02-15-2020, 01:56 AM | #1 |
Rep 448
Drives: G20 330i M Sport
Front Grille Again
Would this genuine G20 M340i grille be a direct swap for my G20 330i?
Manufacturer Part Number: 51139448474 |
02-15-2020, 01:59 AM | #2 |
Grumpy Old Git
443
Rep 923
I don’t see why not.... as long as you get the right one if you have parking assistant plus.
See this thread especially posts by Conezz https://g20.bimmerpost.com/forums/sh....php?t=1619502 And this https://g20.bimmerpost.com/forums/sh....php?t=1685237
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R Last edited by Tam the Bam; 02-15-2020 at 02:11 AM.. |
02-15-2020, 03:15 AM | #3 |
Rep 1,039
Yup! As said by Tam all you need to make sure you have the PA+ hole in the grille if you have that on your car. No cam hole needed if you don't.
02-15-2020, 03:21 AM | #4 |
Rep 448
Thanks both. What are your thoughts on doing this? The grille has always been the thing I dislike the most on the new 3 series.
02-15-2020, 03:44 AM | #5 | |
Grumpy Old Git
443
Rep 923
For myself I would spend my money on the front splitter.
Retired:
02-15-2020, 04:08 AM | #6 | |
Rep 1,684
Then again, maybe not!! |
02-15-2020, 04:14 AM | #7 | |
Rep 1,039
Seaford1143.00 CrownRoyal79283.00 |
02-15-2020, 04:15 AM | #8 | |
Rep 1,039
Edit I see you have a black one already! My first point stands. |
02-15-2020, 04:16 AM | #9 |
Rep 1,684
02-15-2020, 04:20 AM | #11 |
Rep 4,932
If you prefer it do it. I'd say 95% of us that had/have f series models on here swapped the grilles to black ones.
The grille is definitely a low point of the g series but I'm used to it now and assuming I do order an m340 I'm leaving the celerium grille on as I think it looks better than the black ones on mineral grey. The issue for me is the really thick surround of them which really stand out with the black ones. |
02-15-2020, 09:38 AM | #12 |
Rep 829
02-17-2020, 02:01 AM | #13 |
Rep 1,684
Thinking about this overnight (I really need to get out more) the reason I questioned using the 340 grill in a 330 is that the one shown in the picture in the original post does not appear to have 'active' grills in it. The 330 grill including the active bits all appears to be one self contained unit.
I may be wrong on both counts, just trying to avoid someone possibly making an expensive mistake. |
02-17-2020, 02:39 PM | #14 | |
Rep 1,134
Drives: BMW G20 330e M Sport MY20
I am going for the black honeycomb style shown here.
20 BMW G20 330e M Sport Portimão Blue/Cognac, Driver Pro, Tech,M+ lumbar, storage packs
Long gone -15 Peugeot 308 2.0HDi GT AUTO Magnetic Blue, 10 BMW F10 520D SE Xirallic Imperial blue/Cinnamon Brown, 06 E90 320si - Le Mans Blue - Totally standard specification (Scrapped RIP 12/08/2010), 00 Peugeot 306 2.0 SE Cabriolet, 94 Rover 214 SEi, 91 Fiat Uno 60S Mk2 |
04-13-2022, 08:05 AM | #15 |
Rep 474
Just re opening this thread...
Did anyone do this swap? After doing some research it appears the active grill on the msport has 'ribbed' areas where as the 340i variant are flat active grills. Attached photos should illustrate. Would this be an issue for fitting? |
