07-21-2020, 08:43 PM | #1 |
Rep 102
G20 Working 3rd Party Wireless Charger!
Hey guys! So I've seen a few others post about how annoying it is to have a G20 with the digital key card feature (NFC) but not the wireless charging.
I can happily say I've found a wireless charging solution for those of us that did not get the wireless charging option from the factory. I've included the link to the wireless charger on Amazon below. I can confirm that it does work perfectly and fits extremely well in the phone tray. In the description it does indicate that it will not work if the car has NFC and it also indicates that you need to remove the rubber tray liner before installing. Both of those seem to be false. Its working flawlessly in my car (Yes, unfortunately Apple Pay is still triggered sometimes). I installed it with no issues and did not remove the rubber tray liner. From what I've noticed it charges my phone about 5% every 30 minutes or so. It uses the existing USB port in the cupholders and in my opinion looks fantastic. I can post pictures of my install if people want to see what it actually looks like! Wireless Charger Link: https://www.amazon.com/CarQiWireless...5381995&sr=8-2 Last edited by exhibhooligan; 07-22-2020 at 12:12 PM.. |
07-22-2020, 11:07 AM | #3 |
Rep 342
Drives: G20 330ix M Sport
Do you have install photos?
07-22-2020, 11:52 AM | #4 |
Rep 102
I'll post install pictures today. It's easy to install. The only thing I did different then the instructions was I added a few pieces of 3M double sided tape to the bottom of the charger. Probably not necessary at all but I wanted to future proof against rattling. Then just stick the charger in the phone tray and that's it!
07-22-2020, 12:32 PM | #5 |
Rep 102
Not the best pictures but it shows how clean the install is. Basically put a few strips of 3M double sided tape on the bottom (prevent possible rattling), stuck it to the existing phone tray rubber pad and that's it.
The cord length is almost perfect but I tucked it in slightly under the wireless charger (they have a cut out specifically for that). Other then that it's an extremely clean install that I'm pretty happy with. |
07-31-2020, 09:13 PM | #7 |
Rep 92
07-31-2020, 11:46 PM | #8 | |
Rep 102
I do think the usb is limited to 5w since it's just a normal usb-a port. But, it still charges at a pretty decent rate. The charge pad is rated for 10w power but it says in the description you need to use a separate adapter in the cigarette port if you want to take advantage of the full 10 watts. If you're using wireless CarPlay it's fantastic to be getting a little bit of charge instead of nothing! |
08-01-2020, 01:58 PM | #9 |
Rep 13
How often does the NFC pick up ApplePay? I had something similar and cheaper, but it picked up every 10 min so I had to remove.
exhibhooligan95.00 |
08-02-2020, 12:56 AM | #10 | |
Rep 102
But, if I wait to put my phone on the charging pad after I've started the car I've only had 2 instances of Apple Pay being triggered out of around 50-60 times so far. The good thing is even if I place my phone on the charging pad before starting the car and Apple Pay is triggered. The phone still begins to wirelessly charge even if the Apple Pay screen is on. And once Apple Pay figures out it was a false alarm the screen goes away in around 10-20 seconds for me. So no real harm even if the Apple Pay screen gets triggered. Your phone is still charging wirelessly. |
Tags |
g20, wirelesscharging |
