08-12-2011, 11:55 AM | #1 |
Rep 4,709
Buying vs. Building A Gaming Desktop
I was browsing Alienware desktops and was wondering how much I could build an equivalent desktop by buying parts of a site like Newegg. I'm looking for a kickass system but not over-the-top ridiculous. Price point is <$1500.
Here are the Alienware Aurora specs: Intel Core™ i7-2600 (8MB Cache) Overclocked Turbo Boost to 3.9GHz Windows 7 Home Premium 16GB Dual Channel DDR3 at 1333MHz Dual 1.5GB NVIDIA GeForce GTS 450 - SLI® Enabled 1TB SATA 3Gb/s (7,200RPM) 32MB Cache Integrated 7.1 Channel Audio Single Drive: Dual Layer Blu-ray Reader (BD-ROM, DVD±RW, CD-RW) Matte Stealth Black Chassis with 875W Multi-GPU Approved Power Supply Alienware High-Performance Liquid Cooling Price: $1799 with $329.98 discount = $1469.02 How good of a rig can be built for that price? I was too lazy to try to build a comparable system manually off of newegg. |
08-12-2011, 12:07 PM | #3 |
One cam is enough
132
Rep 6,801
That's a pretty good setup for the price, although I've always been an advocate for single graphics cards on the initial build sheet, as opposed to using SLI or Crossfire right off the bat.
Also, their watercooling system.... Does it mix metals between components? That will cause all kinds of corrosion problems. There are some great air cooling options and if your case is in a place where it isn't blocked from ventilation and you don't mind the noise of air vs water, then just go with air cooling. Water is nice and all, but IMO if it isn't "needed", then stay away from it. If you do go ahead and do a water setup, places like NCIX have all kinds of components to build an actual good system, and it doesn't turn out to be very expensive that way either. |
08-12-2011, 12:18 PM | #4 | |
Rep 4,709
In all seriousness, I put together some comparable parts with some being a tad better and went over that price, so I'm thinking that's not bad. I wish they had an SSD option though. |
08-12-2011, 01:19 PM | #5 |
Rep 1,502
Try www.cyberpowerpc.com or www.ibuypower.com for some configuration comparisons. Great site.
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats, '16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold) |
08-12-2011, 01:34 PM | #6 | |
Rep 4,709
08-12-2011, 01:38 PM | #7 |
One cam is enough
132
Rep 6,801
Yeah a few years ago I had cyberpowerpc build a rig for me (before I started doing it myself) and everything was excellent. They had a great return policy, helpful customer service, and their prices couldn't be beat. If you're going for a built rig, use their site along with reviews from newegg and overclock.net and you can't go wrong.
08-12-2011, 02:30 PM | #8 |
Rep 3,288
Here you go. On average, you'll save $100-200 building yourself.
Everything is there except for a case, which you have a deficit of about $300+ to choose from.
08-12-2011, 04:32 PM | #10 |
One cam is enough
132
Rep 6,801
Yeah but you have to dig through some of the combos also offered on newegg (mobo/RAM/CPU or a combination of two of those or sometimes the PS or is in there, etc...) to see if there's a better deal. A lot of the time, they just include unpopular items or really expensive items, but sometimes they have some great combos.
08-12-2011, 04:45 PM | #11 |
Rep 3,288
There are no combos in my build above. I picked each part as a single item. Which leaves room for much further savings, should you choose to search for it.
For instance, there is a deal on G.Skill ram right now. 8gb (2x4gb) 1333 DDR3 for $34.99. Or there are many Case/PSU combo deals you could benefit from.
08-12-2011, 05:35 PM | #13 |
Rep 3,288
It is clear that you did not read my post, only look at the admittedly large picture.
So, I'll give you the benefit of the doubt simply because the picture was just so damn large and enticing. (And also since you seem to be new to the forums, Welcome.) Read this, from my post above. I chose not to include the case because you simply can't buy the exact same case, and the comparison would no longer be direct. Most decent cases can be bought for about $100.
08-12-2011, 06:18 PM | #14 |
Rep 959
I'm in the process of researching components for a new build and have a few suggestions:
1. Don't get an i7. I'm getting the i5-2500k and plenty of people have had success overclocking to 4-4.5ghz on air cooling. i7 is not too much of a step up so unless you want the best that's out there (stock), don't even bother. 2. Instead of 2 GTS 450s, I would suggest getting one more powerful card. I'm looking at the ATI HD 6950 2gb or 1gb...when the price lowers later on as more cards come out, then you can pick up a second one for cheaper and increase power even more. 3. Unless you're mad overclocking don't do liquid cooling. It's unnecessary if you're not pushing your rig to the limits of performance. 4. SATA 6 Hard drive instead of SATA 3, since it should be faster and not too much more expensive. 5. Buying components will definitely save you money over prebuilt desktops eg Alienware. This is my planned build: Core i5 2500k CM Hyper 212 Plus Gigabyte Z68-UD4 8gb DDR3-1600 CAS8 ram ATI HD 6950 2gb or 1gb 500gb SATA6 hard drive...probably wd black DVD rom drive CM HAF922 case So it's not high end but definitely should be good enough to overclock the i5 to 4ghz at the minimum and play games like bc2 and hopefully bf3 |
08-12-2011, 09:40 PM | #15 | |
Rep 3,288
08-12-2011, 10:09 PM | #16 |
Rep 959
I have a 1TB external if I need more space but I figure since it's for college, I'm not really going to use more than 500 gigs. I have only a few games and maybe 4 gigs of music so even 500 gigs is overkill.
08-12-2011, 11:35 PM | #17 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
The i8 needs a V8 amirite?
08-13-2011, 08:09 PM | #19 | |
Rep 959
08-13-2011, 09:33 PM | #20 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Not solely. A large SSD is way too expensive right now, and if it's a gaming rig, it will fill up fast. If you're going to do SSD, I would get a small top performer for the OS, and pair it with a 1.5-2 TB storage drive.
08-13-2011, 09:59 PM | #21 | |
Rep 407
@3lusive: I just built a very similar rig last night: Antec 300 case Gigabyte Z68A-D3-B3 Core i5 2500k CM Hyper 212 Plus 8GB Gskill Ripjaws DDR3-1600 9-9-9-12 Asus GTX 560 ti Samsung Spinpoint F3 1TB hard drive XFX 550W Core Edition Total: $924 (CDN) after tax @kyleb350: I would highly suggest to build your own computer. It saves a lot of money, if your into computers, it becomes a fun process, and knowing that you handpicked all the parts going into your computer is a great feeling especially down the road when it comes time to upgrade since you can pick out parts that leave room for upgrades. For parts suggestions, assuming a $1450(before tax) budget: i5 2500k (overclocks too easily to make a 2600k worth it), GTX 580, 650W+ XFX/Antec/Corsair/Seasonic power supply, 8GB DDR3-1600, Good $150-$200 Z68 motherboard, Samsung Spinpoint or WD Caviar Black 1TB drive (and possibly an SSD if you can fit it in your budget), good CPU air cooler (the Hyper 212+ is the best budget cooler), and for cases I don't know much beyond that I love my Antec 300 for the $50 i spent on it |
08-14-2011, 06:06 PM | #22 |
Rep 1,528
i just built a rig faster than that Alienware for 200 bucks cheaper. Alienware is all about the name really.
Muffler Delete/ Tien S-tech Springs / De-badged /BBS LM Reps 19"/ Nexen tires/DTM M5 Front bumper/ Injen Intake/Blacklines/M-tech Rear/Custom Muffler Tips.... More mods to come
