11-27-2020, 12:09 PM | #23 | ||
Rep 1
12-01-2020, 09:14 AM | #24 |
Rep 110
01-08-2021, 01:28 PM | #25 |
BMW M2
497
Rep 322
10-23-2021, 07:12 AM | #26 |
Rep 3
Drives: BMW X3
Thanks for that, very helpful!
02-05-2022, 04:41 PM | #27 |
Rep 2
In my search for a fuse box diagram, I came across this post and it helped me out installing my dashcam.
It's only fair I also post the fusebox specific to my car, downloaded via the link in the first post. This is for a 320e. I got my 320e last summer (August 2021), but I think it is still model 2020, not sure on how the years work exactly. Anyways, the dealer told me to preferably not touch the fuses in the passanger footwell (FB right), so I originally used F252 for the BATT connection, and F214 for the power connection. It seems F252 is not suitable for the BATT connection as it is also switched and turns off a couple of minutes after closing the car. Weirdly enough though, it stays powered when the trunk is still open and everything gets switched off. I've now connected the BATT cable on F258. If this one doesn't work, I'll try to figure out a connection in the back that does work permanently. |
02-07-2022, 05:36 AM | #29 | |
Rep 2
But as I'm not a car/electronics expert, I don't know what connecting something additional to that line might cause in terms of issues. I do know from RC experience that batteries is not somthing to mess with. I'd rather have you go to an official dealer asking them for advice, maybe even let them connect it for you. On a side note (why I don't mess with batteries): Read up on LiPo and LiFePo batteries and fire hazards also please. I personally wil never ever let my RC LiPo batteries charge unattented or store them outside the battery vault. I've had one LiPo battery swell/pop and had to make it safe by purposely igniting it, putting a stake through it. These are fires you can't extinguish. This is also the reason I chose to hardwire my dashcam. I even refuse to put my car inside my garage because of it being a hybrid one. I'd rather have a roof then a car... |
euro_syd1.50 |
02-19-2022, 12:14 PM | #30 |
Rep 771
Anybody know where and which fuse is for the steering wheel horn in a bmw G20 M340ix. I disconnected the rear battery but the horn still sounds. Thx
02-19-2022, 01:13 PM | #31 | |
Rep 395
This will show you they can't, other can though |
02-23-2022, 05:26 PM | #32 |
Rep 771
07-30-2022, 03:10 PM | #33 |
Rep 1
2019 BMW X3 Front socket fuse replacement
Front outlet socket fuse for 2019 BMW X3 found under passenger foot panel, fuse F46. Unlock two plastic twist locks on each side of upper panel to drop down. Fuse block on upper right side wall. F46 fuse is on left. Bit of a contortion required to get to, but it is fairly straight forward. Use a fuse puller, remove and replace with standard 20 amp blade fuse. Reinstall cover and should be good to go.
No need to go to dealer as BMW suggests. Ever try to get an appt in last year? Not sure why it is as challenging as designed. |
08-03-2022, 08:56 AM | #34 |
Rep 1,687
This thread is really useful….however, just a heads up….the download I got for my 840 from BMW using my VIN is highly inaccurate so I would tread warily when referring to the download for ‘your’ car…..
03-17-2023, 10:09 AM | #36 |
Rep 42
Drives: 2020 BMW M340i XDrive
I pulled out F203, which is a 7.5A Fuse.... this kept my exhaust valve open all the time.
2020 BMW M340i XDrive in Arctic White
MHD Stage 2 Tune, xHP Stage 3, Active Autowerke Catted Downpipe, MST Cold Air Intake, H&R Lowering Springs, Spacers, M Performance Lip and Side Skirts, Exhaust Valve Mod, Blackvue 900S Dual Dashcam and Blackvue Backup Battery If you're in Perth, feel free to join our Facebook group "Perth BMW G20 Group" |
