Technical Topics Suspension / Chassis / Brakes Need help upgraded brakes on 340 ?
      12-06-2020, 09:24 AM   #1
Solid2021
Drives: M340
Hello I have a m340 my only complaint with the car are the brakes they lack much bite when initially pressing the pedal and just overall breaking power. I believe my only option are the red M performance calipers and disc.
I attached some pictures I want to confirm my calipers and disk are in fact a smaller size than the ones in the m performance kit ?
Any information on whatever the most affordable way to upgrade my brakes would be appreciated.
Had the ztk package description mentioned the upgraded brakes I would have at least tried to locate my car with the package.
      12-13-2020, 05:26 AM   #2
OM3RTA
391
If you did not order the Track Pack then you have the 348mm M Sport's in red, so you could locate the M Perf's 374mm calipers FRONT only, as the rear's DO NOT change in size, and then you'd need the uprated disks for both front and rear.
      12-17-2020, 02:51 AM   #3
Duckmann
Drives: G21 M340iX
Or you could go with G30 M-performance brakes in the front, they bolt straight on, but then you cannot fit the 18" wheel.
