2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Rear Tyres
View Poll Results: Which rear tyre would you choose?
Pirelli P Zero 10 43.48%
Bridgestone Potenza S001 1 4.35%
Goodyear Eagle F1 Asymmetric 3 12 52.17%
Voters: 23. You may not vote on this poll
      02-21-2020, 04:35 PM   #1
Andy3661
Andy3661's Avatar
122
Rear Tyres
So im about to have my first tyre change on the rear and looking for some advice for rear 19". 255/35 R19 96Y RSC
Options i have from my local KF are:
Pirelli P Zero
Suggestions are welcome and can i change the tyre index from 96Y?
      02-21-2020, 05:05 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Why would you want to? Insurance usually requires the door plate rating, or higher spec. The XL equivalent will require a higher figure, (100XL).
      02-21-2020, 05:10 PM   #3
Phippsy81
Phippsy81's Avatar
79
Drives: G20 330i M Sport Plu
Pirelli P Zero
I'm going to go with the Goodyear. I've run both the S001's and the older GY Eagle ASY 2's and personally preferred the Goodyear.
IMO they were more comfortable, ran quieter, and had comparable performance to the Bridgestone S001.
I've not run the newer GY ASY 3, but the reviews seem to be good, and suggest they are indeed an updated/improved version of the ASY 2.
I'm looking to switch the god awful Bridgestone Turanza that it came out of the factory with to the Eagle 3 myself....
J
330i M Sport Plus
Previous- 435D M Sport
      02-21-2020, 05:54 PM   #4
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Michelin Pilot Sport 4 S. non run flat performance tyre...
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      02-22-2020, 07:46 AM   #5
OM3RTA
391
That's what I'm thinking for mine.
      02-22-2020, 12:41 PM   #6
Tam the Bam
Grumpy Old Git
443
That’s what I have..... came on the car from new.... been ok this winter so far and looking forward to the warmer weather to really try them out.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
OM3RTA391.00
      02-22-2020, 01:23 PM   #7
OM3RTA
391
I have Potenza's and they have been pretty good also but have heard and read non RFT's give a much more comfortable ride and with the PS' having such a good rep it seemed an obvious choice.
      05-12-2021, 07:36 AM   #8
Simon-BMW
Drives: BMW G20
Pirelli P Zero
What tyres did you go with in the end? How have they performed?
      05-12-2021, 11:03 AM   #9
Axeman15
Axeman15's Avatar
62
I have the dreaded Turanza RFT fitted but will be dumping them in favour of Potenza RFT.
I considered a change to Pilot Sport 4S but decided against this in the end and to stick with RFT.
Lets hope I don't regret it - if I get it wrong and they are just as bad as Turanza's, I won't have long to wait until they need changing again.
      05-12-2021, 02:17 PM   #10
verysideways
Lateral grip estimator
verysideways's Avatar
957
Drives: i4, M2
That's what i have too. Changed before i even collected the car from the dealer. Very happy.
'20 BMW M2
'23 BWM i4 Mora
'10 Porsche 997
'02 Morgan Aero 8
http://petrolhead.tours
      05-12-2021, 04:10 PM   #11
ROSSCOE
ROSSCOE's Avatar
17
Drives: G20 M340i SUNSET ORANGE
Changed to Pilot Sport 4S from Bridgestone Turanza’s at 3,000 miles, best decision I made, changes the car handling so much for the better, managed to get the BMW approved * star marking after a bit of searching. Still got the Bridgestone to sell, will eventually get round to it.
      05-12-2021, 05:15 PM   #12
Andy3661
Andy3661's Avatar
122
Pirelli P Zero
I went for the Pirelli P Zero in the end.
Can really tell the difference with the handling especially in the wet and compared to the Turanza the road noice has massively reduced.
      05-13-2021, 04:26 PM   #13
a.summers86
a.summers86's Avatar
192
Drives: BMW G20 MSport Pro
How does everyone find the awful tyre wear on the rears?
Is it just the turanzas that suffer from this or is it across the board with Perelli and good year?
      05-13-2021, 06:40 PM   #14
Keith_C
Keith_C's Avatar
179
Drives: BMW 330i M Sport Plus
Currently on 16500 miles on my PS4s and around 3.5mm all round
      05-14-2021, 03:33 AM   #15
hamera
hamera's Avatar
442
Drives: 320i M Sport (G20)
Very similar here. Michelin PS4 (not PS4 S, because 18" alloys)
Just got it serviced at 14,5000 miles
Front 4.5mm
Rear 3.5mm
      05-14-2021, 05:27 AM   #16
Axeman15
Axeman15's Avatar
62
My rear Turanza's are a whisker above the TWI at 12,593.
It went in for a free check in Feb and were 3mm at 11,472.
      05-15-2021, 05:19 PM   #17
a.summers86
192
The turanzas are shocking on the rear with a staggered set up. Fronts wear evenly 5.5+ all across after 10.5k miles.
Rears are 3mm in the centre and 4.5mm at either edge.
Always run the correct pressures. You can physically see how they wear in a V when the car is off the ground on the lift.
I do most journeys on th3 motorway and drive smoothly and not particularly hard so can’t even blame this on the wear.
      05-23-2021, 04:39 AM   #18
Drew474
Drives: M340i xdrive
The bridge stones are shocking tyres (turanzas). I had to change my rears at around 7-8k (puncture forced my hand, but were worn in the middle).
Finally ditching the run flats on the car today!
      05-23-2021, 06:48 AM   #19
goodbyalfa
King of the North (living in the east...)
goodbyalfa's Avatar
1056
Drives: M340i mineral white
A fair bit of motorway in there, in the daily commute, but my rear bridgestone potensa s001 were changed at 36.5k Miles on my F36 440i gc. The fronts lasted till 47k Miles...!!!
They are called bridgeSTONES for a reason...
2021 M340i in mineral white, options galore
Previously
2018 440i GC in MG
2015 330D F30 MSport EBII
2012 Alfa Guilietta 2.0d Veloce
2009 Fiat bravo sport
2000 ST Mondeo
      05-23-2021, 07:56 AM   #20
danorman777
danorman777's Avatar
102
Drives: M340i Touring
I wish BMW would let you choose tyres as per other options. They do on some M models and the 128ti.
It would also be good to be able to choose all seasons.
      05-23-2021, 08:35 AM   #21
HighlandPete
The problem is, All Season have never been really on the radar for BMW saloons/tourings in the UK.
Wasn't many years ago BMW UK didn't even support winter tyres. From BMW's perspective, you were on your own for winter tyres.
Besides, All Season never had a good press either, "the jack of all trades, master of none" tyre. Things have changed, but some of the best All Season tyres are still not available in the UK.
      05-23-2021, 08:41 AM   #22
danorman777
102
They are definitely a compromise but are getting better. Michelin Cross Climates get very good reviews and are available here. Sadly it is hard to test them out before buying!!!
