07-24-2020, 07:26 AM | #1 |
Rep 632
Drives: 2019 X740i
Map Update - 3D?
Woke up and my NAV looks completely different, maybe I've completely missed the boat, was it always this way? It's way better than 2D, that's for sure.
07-24-2020, 07:48 AM | #2 |
Rep 1,037
This has always been an option (going back to CCC iDrive)
07-24-2020, 08:25 AM | #4 |
Rep 632
Drives: 2019 X740i
Wow, not sure how it changed, but it's so much better!
07-24-2020, 11:44 AM | #5 |
Rep 38
Is it normal for the map to take full screen and the "status bar" docked in top right. As far as I remember my status bar is always taking full row at the top. Maybe it's the maps, I'll have to check today.
07-24-2020, 12:38 PM | #6 |
Rep 10
There's a proximity sensor that detects when your hand is near the touch screen. If you move away and don't touch the iDrive controller after a few seconds, then the map will go "full screen".
07-24-2020, 04:33 PM | #7 |
Rep 2,946
Drives: 2020 BMW 530xe
I'm not at my car, but I think you get that view if you set the map to "Reduced Mode" in settings.
07-24-2020, 04:43 PM | #8 |
1942
Rep 3,521
I have an old version of iDrive (7.2019.38 I think). Mine doesn’t have the 3D option. Only option was 3D when approaching junctions or something of that sort. Clicking the compass icon at the bottom changes it from current position to always facing north and back.
Is there another setting I’m missing? I went through map settings as well as general settings and couldn’t find it.
07-25-2020, 01:20 AM | #10 | |
Rep 177
VipinLJ1941.50 |
07-25-2020, 01:23 AM | #11 |
1942
Rep 3,521
Thank you very much! But unfortunately, I dont have the perspective option. Just the direction of travel and always north IIRC. Definitely no perspective, because thats the first option I checked. I probably need an update for that.
07-25-2020, 01:52 AM | #12 |
Rep 177
Originally I was on 07/2019 and the option was always present. The screenshot is from youtube video from march 2020, so it may be 11/2019 software version.
It could be that this option was introduced to US market only so late, but it makes no sense to me... I have an issue with disappearing shuffle option when playing usb music, and it appears for a while after I hard reset the iDrive (crazy, right?). I would try the reset as the last thing to be absolutely sure. |
VipinLJ1941.50 |
07-25-2020, 02:34 AM | #13 | |
1942
Rep 3,521
Does the hard reset remove all codings? If so, I can live without the 3D option If not, I can give it a try. But redoing all my codings again using a Bluetooth adapter will be a PITA.
07-25-2020, 03:40 AM | #14 |
Rep 177
Nope, all it does is just turning it off and on again. With engine running press volume/power button for approx 30 seconds until the screen goes blank, give it a minute to restart and check again. If that won't help then I guess you will need an OTA update (not sure about codings though).
VipinLJ1941.50 |
07-25-2020, 06:17 AM | #15 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Cabby ,
The map view you pictured is really great, But takes a little getting used to since it changes its presentation as you drive, rather than traditional north at top look. I switched to this view a while ago as well You can change map views by pushing controller to the right & selecting settings & then view. In addition to this view (perspective), there's north at top & 3D (only in select cities which give you 3D renderings of buildings). Think these were even on my F30
Al
VipinLJ1941.50 |
07-25-2020, 06:53 PM | #16 |
Rep 632
Drives: 2019 X740i
Well what's really strange is I got in our X7 later that day, same thing. Map was 3D view like that and I also didnt change that one. Weird right?
07-25-2020, 07:23 PM | #17 |
1942
Rep 3,521
I did a hard reset and the perspective option appeared. Weird it was missing all thing while.
