07-07-2021, 05:21 PM | #45 |
Rep 269
I haven't had any doubts about the effectiveness or reliability of the bms products, for the jb+ it was more so about the pay off vs risk of warranty loss. I figured if I got the jb+ I'd have my fun and work my way up to jb4, rather than jumping right in and then wanting more anyways.
So your running map 5 with the stock downpipe? I thought anything past map 2 you need catless/high flow? |
07-07-2021, 09:08 PM | #46 |
Rep 524
Yes, I’m running Map 5 with stock downpipe. As long as your fuel is right (E85 mix) and the EWG harness is connected, you can safely run Map 5. That said, I worked myself up to Map 5, meaning anytime i tried a new Map, Id log a few runs and then have the Burger guys evaluate them.
07-07-2021, 09:42 PM | #48 |
1943
Rep 3,521
Ideally yes. Else there'll be a lot of timing pulls that can be harmful to the engine, especially on 91 octane. Probably even on 93. So it's ideally ~E25-30 or 93 with a good octane booster or race gas.
07-13-2021, 11:36 AM | #50 |
Rep 15
Drives: M340I
Considering stock we're doing 0-60 in 4.1s, the results from the JB+ are pretty meh....not gonna lie.
Did you try to lower boost ? Adding boost without having the proper fuel will actually slow the car instead of making it faster. Pretty sure you're on 91oct...Using octane booster or getting 93oct+ would gives better results if you're trying to run more boost! Hopefully that'll help! Last edited by GhostMajor; 07-13-2021 at 04:39 PM.. |
08-07-2021, 09:48 AM | #52 |
1943
Rep 3,521
Yup. JB+ max is around 4-4.5psi over stock? JB4 map 1 is around 3 psi over stock iirc. But JB4 feels smoother.
08-17-2021, 03:03 PM | #53 | |
Rep 771
I'm supposed to be going down to the Dragstrip soon to see what this car can do. I will probably run it on E20-E30 fuel on JB4 map 3 or 4. Car only has an MST Intake and rest is stock.
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White |
09-22-2021, 06:36 PM | #54 |
Rep 1
Hey tarrant64, were you able to clear the the 101F01 error code? I installed the JB+ and after 10 min my check engine light came one and has stayed light despite removing the JB+ and driving the car. I also tried Bimmerlink which allows me to clear other errors, but not this one. Hoping to avoid going to the dealer for this one if possible. Thanks in advance
09-23-2021, 09:23 AM | #56 |
Rep 269
09-23-2021, 07:56 PM | #57 |
Rep 508
09-25-2021, 08:04 PM | #58 |
Rep 10
Tried JB+ on 2021 M340i, was not a fan. Car didn't drive or shift as smooth as it used to. Also, pops/burbles (which I already had a minimal amount due to being 2021) disappeared almost entirely. Ending up returning it.
09-27-2021, 08:01 AM | #59 |
Rep 771
JB4 on an otherwise stock 2021 M340ix running 93 Octane on just Map 3.
I ran 11.75 sec. 1/4mile (left lane)
2018 BMW M3 Alpine White Last edited by ssgm1x; 09-27-2021 at 08:08 AM.. |
PLF693767.50 evan10320728.50 |
09-27-2021, 08:31 AM | #60 |
Rep 162
I just got a 2020 M340i and had still have the JB+ plus i was running in my 2020 330i. I installed it in my M340 and have it set at 3 o'clock. I noticed good torque gains in the bottom end but after 100km/h the car is sluggish compared to stock so i removed it. I can only get 91 octane in my area but was wondering if anyone tried other settings on the JB+ @91 to maximize power gains and not lose any top end power? Even my HP/TQ gauges show a loss of power at the top end compared to stock on my dashboard.
09-27-2021, 03:37 PM | #61 | |
Turbo = God's Gift
Rep 21
Never lose to Waze eta
PLF693767.50 |
09-28-2021, 11:28 PM | #62 |
Rep 355
09-29-2021, 01:28 PM | #63 |
Rep 269
That's actually a piggyback tune which is less effective than a flash, so low 11s is amazing. Or are u referring to someone reaching that level without any bolt ons?
09-29-2021, 09:36 PM | #64 |
Rep 355
09-30-2021, 07:27 AM | #65 |
Rep 50
I don't know who's tune is reliably getting bottom 11's tune only. I have intake and catless downpipe. I have had 4 different tunes. Local tuner OTS e30 stage 2, local tuner dyno tune stage 2+ e50, Bootmod3 OTS stage 2 e30, and Mission Performance stage 2+ e50. I have dragy tested all of them repeatedly in weather from 30* to 80* in the same level spot. None of them have done better than 11.36 with the above mentioned mods. With a little better 60ft it could have been a tenth or two lower but that is with mods and very little fuel in the tank on a 30* day. Typical results were 11.50's. Still great results for not much more than a tune but lets keep it real.
If a jb4 can reliably create bottom 11's with not much else on e30 then I waisted a lot of money. Lol! When I tried the JB+ it felt like the car fought it and felt like stock after running it awhile. No testing honestly, just my feeling. I never bothered since I had the tuning scheduled and the jb+ was just a temporary "fix" for my need for more. The JB4 with ewg wires is certainly better than the + with a lot more adjustability however I would like to see multiple back to back runs to see if performance drops off substantially as the dme "learns" what is going on. If someone could show that the performance from the JB4 is not just "glory run" capable that would be important to know for those debating on whether a tune would do much more for the money.
2020 M340i Xdrive Portimao
AA catless downpipe (offroad only of course) BMS intake and Inlet tube H&R Springs MHD Stage 2 E40 |
09-30-2021, 09:44 AM | #66 |
Rep 269
Has anyone tried Dinans e85 tune? They claim 502who and 539 ft/lbs, with nothing but their axleback.
How much power would a jb4 be putting down with just e30? |
