2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums AUSTRALIA Is comfort access RELIABLE ?
      06-29-2020, 07:36 AM   #1
firetitanx
firetitanx's Avatar
100
Drives: BMW 330i M Sport 2020(G20)
Hi All
I set my car to "Lock automatically when I walk away.
it has been working quite well, except a few times when I do walk away and it just does not work!!
Does anybody have this issue?
To open I just leave the key in my pocket and open with handle.
I have not set comfort access to autoopen on approach.
Anybody know why the autolock is not that reliable or had the same experience?
Thanks
      06-29-2020, 07:42 AM   #2
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
Originally Posted by firetitanx View Post
Hi All
I
Thanks
No problems with my car.
Mine is set to Auto Unlock and auto lock when walk to the car or walk away. Works, perfectly every time.
Have you ever left the key or credit card key in the car? These might stop the car from locking.
      06-29-2020, 07:45 AM   #3
firetitanx
firetitanx's Avatar
100
Hi Steve
Thanks for that.
Interesting I carry the key card in my wallet, but have never left my wallet in the car.
I will monitor this , it just happened tonight , I had the key with me and walked out the garage , normally a couple of steps out the garage it lock and the mirrors close, but tonight no lock I had to lock it manually.
Maybe its too cold
      06-29-2020, 08:12 AM   #4
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Hi All
Thanks
I have a suspicion it may have happened once to me. I know that from then on I always walk away slowly and listen for the mirrors to fold as conformation. It's been 100% since then.
      06-29-2020, 08:14 AM   #5
firetitanx
firetitanx's Avatar
100
Mmmm, thanks Slideit ...the jury is not yet out on this function, well at least on my car I thought it was sooo cool, but have had 2 failures so far.
      06-29-2020, 02:57 PM   #6
del82
Drives: BMW M340i xdrive
Hi All
Thanks
Have it set to auto lock both when walking to and away from the car.
Walking up to the car it's fine. Walking away works 8/10 time.
What I find is that it'll lock when I'm walking around from say the drivers side to the passengers side, close to the car, so if anything it's too sensitive.
It has a number of times not locked when walking away as well. I have the bleep set so I know when it hasn't auto locked.
Current: 2020 M340i
Past: M140i, Z4 35is
      06-29-2020, 05:58 PM   #7
firetitanx
firetitanx's Avatar
100
Ah thanks for that del82 , glad to know that I am not the only one that has experienced this.
When you say you have the bleep set so you know it has not auto locked, can you tell me which setting this is in the menu ?
Thanks
      06-29-2020, 07:32 PM   #8
erawamai
erawamai's Avatar
Drives: BMW 330i G21
Hi All
Thanks
No problems with mine. Walk away and lock.
The kick under the boot to open the boot is a bit finicky.
      06-29-2020, 08:20 PM   #9
firetitanx
firetitanx's Avatar
100
Ah thanks erawamai good to know.
I think the trick with the boot is to do a medium speed kick aligned with the badge.
But I agree, sometimes it does not work and it looks pretty stupid when people see you kicking the boot repeatedly
      06-29-2020, 09:37 PM   #10
achk
Drives: BMW U11 iX1 Xdrive 30
I set it to only lock on walking away as a "back up". I'm used to touching the door handles and using the lock button on the boot lid to lock.
Turned off the unlock on approach function on the first week as it was locking and unlocking when I was wandering through the garage 😂
You gotta touch the door handle to open the door anyway!
Ruka800.00
      06-29-2020, 10:47 PM   #11
firetitanx
firetitanx's Avatar
100
Hahhaha, I agree.
I may follow the same process as you, always lock with the door handle and if I forget and walk away it should lock itself ...good approach
I thought the tech was really nifty, you walk away and it locks voila no worries, but obviously some of us have a 80/20 hit rate, so you still need to check just in case.
      07-01-2020, 02:35 AM   #12
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
Drives: M340i, Mineral White
2020 BMW M340i  [0.00]
2013 125i  [0.00]
Hi All
Thanks
there is a limitation in that it will not work if the car has not been driven for a few days...the number of days isn't specified but I saw on another forum that the consensus was about 4 days.
And if there is another key within about 6 metres of the car, it supposedly won't work either.
But I have never had an issue with it on my car.
I've got it set for lock only. I did have it set for unlock as well , but it drove me crazy... unlocking whenever I was nearby with the key.
      07-01-2020, 03:39 AM   #13
Phippsy81
Phippsy81's Avatar
79
Drives: G20 330i M Sport Plu
Yeah, mine is not 100%, so I turned on the beep on lock function so I can hear if it hasn't worked... it works maybe 8/10.
I do find that when parked in certain places, or I leave from certain positions/angles it's more temperamental too. I have a large wall at the side of the drive and if I walk in a certain position it never likes it 🤷🏻
J
330i M Sport Plus
Previous- 435D M Sport
      07-01-2020, 05:08 AM   #14
Sergeant Skinner
Sergeant Skinner's Avatar
166
Drives: 2020 BMW M340i XDrive
If your phone, NFC enabled credit card, security swipe card etc get in the way of your key (same pocket or in between key and car somehow) then it doesn't work as reliably or at all.
Have you separated everything from your pockets and see if it still behaves weird?
      07-01-2020, 07:47 AM   #15
firetitanx
firetitanx's Avatar
100
Ah , that might be it PBJ , I have my M Card in my wallet and it is quite close to my jacket pocket, I will take it out and see how I go
Good advice
      07-01-2020, 08:22 AM   #16
Sergeant Skinner
166
Good advice
Fingers crossed!!! Happens to me all the time
      07-01-2020, 09:45 AM   #17
firetitanx
firetitanx's Avatar
100
Good advice
Good advice
Everyday learning new things 😄👍
But it's a great journey !!
      07-02-2020, 04:32 AM   #18
firetitanx
firetitanx's Avatar
100
Naah , turning off comfort access auto lock when walking away, just washed the car..hahahah.. the car was doing the autolock dance.. I could always leave the key far away.
My thoughts are , if i always have to doublecheck then I might as well just lock it manually on the door handle instead of walking away and hope it locks and then have to take the key out my pocket and lock it if it doesnt. i'm soo lazy hahaha
      07-02-2020, 04:37 PM   #19
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
When you’re washing the car, leave the key inside.
It will save all that locking/unlocking BS.
      07-03-2020, 02:23 AM   #20
firetitanx
firetitanx's Avatar
100
When you're washing the car, leave the key inside.
Thanks Steve,yes maybe I will use the card instead
      07-03-2020, 03:56 AM   #21
GTR33R
Drives: M340iXdrive
I leave the fob inside when washing.
      07-03-2020, 08:56 AM   #22
digitallust
digitallust's Avatar
Drives: 2019 G20 BMW 330i M-Sport
Or just use the digital key when washing like I do
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned
Current - 2019 BMW G20 330i M Sport Alpine White
Retired - 2018 - Range Rover Velar SE D240
Retired - 2015 - Mercedes Benz C250d AMG Line W205
