Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Which G20 models will have the B58 engine?
      02-07-2018, 03:41 PM   #1
bimmer456
Drives: 340i
So I read a post earlier that indicated there would be two models with the B58 but no mppsk to add on or port install. Something like a 340i and a M340i with 350 and 380 horsepower? Anyone have any confirmation what this will look like?
      02-07-2018, 04:38 PM   #2
Weiman
Weiman's Avatar
Sweden
154
Drives: BMW 116i M-Sport -14
There will no 'regular' 340i, just the M340i with 380 hp or more.
http://g20.bimmerpost.com/forums/sho...99&postcount=1
Last edited by mkoesel; 02-07-2018 at 08:35 PM.. Reason: Changed link domain name to match this forum
      02-08-2018, 03:51 AM   #3
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
2959
Drives: 340 6MT, 50e, others
      02-08-2018, 07:45 AM   #4
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3449
2020 BMW M340i  [0.00]
Just M340i
jpichardo@tulley.com
      02-08-2018, 11:54 AM   #5
nozydog
Driver
nozydog's Avatar
465
Drives: 2020 X2 M35i
Originally Posted by eluded View Post
I’ve heard from a very reliable source that there will be both 340i & M340i. Personally I doubt it, but anything could be decided between now and production, which doesn’t start for at least another 8 months!! Mind you with no standard 340i there’ll be one huge gap between 330i (270hp) and M340i (370hp) obviously these are estimated hp ratings
      02-11-2018, 10:43 AM   #6
Blubaron79
Blubaron79's Avatar
Drives: 2021 M340i xDrive
You could be correct, but I doubt this. Look at all the other lineups.
5 Series for example:
530 as the entry level
540 as the middle tier
M550 as the top dog (not including true M Models)
3 Series should be similar:
320 (rumors are saying it could go away)
330
M340
Cheers!
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive
      02-11-2018, 11:38 AM   #7
nozydog
Driver
nozydog's Avatar
465
330
M340
Cheers!
Here in the uk entry level is 520i with 530i & 540i (M550i coming later I assume) so there is one standard 6 pot before M550i...
My source suggests the 3 range will consist of 318i (UK only?) 320i, 330i, 340i & M350i but he may just be assuming it will follow the 5 range!! I think what you suggest is more likely!
So the 5 gets a standard 6 pot car, but then it is a MUCH bigger car!
      02-11-2018, 08:58 PM   #8
TheBingoBalls
TheBingoBalls's Avatar
Drives: BMW
All 40i models will now become M40i indicating the top trim for that particular model.
nozydog465.00
      02-12-2018, 02:41 AM   #9
frankchn
Drives: F90 M5
Don't think a M350i is possible -- the 50i badges denote the N63 4.4L V8 across BMW's current lineup, and with the exception of the E90 M3s, no 3 series has had a V8 in it. A 450 hp non-M3 3-series will also be awfully close to the 475-500hp G80 M3.
A 375-hp M340i is much more likely, and it will maintain the 100-hp gap between the top end series production cars and the base M car.
nozydog465.00
      02-12-2018, 04:08 AM   #10
nozydog
Driver
nozydog's Avatar
465
Also indicating the need for a higher price ... The power of the 'M' !!!
      02-12-2018, 04:10 AM   #11
nozydog
Driver
nozydog's Avatar
465
Ah right, I wasn't aware that 50i is reserved for the V8...
      03-02-2018, 10:49 AM   #12
RAV02
Drives: 2013 335
The price gap between the 330 & M40 IS JUST GETTING TO large. I have a 2013 335 and it was 5,000 for than the 328 in the base configuration. The 335 came standard with a $1500 sunroof so the price was actually only $3500 more. Now when you go from the 330 to M40 it is $12,000 in the X4 ( No M40 in the 3 series yet to compare ) So the gap used to be $3500 now it is 12,000, an additional $8500 for very little. The extra 35 HP cost BMW nothing, just different software. You do get variable dampening worth about $1500. Now the difference is down to $7,000 for basically marketing bullshit and things like slightly larger brakes that no one will ever notice. I believe BMW will be walking customers if they do not over a 340. Mercedes is doing the crap with their AMG cars. The lower priced AMG gives black brake calipers and the full AMG gives you red, wow. I hope BMW buyers are smarter than this and not buy into the marketing and badging hype.
      03-20-2019, 11:33 AM   #13
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
Production has started. M340's are already inbound to the U.S.
according to my dealer.
      03-22-2019, 11:31 AM   #14
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
If they do add a middle tier, it'll most like be an inline 4 with more power. Something like a 335i with about 300hp. I doubt they'd use another B58 in the lineup.
      03-22-2019, 01:23 PM   #15
bimmer456
Drives: 340i
They can use the inline 4 in the X2 M35i with 302 HP
      03-29-2019, 03:28 PM   #16
upsidedownfunnel
Drives: 2014 335i
Originally Posted by Railgun View Post
Closer to 14k base difference for the G20. Pretty crazy.
Well there really is no "base" 340i anymore though. The M340i is already fairly well optioned with the M Sport package, more standard features like the M sport brakes and differential and Nav/Live Cockpit Pro/Connected Drive and Carplay.
It sucks that you can't get a reasonably priced B58 option, though. But that's how everyone is doing it now. Audi has been doing it for a while, Mercedes started doing it recently, and now BMW. Basically most cars are the base 2.0T model and anything with a bigger engine requires you to buy the high performance model: either the S4, C43 AMG, or the M340i.
Sales-wise it probably makes sense. Much like how it "makes sense" to stop making a manual transmission 3 series. Oh well.
