LHZ_CCM_IKF-> aktivIKF_EN 3. BDC->IKF_ENABLE: ikf_alle_size Wireless Charging 1. BDC -> WcaWirelessChargingAblage-> WCA_ENABLE -> aktiv 3. HU_MGU -> 3000 HMI_SPEECH -> WCA -> aktiv Rear DRL 1. HU_MGU->HMI_SPEECH->DAYDRIVING_LIGHT_REAR->aktiv 2. BDC in Expert Mode > 3702LicFeatures->Feature_4 ->activ |
22
VipinLJ1941.50 EDMG2076.50 ultrared93103.00 Poochie9103.00 oreoOozZz126.00 jeremycanada25.00 Fpangalos46.00 Tskyline10.00 jocamero48.50 RN4Ever66.50 ssgm1x417.50 Sneakz30.00 schoolbus1598.00 M00dz3.00 portimao5021.50 kleichnet0.00 Cpatel38.50 excep7ion49.50 Murtaza_930.00 Farminarmin0.00 doughy20020.00 Giangy7.50 |
01-08-2021, 10:28 PM | #6 | |
Rep 56
01-08-2021, 11:32 PM | #7 | ||
Rep 9
EDMG2076.50 |
01-08-2021, 11:44 PM | #8 |
1942
Rep 3,521
You can buy the OEM wireless charging unit online and install it in your car. You'll then need to do the coding mentioned above to activate it in your idrive.
01-09-2021, 12:36 AM | #9 |
Rep 422
01-09-2021, 01:55 AM | #10 |
Rep 146
I have added the below using Bimmercode Beta in standard mode on a UK spec car running BMW 07/20.54 software.
I have to keep a list as I need to re code the car each time I download the latest BMW software update as it wipes most of this coding and I have to start again. Coding is done at your own risk. You need the correct software version and modules on the car for all coding to work correctly. All codes work on my car, but it is possible to cause serious damage to the car particularly in "expert mode". Head Unit MGU Remove legal disclaimers M start up animation in I drive Video in Motion enable Radio 50% at start up Tyre pressure & temperature both displayed Front DRL check box added in I drive Body Domain Controller BDC Start car in adaptive mode Light / rain sensor insensitive Turn off passenger mirror tilt in reverse Rear LEDS on with front DRL's Boot opening delay to 1 second No horn when locking car with engine running Window lifter interuption when opening door - removed Advanced Crash Module ACSM Remove seat belt chimes driver and passenger Change rear view camera to 50km and 50m Engine Control Unit DME Air con memory remember last setting Air con auto settings used in manual mode Instrument Cluster DKOMBI Alpina dash layout Powertailgate Module HKFM Close tailgate without long press on remote I added the below in expert mode Enable Sport + function & Comfort + functions Expert mode Body Domain Controller - BDC 3221 PfFesMaster > fes > Change FesSportWorldMode1 to SportExpert (Default should be Non sport expert). “3221 PfFesMaster” > fes > comfort plus > Comfort Plus Enable sport + & comfort + options in the I drive menu Expert mode Headunit - MGU 3008 > Fes_sport_Expert > Change nicht aktiv to aktiv for sport + 3008 > Fes_Comfort_Plus and change it to aktiv for comfort + Enable Auto Steering Wheel heat option in I drive Expert mode Headunit - MGU 3000 HMI SPEECH > AKT_Auto_Lenkradheizung > aktiv Enable Auto Steering Wheel heat function Body Domain Controller - BDC 3142 PfLinLRE > LHZ_ CCM_IKF > aktiv 3450 Others 1 > IKF_ENABLE: ikf_alle_sitze Enable Rear Camera Zoom (Towbar) Expert mode Headunit – MGU 300B Parken- Macro_trailer_coupling > active. Enable Bowers & Wilkins HI FI & Equaliser Expert mode Headunit - MGU 3002 - Audio Broadcast – Audio System then change the parameters from alev3-Ram to alev4-Ram code Ambient light colours were then changed in expert mode with an additional instruction sheet which I have. Last edited by andy5468; 01-13-2021 at 12:21 AM.. |
24
EDMG2076.50 VipinLJ1941.50 hamera441.50 BCD-53551.50 Ghost2337.50 chunll200175.00 oreoOozZz126.00 Andrei_180.00 Sonic RR115.50 masonwoyt4.50 EnWhyCeeBMW6.00 Chevychong0.00 jocamero48.50 pewpew39225.50 CyclingBroStyle233.00 fkyang20.00 PingJu_Wu0.00 schoolbus1598.00 HappyGuy_Holland1.50 WolfpackCO153.00 dancing__narwhal141.50 excep7ion49.50 Farminarmin0.00 Giangy7.50 |
01-09-2021, 02:18 AM | #11 | |
Rep 56
01-09-2021, 05:55 AM | #12 |
Rep 47
Assisted Driving View (cars before 07/19):
DKOMBI: CB_FZG_UMGEBUNG_FAS -> aktiv CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG -> aktiv PIA_FZG_UMGEBUNG_FAS -> aktiv |
01-09-2021, 07:37 AM | #13 |
Rep 558
Nice work, all.
My 07/2020 OTA just happened... time to get to work! |
01-09-2021, 09:13 AM | #14 |
Rep 146
I tried this on mine a couple of months ago, but apparently I need the correct modules installed, which I do not have, so it did nothing. Mine was a March 2019 build.
01-09-2021, 10:24 AM | #15 |
Rep 2
Hi guys, Need some help.
Tried coding my 330e G20 year 2020 Was doing fine until coding FEM Did some activation of Nav and Car Play (I assume apple car play) After coding completed the idrive7 locks into an endless reboot loop. The Logo comes on for a few seconds and goes off and comes on again. Endless reboot loop. Tried holding down the volume button 30sec to reboot the system but nothing. The car is still drivable and only the reverse camera system comes on in R. Otherwise the idrive7 goes in to endless reboot and when reading the car on Bimmercode the FEM menu is no longer there. Probably due to the fact the idrive7 can’t start up. Anyway to rectify this ? |
01-09-2021, 10:47 AM | #16 |
Rep 558
Is there and M opening animation for the instrument cluster? I thought I had one coded or is it only in the idrive display?
01-09-2021, 11:17 AM | #17 | |
1942
Rep 3,521
EDMG2076.50 |
01-09-2021, 12:02 PM | #18 |
Rep 4,551
FYI, if anyone is running the 11/2020.xx software I highly suggest signing up for bimmercode beta as the developers have fixed issues coding certain modules. DME for sure. Maybe others.
You don't want to brick your car so go easy with the expert coding. Only use known tested coding. Avoid trying to be a genius or you might end up needing a flatbed to dealer and be left with an expensive repair bill.
01-09-2021, 10:02 PM | #19 |
Rep 2
01-10-2021, 06:21 AM | #21 |
Rep 15
finaly auto steerheating is working again. with old software was normal that it works but after my visit ad the story doesnt work any more.
thanks for sharing the information i had fix it with bimmercode and enet cable |
