2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Removing my mirror caps - any tips?
      02-17-2020, 01:34 PM   #1
BMKILLA
Drives: BMW G30 530e
Guys anyone followed this video to remove their mirror caps?
I've seen the other video on YouTube here with seems WAY more involved
Ive also seen that some people have snapped bits trying to remove them, anyone have any tips to share or maybe BMW instructions please?
I thought I saw a post somewhere but I'm using the app and searched but couldn't find any other posts, sorry if there is one in advance.
      02-17-2020, 07:47 PM   #2
Rednose_M340i
Rednose_M340i's Avatar
Drives: BMW M340i
It's not hard at all if you are a little bit handy.
Just tilt the mirror all the way down en release the two clips inside and carefully remove the cap with the help of a plastic tool.
It pops right off and then unscrew 3 screws to remove blinker. That's it.
Good video like the way i do it:
Just watch the movies and go for it
BMKILLA50.50
      02-18-2020, 06:04 AM   #3
BMKILLA
Thanks 😊 I saw that video and wasn't sure if it's the same for the G20. Have you removed them yourself using that method?
      02-18-2020, 06:36 AM   #4
Rednose_M340i
Drives: BMW M340i
Yes I did it that way.
BMKILLA50.50
      02-18-2020, 11:27 AM   #5
OM3RTA
391
Will need to have a gander at that vid as previously watched the Kies video& read comments on the US which suggested it could be really easy to crack the glass.
      02-18-2020, 11:35 AM   #6
Rednose_M340i
Drives: BMW M340i
The glass is fragile indeed, so I am not a fan of Kies his way for removing the mirrorcaps.
Do it the safer way like I said above
      02-18-2020, 12:03 PM   #7
OM3RTA
391
Does look waay less of a hassle in that vid
      02-21-2020, 11:54 PM   #8
BMKILLA
Installed, took 10 mins 👍
      02-22-2020, 07:43 AM   #9
OM3RTA
391
Looks good
BMKILLA50.50
      03-21-2021, 03:35 PM   #10
devil84
116
Drives: G30
anyone know if the G20 and G30 carbon caps. i.e same fitment. I note they have a different part number
      03-22-2021, 02:17 PM   #11
SilverGrey
124
Drives: BMW 330i M Sport
If I tried prying the mirror apart like in the video, I know I would crack the glass and sever the wires. Good job I have no intention of that mod!
Current: G20 330i M Sport
Previous BMW's:
F36 420i Gran Coupe M Sport; Z4 Coupe 3.0si M Sport; E46 325i Sport coupe;
      03-23-2021, 05:35 AM   #12
Carbon dude
Drives: G20 320D 2019, current M340i
I have the carbon wing mirror ones for my g20 and they fit perfectly.
      03-23-2021, 05:37 AM   #13
Carbon dude
I just removed the rear cover, no way I would use kies method. He makes it look easy and I tried it but got too scared incase it broke. In the end I bought a plastic set of wing cover remover from amazon.
      03-25-2021, 04:31 AM   #14
OM3RTA
391
It does take a good bit of force, more than you'd think, but as long as you go from the centre bottom part of the glass and use a tool that's thick enough not to flex you should be ok. The 'pop' or 'crack' when you do release the glass is most satisfying
      05-27-2022, 02:42 AM   #15
gorthol
gorthol's Avatar
Spain
63
Drives: BMW 330e 2021
2021 BMW 330e  [0.00]
I did this yesterday. There is no need to remove the glass and risk breaking it, just put the mirror to the bottom and using a flashlight to see clearly and a flat head screwdriver just pop out the brackets holding the caps (two pairs), it's easier if you use a screwdriver with a wide head so you can move the top and bottom at the same time just by rotating it in the center.
      05-27-2022, 06:21 AM   #16
Chubbiejones
Chubbiejones's Avatar
Drives: 2020 BMW M340i
I'd definitely try the process given in the 5series video vs the Kies.
