03-13-2024, 12:46 PM | #1 |
Rep 7,026
Drives: 2022 DG/BLk xDrive M4C Wk 34
Some of us had a feeling that this was coming. With a significant reduction in price. This has now been confirmed by part numbers separating the LCi style Laser lights from the original CSL Laser lights, released on the G82 CSL.
Please confirm part number compatibility by VIN, before purchase. This post is for informational purposes, only and I am not responsible for you not verifying and ordering the correct part numbers. Update on coding requirements. There is a flicker that we are working out. This has also been confirmed to function the same on the original CSL tail lights when retrofitted to a G8X. If you read into the thread, it can be coded out. If you’re willing to live with it, thats up to you, personally. If you want the turn signal and the brake light separated, the lights need to be coded, and a wire needs to be added to a plug in the passenger side footwell. The part numbers have been taken directly from a 2025 G82 VIN number, and the ECE tail light part numbers, have been provided by 2 separate shops in Germany. BMW G82 LCi Tail Light part numbers: Pricing seems to be falling into the $2,200 to $2,400 range, for all 4 light pieces. US: 63215A37AB5 63215A37AB6 63215A37AC3 63215A37AC4 ECE RHD 63215A37AB3 63215A37AB4 63215A37AC1 63215A37AC2 ECE LHD: 63215A37AB3 63215A37AB4 63215A37AB7 63215A37AB8
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
03-13-2024, 01:00 PM | #2 |
Rep 2,743
Drives: 2024 M4 Convertible
Is there a separate part number for the G83?
I've never paid attention to it, but what is the stock functionality? (turn signal and brake light separate vs same) |
Limegrntaln13676.00 |
03-13-2024, 01:03 PM | #3 | |
Rep 752
Drives: 22 M4c vert
All we need to do is the coding, and we get the oem euro separated turn signals (or Sequentials like on my aftermarket csls) |
03-13-2024, 01:03 PM | #4 |
Rep 570
03-13-2024, 01:25 PM | #5 | |
Rep 7,026
In the US model, both of these, together are brake lights, and both blink together, for turn signals. White car is US Spec. Where both blink, together, and gray car is just the Euro turn signal blinking.
YT: G Dubyou |
03-13-2024, 01:53 PM | #6 | |
Rep 570
Small difference, but it looks much better the euro way. |
03-13-2024, 01:54 PM | #7 |
Rep 7,026
Do updates kill the coding? And the G83 for some reason, has the wiring and the G82 doesn’t.
YT: G Dubyou |
03-13-2024, 02:14 PM | #8 | |
Rep 570
Then again -- it takes 5 minutes to redo. Still annoying though. There's some other great euro options to pick from too (i.e. kill the amber illumination when the headlights are on at night, brake force display, etc.) |
Limegrntaln13676.00 M4Tejas843.00 |
03-13-2024, 05:55 PM | #9 | |
Rep 2,743
Limegrntaln13676.00 aktif81044.00 |
03-13-2024, 06:39 PM | #10 |
Rep 7,026
The G82 is plug and play as well. Just the G83 has that wire to separate the turn and brake, if you code it in. The G82 needs the wire run from the passenger floor kick panel fuse box.
YT: G Dubyou |
03-15-2024, 09:52 PM | #11 | |
Rep 528
thanks man Order #xxxxx Placed on Mar 18, 2024 Status In Progress Processing items Item Part # Quantity Amount Status ETA Rear Light In The Side Panel 632010 63-21-5-A37-AB5 1 $544.04 - Rear Light In The Side Panel 632010 63-21-5-A37-AB6 1 $544.04 - Tail Light Tailgate Left 632010 63-21-5-A37-AC3 1 $544.04 - Tail Light Tailgate Right 632010 63-21-5-A37-AC4 1 $544.04 -
03-16-2024, 12:42 AM | #13 |
Rep 553
Drives: 2022 G83 M4
Can confirm updates kill the coding and it reverts to us coding but is super easy to code back to the Euro way. Time to do some shopping
2022 G83 M4 Convertible Isle of Man Green on Tartufo Instagram:kermit_g83
2020 GLE 450 Emerald Green on Macchiato Beige - wife and baby mobile 2016 M3 TB on SS - gone but not forgotten |
03-16-2024, 03:37 PM | #14 |
Rep 7,026
The prices don’t matter. The picture was so wide screen, I needed to zoom the part numbers to see it on the phone. So, it inadvertently cut off the prices. I called my local dealer with the part numbers and they told me $4,470.63. Plug the numbers in, online and you can find them for $2,300ish shipped.
YT: G Dubyou |
03-16-2024, 06:19 PM | #15 |
Rep 56
Can anyone speak to if the seals are needed too?
Also what's the protective film about? |
03-16-2024, 08:10 PM | #16 |
Rep 7,026
The whole page is other parts of the rear trunk/ boot section. Just pay attention to the tails. They should come complete ready to install.
YT: G Dubyou |
MasterM58.00 |
03-17-2024, 12:38 AM | #17 | |
Bodeine Brazy™
1269
Rep 895
Also on the Euro spec, the bottom brake light is what blinks for turn signal.
Limegrntaln13676.00 dynebolik30.00 |
03-17-2024, 12:43 AM | #18 | |
Bodeine Brazy™
1269
Rep 895
I paid $5,895.00 for a set of CSL Laser (Euro Spec) last year. I plugged in the numbers for the LCI Laser on the same website and it's $2308.64 without shipping and taxes.
03-17-2024, 01:32 AM | #19 |
Rep 553
Drives: 2022 G83 M4
This is what I'm trying to figure out. IS there a difference functionally/aesthetically between the CSL and LSI lights?
03-17-2024, 01:51 AM | #20 |
Rep 25
I would rather have the ones fitted in my car.
03-17-2024, 05:38 AM | #21 | ||
Rep 7,026
BMW needed to find a cheaper way to produce them, or they found a cheaper supplier for the lights, before the decided to install them on every single 2025. Having a set of $8,500 (retail) tail lights on every single car, without raising the price of the car to compensate for it, doesn’t seem like a good move. When you get to the end of the build, and look at the summary page on the build, the tail lights are installed on the car. The only plausible option is, they’re standard. I believe it’s already been confirmed that they are standard, I just can’t remember where I read it. And it’s 3am, so, I’m not going to go looking. Looking at the pictures, up close, the main difference I was looking for, was the yellow triangle laser sticker, denoting that they are in fact laser and not just LEDs, like most of the alibaba knock offs. Even alibaba has some real laser tails. And the actual LCi tails, do say “BMW Laser” on them. I don’t see any noticeable differences. I ordered a set, but, I don’t have any real CSL tails to compare them to. I probably need to get a hold of Skyscraper as he’s local to me, and has a real CSL set on his G82. He would be able to see if there were any difference with them. I called my local parts counter, who doesn’t discount anything, and actual MSRP, according to them, is $4,470. I was able to get mine for $2,3xx. I had them ordered at another place, for $2,081 shipped, but they cancelled my order, saying, if they couldn’t get them within 10 days, it was their policy to cancel the order. What I really think, is, they didn’t know about the part number and when the price was added to their order guide, it was too cheap, and when you order parts from this place, anything over $899.00 ships for free. So, they were also eating shipping. $577 is too high. I paid $544. The place that cancelled my order, was $520. But, they claimed they don’t do special orders that take more than 10 days to get.
YT: G Dubyou Last edited by Limegrntaln; 03-17-2024 at 05:58 AM.. |
M4Tejas843.00 |
03-17-2024, 08:02 PM | #22 | |
Rep 845
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
