03-01-2021, 04:18 AM | #23 |
Rep 619
It can be - I have seen a video on YT about it.... But I also read it can be detected by BMW service, even if re-enabled... so could be a warranty issue... personally I'd avoid that option
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
03-01-2021, 04:46 AM | #24 | |
Rep 320
I did a res delete on my GTI Performance and the economy suffered a lot as the noise was so addictive it was hard just to tootle around anymore!
Arrived: '20 330e M Sport in Mineral Grey
'03 MY 996 Turbo in Arctic Silver Gone: '18 Golf GTI Performance DSG in Tungsten |
03-01-2021, 09:37 AM | #25 |
Rep 8,081
Surprised at how much difference it actually makes to the noise.
In the end I decided against removing the spring link from the actuator to the flap. Whether the flap is open or closed the spring provides some pressure against the end-stop - I'm guessing that was done as a metal flap in a metal tube could make a terrible noise if it rattled even slightly. I let the valve open (with a resounding clunk) in sport mode and then unplugged the actuator. I covered the socket with some waterproof tape and placed the connector into a small poly back secured tightly with a cable tie, and then cable-tied the plug to the bracket to stop it flapping about. Works OK Unfortunately I'm buggered if I can get pictures to appear correctly.
Ian
Jim_330e144.00 |
03-04-2021, 07:31 AM | #26 |
Rep 320
Just went out to try and do this mod. Ran the car for 10mins or so in Sport mode and the flap stayed firmly shut. I went around the block and pulled up and there was a tiny bit of steam from the right pipe but the valve still looked shut. When I got home, I had a poke at the spring and putting some pressure on it could hear the valve start to open and make some noise but didn't want to try and force it open with it still plugged in etc. Any advice?!
03-04-2021, 07:47 AM | #27 |
Rep 8,081
I wouldn't force it but I found that it opened (with a 'clunk') in sport mode and at full operating temperature.
On the 330e though Rich mentioned that it seemed to open and close during idle so maybe you'll have to be patient. As far as I know, it's either open or closed though, it doesn't partially open. Don't know how much difference it makes on the 330e but on the 330i it's a very satisfying burble. I'd guess the 330e is the same as it's essentially the same engine.
Ian
gorthol62.50 |
03-04-2021, 07:48 AM | #28 | |
Rep 285
03-04-2021, 07:51 AM | #29 |
Rep 8,081
If you can do that on the 330e then that's the way to go - just set the exhaust to be permanently in sport even if the rest of the car is in comfort. I don't know if it's the same on the 330i I haven't looked. But I will...
Ian
03-04-2021, 08:02 AM | #30 |
Rep 320
Cheers guys. I thought setting the noise preference was just for the fake noise in the car?
Also, on the 330e is there even a Comfort setting? This was what was advised during the recall but I only have Sport, Hybrid, or Electric?
03-04-2021, 08:09 AM | #31 |
Rep 285
I thought it was to warn those people who think a car park is just for pedestrians as they aimlessly push their shopping trolley down the middle of the road? So many people need running over when I'm in stealth mode
Jim_330e144.00 |
03-05-2021, 02:17 AM | #32 |
Rep 8,081
On the 330e I think that setting is just for the fake noise as it changes even if the engine is not running so it's unlikely to open the exhaust flap. I think it will need to be disconnected or modified.
Ian
03-06-2021, 08:36 AM | #34 | |
Rep 13
I'm trying to this on my 330e today but having no luck getting the valve to open 🤔 Had it running in sport on the drive for about 20 minutes with no change, took it round the block and back and still the same when idle afterwards? Any advice? Cheers James |
03-06-2021, 09:06 AM | #36 | |
Rep 34
See if that works. As previously mentioned, the valve opened and closed multiple times during idle. Removing the spring and tying the valve open solves this issue. |
03-06-2021, 09:33 AM | #37 | ||
Rep 13
Will try it again tomorrow |
03-07-2021, 08:55 AM | #38 | |||
Rep 13
03-09-2021, 03:48 AM | #39 |
Rep 619
I observed this yesterday with new 330e that arrived, in Sport mode (Xtraboost), both flaps fully open at startup and idle... and stayed open... I could see it and the mist coming out the right as well
It does sound much nicer than I thought for a 2.0l, nice little growl I have set the internal fake sound to reduced, and all is well I'm on 11.2020.57 if that helps
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud Last edited by jedpause; 03-09-2021 at 07:48 AM.. |
03-12-2021, 01:08 PM | #41 |
Rep 861
Same here. only checked a couple of times, but with xtraboost selected, nothing from RHS tail pipe.
Also tried different settings for Engine Sound, in case that had a bearing. Not too fussed as no intention of forcing it open as I'm at the age where I'd rather drive in silence, but would be nice to know the option was there.
