Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications 2021 Flashing.... Bad News for now...
      02-15-2021, 12:13 PM   #67
Digzz
21
Drives: M2 G87
Can anyone shed some light please ?
I have a 2019 M340i . Does this mean I can bench unlock it and tune it with BM3 with the ODB Port ?
Is this possible ?
      02-15-2021, 12:48 PM   #68
chenry
Drives: BMWs
Is this possible ?
With a 2019 you should be able to unlock and flash at home with BM3, Mission Performance, MHD all over OBD. I unlocked and flashed my 2020 myself using Mission
      02-15-2021, 12:53 PM   #69
Digzz
21
Drives: M2 G87
Oh ok . So I don't need to bench unlock ?
      02-15-2021, 01:03 PM   #70
chenry
Drives: BMWs
typically no unless your DME has been updated with a later rev of software (I think some were updated but I'm not 100% on that). With Mission I downloaded the MP software hooked it up to the car and it gave Alex a data dump on my DME rev of software etc...so he was able to see if my car was able to be remotely flashed. I'm sure BM3 can do something similar but I'm not familiar with their process
      02-15-2021, 01:06 PM   #71
Digzz
21
Drives: M2 G87
Thanks . Think I’m goner do BM3 scan and I heard you can send it to them and they tell you.
      03-01-2021, 07:50 AM   #72
kuzdu
Drives: 21 M240i
Any updates from the flashing world?
      03-01-2021, 04:26 PM   #73
iiSonnyii
Drives: 2021 m340i
Nothing yet, we are all waiting. I am currently running JB4, Burger Tuning Staff is quick to response and was fairly simple to install. If your interested go talk to mike@x-ph.
      03-01-2021, 07:22 PM   #74
Vmaxx
Drives: 2021 M340i xDrive
Same here, IMO for the money JB4 has been satisfactory. I think it will be the second half of the year before we have a cracked dme for 2021s, and that’s if we’re lucky.
      03-01-2021, 08:52 PM   #75
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
Drives: G01///G20///I20
Either of you have dyno or track numbers or just butt dyno?
Also, are you running the EWG add on for JB4?
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
2024 iX - Yea, she fast
      03-01-2021, 09:02 PM   #76
themnmd
themnmd's Avatar
Drives: 23 X5MC
Is this possible ?
With all due respect there is no 2019 M340. I have a 2020 took delivery August 2019 , built in July, sold as a 2020
      03-01-2021, 09:53 PM   #77
iiSonnyii
Drives: 2021 m340i
I do have EWG add on and running E30. I am running on Map4, currently full boost is 26 psi and have catless downpipe.
I raced my friend 2021 Supra when I was stock and he took me by 2 cars. With JB4 and e30, I got him by 2 cars. Hope this helps. I don't have any dyno numbers sorry.
      03-01-2021, 10:28 PM   #78
Patgilm
Drives: GT-R, X7 M50i, M340
Look where he is from. In the UK they did have a 2019 model year. In the US it was a 2020.
themnmd1691.00
Jim-Bow130.50
      03-02-2021, 03:57 AM   #79
Vmaxx
I have Draggy results pre and post JB4, measured on the same road, same weather conditions, same fuel levels, etc... and gained about 3/10ths of a second to 60, 4/10ths now that I have a down pipe.
      03-02-2021, 06:46 AM   #80
Banana Clipper
Jewel Runner
Any cels from the Downpipe?
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
      03-02-2021, 08:10 AM   #81
themnmd
themnmd's Avatar
Drives: 23 X5MC
Ah my bad thanks
      03-02-2021, 09:29 AM   #82
kuzdu
Drives: 21 M240i
I reached out to bootmod3 it's still in the works. i ordered the JB4 yesterday probably going to run stage 3 on 93 oct. i forgot to order the ewg wire. if i get the wire i would be able to run map4 on 93 alone or would i have to do an E85 blend?
      03-02-2021, 09:45 AM   #83
Vmaxx
You could still run 93 but you won’t see much gains without E on that map. I would stick with Maps 2 and 3 if your only going to use 93.
      03-02-2021, 10:11 AM   #84
kuzdu
Drives: 21 M240i
sounds good, the station by me has E85 i guess after i install it and get the feel for it ill do the EWG and e85 blend. last thing left to do after that is the down pipe and I'm set
      03-02-2021, 10:13 AM   #85
kuzdu
Drives: 21 M240i
How does the JB4 differentiate stage 2 from 1 meaning no down pipe to a down pipe? hopefully XHP does a reflash for you guys soon. my transmission is lighting fast with shifts after the flash.
      03-02-2021, 11:05 AM   #86
Fuel-It!
Drives: M4, M5, M2C, X4M, 440i, etc...
They have different maps in the system for use with different fuel and mods. The only catch with downpipe is they won't turn off the light for you inside the USA so if you go catless have to deal with CEL.
      03-02-2021, 12:17 PM   #87
kuzdu
Drives: 21 M240i
Crap that's good to know, i will have to do the washer flange thing to get rid of the light. Thanks a lot for all the info.
      03-02-2021, 03:21 PM   #88
iiSonnyii
Drives: 2021 m340i
Yes, because JB4 just went 50 State legal, they had to update the firmware where it doesn't auto delete catless cel code. Doesn't bother me, car still performs and easy to delete codes.
