Technical Topics Wheels and Tires M340I 245/35/20 tires rubbing the front strut
      01-24-2021, 01:44 AM   #1
krnhyun
Drives: 2021 BMW M340I
Hi, I bought 245/35/20 tires because I saw some guys here running 245/35/20 tires on the front. I test fitted them and tire is rubbing the spring cover of the strut. What is the problem it will be? how can I run 245/35/20 tires?
      01-24-2021, 11:50 AM   #2
CCM11285
CCM11285's Avatar
Drives: '24 G82
Get some spacers to push the wheel away from the strut tower
      01-24-2021, 12:31 PM   #3
TheDudeMan
TheDudeMan's Avatar
Ukraine
252
Drives: 20' 330i & RX 350
Are you running these on stock wheels?
5mm spacer should solve your problem.
      01-25-2021, 03:35 PM   #4
krnhyun
aftermarket wheel. 5mm won't solve my problem.
      01-25-2021, 06:08 PM   #5
TheDudeMan
TheDudeMan's Avatar
Ukraine
252
What's the wheel spec?
I'm running a 19x9 +32 with a 255 upfront, no issue. Granted I have a sportline 330i with passive dampers. From my understanding, the adaptive dampers are slightly thicker.
      01-25-2021, 08:53 PM   #6
krnhyun
20x9.5 +25 245 upfront. maybe car has bent strut or something?
      01-26-2021, 08:04 PM   #7
TheDudeMan
TheDudeMan's Avatar
Ukraine
252
I don't think so. What's the sidewall size? Also, is the tire making contact or rim?
      01-28-2021, 05:45 AM   #8
Nimz
BMW
South Africa
43
Drives: F30 M-Sport
You issue is the wheel specification rather than the tyre size.
Check the below link to an offset calculator which might provide some guidance
https://www.willtheyfit.com/index.ph...9-5&offset2=25
Sonic RR112.50
      01-29-2021, 03:58 AM   #9
krnhyun
tire size is 245 35 20. tire is making contact.
      01-29-2021, 03:15 PM   #10
Don76
Drives: BMW 320i M-Sport
I run 235/35R20 on an aftermarket 8.5 rim.
(275/30R20 on 9.5 rim on the rear)
I run 15mm spacers on the front, but not because it catches, but to poke the wheels out flush.
You've got a few choices.
1: Try spacers. Cheapest and easiest option.
2: Change to a narrower front tyre.
3: Change to a narrower front rim.
If it were me, I'd try option 1
