2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums USA - California 2021 M340i maxed out @ 130 mph
      02-12-2021, 01:17 AM   #1
Gflores23
Drives: 2018 BMW 540i / 2021 BMW M340i
Hello , so I was going fast and as I’m going I feel like a thirst I look down and my gauge says 130 mph and doesn’t want to go anymore. Obviously there has to be a limiter or something but anyone else have a problem ?
      02-12-2021, 02:07 AM   #2
PortimaoM340NYC
Drives: BMW M340
Yeah it normal for vehicles equipped with all season tires and runflats to max at 130mph. all other setups are 155mph
      02-13-2021, 08:32 PM   #3
neal11
neal11's Avatar
14
2020 BMW M340i  [0.00]
Interesting.. I have run flats too but am able to go over 130mph
      02-13-2021, 10:20 PM   #4
chenry
Drives: BMWs
So if you change your tire type in idrive does your top speed change hmmmm I wonder.
      02-15-2021, 08:38 PM   #5
cywing1119
Drives: 2010 E92 M3
i wish, but it doesn't work
      02-15-2021, 08:39 PM   #6
cywing1119
Drives: 2010 E92 M3
The all season run flat which is 225/40/19 all around will locked at 130mph top speed
      02-15-2021, 11:20 PM   #7
MBM340
MBM340's Avatar
Drives: 2021 M340 RWD
2021 BMW M340i  [0.00]
IF your car came with staggered set up and Summer tires you get 155...if you have square set up you are screwed into 130...I believe dealers can change but you have to have that setup.
"Either get busy living, or get busy dying. That's GD right." - Red (Shawshank)
      03-03-2021, 04:19 AM   #8
Gflores23
Do you know if I can go to the dealer and they can some how get me to go past 130 mph
      03-03-2021, 09:37 AM   #9
MBM340
MBM340's Avatar
You can look that up on here...tons of threads. They won't do it unless you have staggered set up with Summer tires. They still may not do it. It is programmed from the factory.
      03-17-2021, 12:07 PM   #10
chenry
Drives: BMWs
The only way I know to do it is with a flash tune but that obviously comes with power gains as well. If you are only looking to get rid of the speed limiter you might want to call Alex at Mission Performance...they are in Rancho Cucamonga (not too far from you) he may be able to do a one off for you?
      04-03-2021, 03:23 AM   #11
bimmer456
Drives: 340i
Didn't know the m340 came with this setup thought it was only m sport trim so no all season square setup, thought that was 330 only.
      04-04-2021, 01:23 AM   #12
cywing1119
Drives: 2010 E92 M3
it was a option from dealership
      04-09-2021, 03:45 PM   #13
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
Unless you're at the track, 130 is more than fast enough.......(and if you're Tiger Woods, 87mph...)
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|
      09-01-2022, 02:59 PM   #14
IsleOfMs
Drives: M340i
I asked my dealer about that and instead of saying "no, we won't do that" or "no, the software is hardcoded and can't be overwritten" or literally any other actually knowledgeable and believable statement, the guy said "It's a state law to limit cars to 130 and it would break the law to remove that limiter." LOL.
So that guy was obviously talking out his tailpipe but I didn't want to argue with him. Chances are that if you found the right dealer, you might find one who can/will fix it for you but it's not likely.
It's frustrating since someone could by a car with high performance wheels/tires, and keep that OEM set of wheels for the track or some other special occasion and buy a second set of square all seasons for commuting or road trips and nobody would go change his limiter to 130.
      09-01-2022, 04:15 PM   #15
Bc2005
Drives: 2021 M340i
AFAIK the higher speed limit on an M340i requires the high performance tire and cooling package, which is more than just different tires. However, maybe I’m confused.
