03-17-2021, 03:43 PM | #265 | |
Rep 1,177
I couldn't notice the difference with the slowing down for bends as my car was doing that before without the nav activated. However, loving the indicator action I got to try a couple of times but looks like it's not blindly slowing down when you use the indicator, but actually using nav data to judge when you need to turn. I use my active cruise a lot round town as it just ensures i keep the speed down so this is really useful. |
03-17-2021, 04:25 PM | #266 |
Rep 1,587
Good to hear! Also means you dont need bmw nav running to get the integrated drive assist, so can use google maps etc
What was your SWA set to? USA or CatC? |
03-17-2021, 05:30 PM | #268 |
Rep 1,177
03-17-2021, 05:37 PM | #269 | |
Rep 1,587
You could test and see if it behaves the same as I saw then change it back if worse. Just odd as most changes for newer models are heading towards more autonomy and this one seems to be a step back I normally advise those with cat c to change to USA |
srbs73556.50 |
03-18-2021, 05:09 AM | #270 |
Rep 33
Drives: G02 3.0d Xdrive
With Bimmercode I cannot see any option that can help me seeing the Sport Plus and Comfort Plus in the central display, but only in the intrument cluster?!
Following latest update is there anyone coding and solving this issue?! Before the BMW latest update I was able to code that... Thank you. |
03-18-2021, 10:38 AM | #271 |
Rep 207
Hi,
Can i check, what do ANFAHR_ERINNERUNG do? |
03-18-2021, 11:37 AM | #273 |
Rep 1,228
03-18-2021, 01:40 PM | #274 |
Rep 1,587
If you dont code it (BDC and HU) then you wont get the Green light reminder options, and wont be able to configure how soon it reminds you to set off when the light has changed to green, when not paying attention.
Also translates to 'get honked less often' |
03-18-2021, 04:44 PM | #276 |
Rep 423
No, it won't make any difference I'm afraid. Charging the battery will only help you trigger the instalation process once the update is downloaded to your car.
03-18-2021, 04:45 PM | #277 | |
Rep 157
I'd expect when you get it pushed to you is a function of where your vehicle's at in the queue/tranche etc. dictated by the OTA campaign at BMW. HTH |
aquamaster7.50 |
03-18-2021, 04:53 PM | #278 | |
Rep 270
03-27-2021, 09:24 AM | #280 |
Rep 93
Does anyone know how to force an update?
I'm still on 07/2020.45 and when I search for updates it says there is nothing available Now my spotify is playing up, keep disconnecting Last edited by Kleev; 03-27-2021 at 10:00 AM.. |
03-31-2021, 04:47 AM | #281 | |
Rep 102
Just spoken to BMW U.K. and they say that .45 is the latest, obviously not correct. They say I will probably not get updated from 11/2020.45 to 11/2020.50 OTA. Very annoying as .50 required as a minimum to get Alexa working. BMW's update process is frustrating as sub-versions can have a big affect, but difficult to get the latest.
Mineral White 330i M Sport Pro
03-31-2021, 04:58 AM | #282 | |
Rep 1,587
Screenshot the 11/2020 release notes, including Alexa Integration and present that back BMW UK, who know next nothing in my experience. |
04-01-2021, 04:32 AM | #283 | ||
Rep 326
Had mine ready for installation for around 3 weeks with no sign of installation. This week I've been doing some decent commutes up the motorway, around 350 miles in total and during daylight. Went out on an errand last night and noticed that the stop/start had actually started to work again (not worked properly for months) which is reliant on state of battery charge and when I got home and pulled up, it instantly asked me to install the update. So 3 weeks or so it took to install and all because the battery wasn't charged to optimum which is a bit ridiculous considering the size of battery compared to what it's updating.
04-02-2021, 02:42 PM | #284 | ||
Rep 102
They say the only way to get it fixed from.45, is via the dealer network, who shouldn't charge for the update.
04-02-2021, 02:44 PM | #285 | |||
Rep 1,587
04-07-2021, 02:24 PM | #286 | |
Rep 242
what mean "CatC"? i wanted to test the codes provided by ifr to srbs73 (to adapt the route without navi) but even looking on google i could not understand what "catc" means thanks |
