02-28-2021, 09:55 AM | #1 |
Rep 2,567
Hi all,
Just picked up a G20 2 weeks ago and something on the highway hit the center grille and slightly cracked it. Luckily it didn't hit the bumper. Part is relatively inexpensive. Is there a way to replace the center grille without removing the bumper? If the under shields are removed, could it be swapped out that way?
07 e92 335i - Retired
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current |
02-28-2021, 10:42 AM | #2 |
Rep 4,722
I had this happen on my old F32. Dealer had to pull the bumper off. My guess is it's probably the same?
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
02-28-2021, 12:51 PM | #3 |
Rep 2,567
Hmm probably. Would be nice if it could be done without removing the bumper.
02-28-2021, 07:17 PM | #4 |
Rep 359
No it's not possible, this trim is attached from the back side. You will have to remove the bumper.
I have attached instructions for a bumper replacement. You can skip most of the stuff there, but it includes the instructions for removing the bumper. Just look at it, should be clear which steps you can skip. |
OM3RTA391.00 |
03-01-2021, 06:25 AM | #5 | |
Rep 2,567
03-06-2021, 01:00 PM | #6 |
Rep 35
This just happened to me, got my car 3 weeks ago and hit a squirrel. I ordered the replacement part for it for like $75 on Amazon and talked to a friend at a local shop. They said they wouldn't recommend DIYing it as you have to take the bumper off and there's a ton of sensors that are hard to deal with. They said it's much more expensive to do it at a dealership than a shop btw.
03-07-2021, 01:09 PM | #7 | |
Rep 2,567
These grills suck. Soo flimsy.
03-07-2021, 05:03 PM | #8 | |
Rep 359
03-07-2021, 08:43 PM | #9 | ||
Rep 2,567
apptest2996.00 |
03-08-2021, 09:19 AM | #10 |
Rep 359
I'm based in Munich. No need to be nervous, if you never wrenched on your car, maybe start with something else first (i.e. give the front bumper issue to a shop for now). While it isn't particularly hard to drop the bumper, you probably still shouldn't do it if you don't have any experience at all.
