04-21-2021, 10:05 PM | #23 |
Rep 558
You're in New York so do you get +22 HP on 91 or +32 HP on 93?
Dinan_Engineering3910.00 |
04-22-2021, 07:17 AM | #24 |
Rep 22
I wanted to get Dinan + that is mapped for 91. Now I will probably hold-off because I initially thought I will be getting around 45HP, and not only 22. I will probably wait until Carbahn fixes remote start with their tune and go with Carbahn, since they offer around 50HP more at the peak. If anyone disagree with me, let me know, since I am pretty new to this.
04-22-2021, 08:59 PM | #25 | |
Rep 558
04-22-2021, 09:36 PM | #26 |
Rep 113
Drives: 2023 BMW M3 Competition
I checked with Dinan on this as I didn't want to lose remote start, but unfortunately you do lose it with Dinan as well. They're working on a patch but need a vehicle without remote start in order to analyze code differences and lock down where the issue is. Unless they get one, it could be a while, but holding out hope!
04-22-2021, 10:04 PM | #27 | |
Rep 558
This is how I am reading things if I am wrong anyone please let me know. Like maybe the 93 option is warrantied as well? Last edited by RTPenland; 04-22-2021 at 10:10 PM.. Reason: i added that cool thing |
04-23-2021, 10:47 AM | #28 | |||
Rep 3,129
Dinan + is the only variant that offers the factory matching warranty. It is calibrated for 91 octane as that is the minimum standard for the vehicle. You may use a higher octane than prescribed by the tune. For example, running 93 Octane on a 91 Octane map is fine, and in most cases will offer a bump in performance. Typically not to the full extent of the specific 93 callibration but more then adverstised on 91. We only warrant 91 octane simply because that is what we can control. Warrantying higher grades with more aggressive maps leaves the possibility that folks will run lower octane then required by the and cause harm to the engine which we would then be liable for. As far as the power bumps go -- if you are strictly looking at peak HP only then yes that gain is 22 HP (Dinan + (91)). Please note however that that peak occurs at 6000 RPM, a very narrow part of the power band that generally speaking is not utilized terriby often outside of a race track. Typical street driving is more in the 2k-4k RPM range. This is where the argument for the "area under the curve" comes into play. Is the power usable and in an area that is actually realized essentially. I would encourage you to expand the scope of metrics beyond peak HP as that is one very small data point. In comparison to other vendors tunes all I will say is that you should ensure you are comparing apples to apples when comparing charts. There will be some variance from different dyno types but nowadays I like to think that is minimal. However, is it the same octane, run in the same gear, similar cooling conditions, same vehicle / type, etc? All of those will have a bearing on comparables. I like to think we do a good job of presenting all the different variables and clearly label everything so that everything is pretty transparent. |
Top Gon414.50 |
04-23-2021, 12:29 PM | #29 |
Rep 22
So I was bored enough to create graphs for comparison. Note that there are approximates, see below. From these graphs seems that Dinan provides more power from 2500 to 4500 RPM. At 5000 RPM, HP advantage of Carbahn is negligible - 1HP, the difference starts at 5500 RPM that I assume not everyone will push on a highway.
Hope it helps. |
04-23-2021, 01:05 PM | #30 |
Rep 558
Okay so to summarize (based on what I see on the Dinan website and the numbers they are sharing:
04-23-2021, 01:39 PM | #31 | |
Rep 22
Can Dinan_Engineering confirm whether we lose or keep remote start with Dinan +? |
04-23-2021, 01:43 PM | #32 |
Rep 558
they (Dinan) just confirmed a couple posts above that remote start is lost with their tune
04-23-2021, 01:45 PM | #33 |
Rep 22
04-23-2021, 01:51 PM | #34 |
Rep 3,129
At this exact moment remote start is lost regardless of tune variant (Dinan+ or Stage 1). Technically it works for one start after the flash is installed and then will not after that but don't think anyone would consider that "working." As noted a couple posts up we are fairly confident we are on the path to resolving it in some form or another. Doing some permutation testing over the weekend and into early next week. By mid-week next week we should have a clearer idea if it is the magic bullet or needs more work.
04-23-2021, 02:01 PM | #35 |
Rep 558
Yeah I think Mission Performance is the only tuner that figured out a work around for adding or retaining remote start after flash. Those guys it seems have the capability to do some pretty cool things probably why Toyota hired them to work on their Supra
Last edited by RTPenland; 04-23-2021 at 02:28 PM.. Reason: added the toyota comment |
04-23-2021, 09:05 PM | #36 |
Bashar
415
Rep 1,120
Thank you Dinan_Engineering for responding to this thread and clarifying the results.
Is there a Carbahn rep on this forum also? CarBahn Autoworks I'm currently running a jb4 but I might jump ship to Dinan/Carbahn in the next few months. |
04-23-2021, 09:38 PM | #37 |
Rep 113
They did?? I was under the impression that their workaround was to keep your keycard in your vehicle at all times, which will allow you to use remote start (please correct me if I'm wrong on that). I wouldn't consider that proper remote start function, but if they did indeed fix it, awesome!
04-23-2021, 11:44 PM | #38 | |
1942
Rep 3,521
05-04-2021, 10:24 AM | #40 |
Rep 3,129
Still being worked on. The method we were testing/pursuing pseudo works but has caused some other problems on seemingly unrelated systems. Down the rabbit hole we are going. The good news (if your a silver lining type of person) is that it seems to affect all the late model cars in the fleet so it is getting a bit more attention as a result.
06-02-2021, 09:42 AM | #41 | |
Rep 262
06-03-2021, 08:02 AM | #42 |
Rep 75
Lot's of things to unpack here --
Dinan + is the only variant that offers the factory matching warranty. NOT true, CarBahn also offers factory matching warranty. A guy at Carbahn told me many of the DME tuners at Dinan left for CarBahn when Steve Dinan started the company. Take it for what it's worth but seems logical since CarBahn had full DME tunes long before Dinan. When I got my CarBahn time in July 2020 Dinan only offered piggy backs similar to JB4. Last edited by SpiveyCJ; 06-03-2021 at 08:07 AM.. |
06-05-2021, 02:20 PM | #43 |
Rep 220
Drives: '20 M340iX
06-06-2021, 11:53 AM | #44 | |
Rep 262
