Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics M340i: HUD sport display shift lights gone after 11/2019.4 update
      02-19-2020, 12:50 PM   #1
Giggler
Drives: 20' M340i, 24' X5 40i
So I just discovered this recently. The shift point lights, which are hugely beneficial to timing shifts, are gone after the latest firmware and not sure how to get them back.
I've gone into my menus and verified that the option "Sports Displays" is enabled. Has anyone experienced this and know how to fix it? The sports display still works, it shows the rev meter, but the shift lights no longer appear when you approach max RPM. I was bouncing off the rev limiter this morning trying to make it work, got frustrated, so now posting here.
      02-19-2020, 01:11 PM   #2
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
Wait, there are shift lights in the HUD?
      02-19-2020, 01:51 PM   #3
VipinLJ
VipinLJ's Avatar
If the update removed that, that totally sucks. Did you try disabling and enabling it again? Make sure it’s selected in all modes and not the sport mode option? If nothing works, call the dealer up and ask them? I’d be pissed too if an update disabled shift lights.
Car > Settings > Displays > Head-up display > Sport display - always on.
Shifter in M/S and use the paddles/shifter to shift in Manual mode. As the car nears the red line, the shift lights pop up on the HUD.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
RedKloud736.00
Pauleebe379.50
      02-19-2020, 02:27 PM   #4
Giggler
In sport/Sport+ there used to be with original 3/2019 firmware I had. When you were in sport/sport+ mode and you have sport display enabled, you will get a rev gauge and then right above it, you will get a shift light that lets you know when to shift. I don't run manual mode that often because the automatic transmission shift logic is so good, but every now and then I like to play around with it and I miss this feature dearly.
      02-19-2020, 08:36 PM   #5
Giggler
Problem Solved: The vertical height adjustment of the HUD was set too high and the top edge of the HUD was hidden/obscured. Because the shift indicator light is located at the very top edge, it will not be visible if the HUD is adjusted too high.
I was driving like a hooligan taking it to redline over and over trying to figure it out and was almost ready to do a factory reset... haha. Carry on, nothing to see here.
      02-22-2020, 03:04 PM   #6
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Wow, sure am glad I read this thread!
My M340 is first automatic I've had since our station wagon phase. Have been working on using the paddles & am almost comfortable. The big thing I still had to work through was when to shift because the car handles so effortlessly.
Though I have the horizontal tach in the HUD, I never noticed the the redline at the top of HUD -- until now!
Thanks!
Al
Retired: 2014 328i
BMW CCA
Giggler408.00
      06-04-2021, 06:32 PM   #7
merlin99
Drives: G20 330i
I going to try this too, been bugging me for ages
      06-05-2021, 03:23 AM   #8
Mav281
Mav281's Avatar
11
Drives: 2017 BMW M4
Similar issue here, sure I have seen other threads on this as well. I have a 20 plate UK G20 330e. Since the last update I can see the sport gauge if I set it to always on, but if you set it to Sport mode only it no longer appears when switching into sport mode. Changing the height of the HUD makes no difference.
      06-05-2021, 04:55 AM   #9
phayze
Drives: BMW
Hi,
For this, you need to code to fix the issue.
