02-07-2021, 06:50 AM | #1 |
Rep 38
G20 M Performance Brakes Coding Procedure
Hi All,
Can anyone share the coding steps after installing the M Performance Brake Kit on the G20? Much appreciated, thanks. |
02-08-2021, 04:54 AM | #2 |
Rep 562
This is from in the install instructions... Can't help you past that, sorry.
6. Concluding work and coding The retrofit system requires programming/coding. – Connect the battery – Bleed the brake system with DSC as described in ISTA/AIR No. 34 00 046 – Fit the front and rear wheels as described in ISTA/AIR No. 36 10 300 – Encode the retrofit with the Software Service Station (SSS) via the – Retrofit/Sport Brake – path – Conduct a brief test – Carry out a function test (please use ISTA/AIR No. 34 00 ... General instructions for running-in new brake disks / brake pads.) |
