Technical Topics DIYs and Coding Discussions G20Can I code the automatic speed limit assistant?
      02-12-2020, 07:25 AM   #1
king YU
king YU's Avatar
Drives: G20
      02-13-2020, 02:33 AM   #2
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
That is not something you can code, your car have to be born with it.
      02-13-2020, 03:57 AM   #3
king YU
king YU's Avatar
Drives: G20
My original car is equipped with a professional driving assistant (sa5AU), but I don't know how to code
      02-13-2020, 10:36 AM   #4
Basti@G20 320D
Sweden
25
Maybe China don't allow automatic speed limit change.....try to ask BMW
      02-14-2020, 01:42 AM   #5
Basti@G20 320D
Sweden
25
https://www.bimmerfest.com/forums/sh....php?t=1315659
try this link
      09-05-2020, 10:36 PM   #6
juhcobywankenobi
Drives: 2019 BMW 330i
2019 BMW 330i  [0.00]
Originally Posted by Basti@G20 320D View Post
This link appears to talk about Speed Limit Info, my car already has that. Is it not possible to code the automatic speed limit adjust for active cruise control in the US?
      09-06-2020, 12:08 AM   #7
ifr
ifr's Avatar
1198
Drives: Tesla MY LR AWD
I put these codes together which work fine on a G05 etc so should also work on the G20.
https://drive.google.com/file/d/1sLa...ew?usp=sharing
      09-06-2020, 03:55 AM   #8
juhcobywankenobi
Awesome thanks @ifr!
Out of curiosity why are the last block of modules/functions crossed out?
Gonna try these soon, this will get me closer to what I want the car to do during assisted driving.
      09-06-2020, 05:53 AM   #9
ifr
ifr's Avatar
1198
They are set on a UK car but don't appear to be needed. You can set them if you like.
      09-07-2020, 05:30 AM   #10
dominguez255
Drives: BMW Serie 1 F40
I have the speed limit assistance that allows me to manually accept the limits, I have activated to test the automatic, in BDC >> AUTOMATISCH, STRECKEN_VERLAULF, VORAUSSCHAU, VOFFSET_LANGSAM, VOFFSET, in the HU_MU
SLAAUTOMATISCH, STRECKENVENRLAUF, VORAUSSCHAU, VOFFSET AND VOFFSET_LANGSAM, I get the option in the idrive and it lets me accept it, but then when it comes time to work, it does not change the limiter or the cruise alone, I think I need to activate the SAS2, but with bimmercode I can't
      09-07-2020, 12:10 PM   #11
ifr
ifr's Avatar
1198
You can't code aSLA with BimmerCode. You need esysx.
      09-07-2020, 03:16 PM   #12
dominguez255
Ahh okey , then i forget about it
      09-11-2020, 11:57 PM   #13
juhcobywankenobi
Almost..
Using your coding sheet @ifr I almost got aSLA working. The car goes 10mph above the set speed, but unfortunately, the auto-adjust does not work and a warning pops up about "not active in your country".
My G20 does not have SAS/42C1, but I did find all the functions in the DSC_VIP_IB2/3D78. However, it errors out when I try to code it in that module.
Any help would be really appreciated!
Btw, any idea what "2nd adjustment up to 40mph" is? The limit is still 10mph over or under.
Here is the error from esys:
DSC_VIP_IB2 [39]
cdDeploy FinishedWithError
cafd_00003d78-007_010_102 NotExecutable
Here are the images:
      09-12-2020, 01:30 AM   #14
ifr
ifr's Avatar
1198
DSC_VIP_IB2 [39]
If you have DAP then you have SAS. If you don't have DAP it won't work.
Make sure you connect in diagnostic mode. This should also address the VIP issue, but VIP coding should not be necessary and won't substitute for SAS, which is why you are getting the country error.
The second speed allows you to set 2 speeds . 1 up to 40mph and the other above 40mph. I set up to 40 at +2mph and above 40 at +5. This ensures I won't get a speeding ticket
      09-12-2020, 01:41 AM   #15
juhcobywankenobi
DSC_VIP_IB2 [39]
Apologies, what js DAP? And for that matter SAS?
I've not done esys in diagnostic mode. Gonna see if I can figure that out right now.
And thanks for the quick response! It is much appreciated!
      09-12-2020, 01:50 AM   #16
juhcobywankenobi
DSC_VIP_IB2 [39]
Silly me, I read the ecu with the engine off. Apparently that's a rookie mistake! But I'm a rookie. Thanks again!! Gonna try to code it now using the SAS functions.
      09-12-2020, 02:19 AM   #17
juhcobywankenobi
Test drove it and it worked pretty well, I was happy with the changes in speed, not too abrupt and nice to have it.
Though not all went well, for some reason my driver assistance view in the instrument panel was dark. In fact nothing was coming up anymore including the map. The speedometer and everything were working fine. Also noticed in the HUD the cars it detected were not coming up either...
      09-12-2020, 03:11 AM   #18
ifr
ifr's Avatar
1198
That doesn't sound related to the aSLA coding as the only times I've seen that behaviour is due to changes in DKOMBI. Have you made any changes there too?
My approach would be to first let the car sleep, then confirm the issue is still prevalent. Then revert your aSLA changes only. If that fixes the issue then document the difference in codings for each ECU between what you have set at your car and what the spreadsheet lists i.e. document what you had to change for each ECU. Then you will need to to troubleshoot the codes that may be causing the issue. I can recommend the codes to try first.
I'm not sure if others have coded aSLA on G20. I know G05/G07 have been coded without issue.
      09-12-2020, 05:52 AM   #19
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
@ifr,
Is the reason you can't code auto Speed Limit Assist with Bimmercode is that the SAS module is not included? If so, I contacted developer and he said it's on their to do list, but no date set up yet.
BTW, what does VIP stand for -- in this context, of course?
Al
Retired: 2014 328i
BMW CCA
      09-12-2020, 07:01 AM   #20
ifr
ifr's Avatar
1198
@ifr,
Correct.
Virtual integration platform:
https://g20.bimmerpost.com/forums/at...8;d=1550722478
      09-12-2020, 01:42 PM   #21
juhcobywankenobi
@ifr,
Correct.
Wow this is super helpful thanks!! Now all of these acronyms make a lot more sense.
I let the car sit overnight and that seemed to do the trick, how odd. I shut it off and locked it last night, but it still was coming up blank. Now it works tho, hopefully will continue to do so.
      11-23-2020, 01:57 AM   #22
skuld
Drives: 318i
Hi @ifr
Link lost.
This link is invalid, can you share it again?
Thank you.
