03-03-2023, 07:42 AM | #1 |
Rep 31
Water in sills
I opened bonnet yesterday in rain, and the rain water ran off and into the engine compartment. This morning I can hear water swooshing about as I brake and accelerate, which seems to be coming from the sills. Is this normal? Ta.
03-03-2023, 01:58 PM | #2 |
Rep 7,484
Sounds like blocked drainage holes. Not normal. Usually, it’s leaves that get caught under the hood, some decay, and gunk up. Equally, there are drain channels under the doors and sills. So check all over.. it might be something you can address yourself before turning it over to the dealer. You can always do a dye leak test with UV light. It’s an inexpensive dye and light available online. Spray the dye and water mix in different places. Check with the light.
shauntb10.00 |
03-06-2023, 02:07 AM | #4 |
Rep 820
