Technical Topics DIYs and Coding Discussions Acoustic signal on reverse
      01-20-2020, 01:10 PM   #1
sd_dracula
Drives: 2020 G20 330e
Acoustic signal when reverse gear is engaged
Apparently it can be codded with the bimmercode app:
Enable/disable the acoustic signal that sounds when the reverse gear is engaged.
Values:
Active
Not active
For this option the following control unit has to be available in the car: “Instrument Cluster” DKOMBI4
Anyone found where this is via esys if possible?
      01-20-2020, 02:07 PM   #2
VipinLJ
VipinLJ's Avatar
I coded it first along with my auto start stop. It worked fine till I tried flashing my car with BM3 and that messed up the ECU settings. I lost both those codings while other codings stayed, which was weird. I then redid auto start stop and acoustic signal when reverse gear is engaged. Auto start stop works but acoustic didn’t work this time even though it showed it was active.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      01-20-2020, 02:20 PM   #3
sd_dracula
Did you do that bimmercode app or manually via tokenmaster/esys?
      01-20-2020, 03:21 PM   #4
VipinLJ
VipinLJ's Avatar
Bimmercode
      01-22-2020, 11:51 AM   #5
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Bimmercode
VipinLJ ,
Two questions, if I may:
  • First, what ECU module is the Acousitic Back up warning sound in?
  • Is the sound outside the car (I ask this because on my old F30, when I coded the back up sound, it was an god-awful sound inside the car)?
Thanks
Al
Retired: 2014 328i
BMW CCA
      01-22-2020, 12:43 PM   #6
VipinLJ
VipinLJ's Avatar
VipinLJ ,
Thanks
1. It was in the Instrument cluster DKOMBI4 module.
2. Yes. It was a beep noise inside the car when you engaged reverse. Just one, slightly long beep. I coded it because my VWs in India (manual transmission) made the exact same single beep as a warning to let you know reverse gear is engaged and it brought back memories
RSnic657.50
      01-22-2020, 07:25 PM   #7
Rossgazz
Drives: 2020 330I
I coded it first along with my auto start stop. It worked fine till I tried flashing my car with BM3 and that messed up the ECU settings. I lost both those codings while other codings stayed, which was weird. I then redid auto start stop and acoustic signal when reverse gear is engaged. Auto start stop works but acoustic didn't work this time even though it showed it was active.
I just coded off the auto start stop myself. I noticed it now stays off in comfort and sport, but if I switch into eco it turns back on and has to be manually turned off again via the console button. Was this your experience as well or is mine buggered up ?
      01-22-2020, 09:58 PM   #8
VipinLJ
VipinLJ's Avatar
I’ll let you know how it is the next time I take the 330i out. I’ve driven it in eco pro only once for 15s. Hated it and never tried it again. And that was before I coded a.s.s off.
      01-24-2020, 08:24 AM   #9
VipinLJ
VipinLJ's Avatar
Yours works exactly like mine did. I tried it today to see if what you said was right. The moment I hit eco pro, the a.s.s light on the console turns off. Put it back in comfort or sport and it still stays off. I have to press the button to turn it back on. It stays on after that until I hit eco pro again.
      01-24-2020, 03:50 PM   #10
Rossgazz
Drives: 2020 330I
[QUOTE=VipinLJ;25723741]
I just coded off the auto start stop myself. I noticed it now stays off in comfort and sport, but if I switch into eco it turns back on and has to be manually turned off again via the console button. Was this your experience as well or is mine buggered up ?[/QUOYours works exactly like mine did. I tried it today to see if what you said was right. The moment I hit eco pro, the a.s.s light on the console turns off. Put it back in comfort or sport and it still stays off. I have to press the button to turn it back on. It stays on after that until I hit eco pro again.
Ah ok, appreciate you checking. Thank You !
VipinLJ1936.50
      02-07-2020, 05:33 PM   #11
sd_dracula
So did anyone manage to code this with esys in the end?
      02-07-2020, 08:41 PM   #12
RSnic
RSnic's Avatar
Hi,
on my previous var, 2014 F30, I coded the ASS memory. Whenever I changed driving modes, the car "forgot ASS memory" -- exactly as you described. Having said that, however, if I was driving in EcoPro & shut car down with ASS off (ie, the red light on). When I started it again (I also coded car to start in EcoPro), ASS was off (red light on).
Now that I have coded ASS memory on my M340, the same occurs. This is the normal modus operandi for ASS Memory
Hope that helps
Al
Retired: 2014 328i
BMW CCA
      02-07-2020, 08:45 PM   #13
Burrcold
Drives: 2024 BMW M3 Comp xDrive
All this talk about ASS...
      02-08-2020, 02:30 AM   #14
sd_dracula
Not to mention going off topic...
